Question about Emerson Smartset Clock Radio
I need a manual for hh211 to be able to set time
How do I adjust the settings on a 625-236 atomic clock
If you have a Howard-Miller 625-236 atomic clock, do you need to change the time zone only or manually set the time?
To set the time zone, press Mode (furthest left on the back of the clock) to get to the Alarm Time Mode. Then press Set (2nd from the left) to change the time zone. Then press Adjust (the middle button) to select the correct time zone. Press Mode again to exit the settings mode. To manually set the time, you need to remove the battery from the clock. Then reinsert the battery after 30+ seconds. Press and hold Set until the hour begins to flash, then press Adjust to change the time. Press and hold to quickly change the hour. Then press Set to change to the minutes and use Adjust to set the current minutes. Repeat this routine to set the seconds, month, date and year. Press Mode to exit to the Time mode.
The manual is available here: http://www.theclockdepot.com/howard-miller-625-236-techtime-operations-manual.pdf .
I hope this helps.
Oct 06, 2014 | Home
How do you change the time zone on 2007 Toshiba Regza 42HL67?
the manual doesn't mention anything about setting the time, so I am wondering if it comes from the cable or satellite box connected to it.
this is how it is done on another Regza model
Setting the time zone
The Time Zone setup will allow you to specify the
correct time zone for your region. This feature will
allow the TV status information to show the correct
time zone information for your viewing area.
From the SETUP menu, highlight TV Settings and
press T.
Press B or b to select Local Time Setting and press
T.
Highlight Time Zone and press C or c to set your
desired time zone.
If you want to activate the daylight saving time,
highlight Daylight Saving Time.
5
Press C or c to select On and press O.
Toshiba REGZA 46SV670U Owner Manual Setting The Auto Input Feature Setting...
your model manual
Toshiba 42HL67 42 LCD TV Service Manual
Jul 24, 2017 | Toshiba REGZA Televison & Video
How do I change the time on my tom tom
The clock on your navigation device is automatically synchronised with the satellite clocks. You can also set the clock manually, for example when the device is indoors and unable to receive a satellite signal. The default setting is to automatically adjust the clock for the current time zone.
How to change clock settings To select the time format and to set the time, follow these steps:
Open the Main menu and tap Settings.
In the Settings menu, tap Set clock.
Select how the time should be displayed, then tap Next.
When you do not have a satellite signal, you are asked if you want to set the time manually.
Note: Since you need to be outside for your navigation device to receive a satellite signal, you might want to immediately set the time manually. The device will then set the time automatically when you next take the device outside.
Tap Yes to set the time manually or tap No to set your device to update the time automatically using GPS satellites.
Hope this was helpful. Thank you for using fixya.
Jan 26, 2011 | Tomtom GPS
HOW DO i SET THE WOODS 59203 TIMER LOST DIRECTIONS
Woods timers and manuals:
http://waterheatertimer.org/Woods-timers-and-manuals.html
The picture shown at fixya for 59203 is not correct.
Picture shows 49112 which is also TD1000:
Manual for 49112-TD1000:
http://waterheatertimer.org/pdf/Noma-TD1000.pdf
Manual for 59203:
http://waterheatertimer.org/pdf/Woods-59203.pdf
Manual shows 15 steps.
Plug timer in to charge battery. If battery will not charge, then timer is bad.
Set current time.
Set program1 ON time.
Set program1 OFF time
Set program2 ON time
Set program2 OFF time up to 20 pairs of ON-OFF times.
When programming is complete, press ON/OFF/Auto until Auto shows in display.
Add a comment of you need help with specific programming.
Nov 28, 2010 | Woods Indoor 24 Hour Digital Timer (59203)
How do i set cam position and timing on an old yamaha xt 500
You didn't say WHY the cam / valve timing needs to be reset. For some reason I get the feeling someone told you that resetting was needed and so you are asking how. Obviously, you may have installed new pistons and that is why the resetting is needed. In either event, when the cam timing is set the valve timing is also set. Other than adjusting valve lash, setting the cam sets the valve timing. Below is a web site where you can do a free download of a factory service manual. The process is not hard but having a manual will be more help and faster help than I can give online.
http://www.carlsalter.com/motorcycle-manuals.asp
May 25, 2010 | 1997 Yamaha XT 600 E
How do I change the radio station on the radio alarm
Here is the full manual
http://www.timexaudio.com/pdf/T311IB57574_35.pdf
Here are the instructions from the manual.
Setting the Radio Alarm
1. Press and hold the
Radio Alarm Button. The display will flash and the Radio Alarm Indicator will
appear. If you do not begin setting the time within ten seconds of pressing the button, the display will stop
flashing and you will need to press the
Radio Alarm Button again.
2. While the display flashes, press the Reverse and  Forward Buttons to set the wake time. Hold a button
for a few seconds to set the time rapidly. Be sure to set the correct AM/PM time, as shown by the PM Indicator.
3. After setting the radio alarm time, you will need to select the station. First, press the  Radio Band Button
to select a radio frequency. Next, select a station using the Memory Set 1-6 Buttons. For more
information on programming radio stations into memory, see the Programming Radio Station Settings section
of this manual. Rotate the  Volume Thumbwheel to set the wake sound volume.
4. After setting the radio alarm wake time and sound, you will need to select the 7-5-2 setting. The 7-5-2 setting
lets you set the alarm for a full week, weekdays only, or the weekend. Before setting the alarm, be sure that
the correct date is set, as shown in the “Auto-Set” and Manual Time and Date Settings section of the manual.
While the display is still flashing, press the  Date/7-5-2 Button until the desired setting is shown.
5. After you have set the radio alarm wake time, sound, and 7-5-2 setting, press the  Enter Button. The
Radio Alarm Indicator will appear on the display, showing that the radio alarm has been set.
Aug 08, 2009 | Timex T311T Clock Radio
Garmin 205 running watch/ need to set actual time
It was only now that i saw your original post
One option is to touch the time settings in the top right. You can then change the time. Another option is below.
To update the time.
Go to Tools> Settings>Time
Time Format select either 12 or 24 hour time format
Current Time - you can manually set it or automatic to have the nuvi set the time based on your location.
The link to the manual is below as well.
http://www8.garmin.com/manuals/nuvi205_OwnersManual.pdf
http://www8.garmin.com/manuals/2459_QuickStartManual.pdf
Oct 13, 2008 | GPS
Need owner's manual to set time
i can't set the time i need help
Apr 12, 2008 | RCA RP4803 Clock Radio
Instruction manual
Hold the clk button untill the time starts flashing,press 4 to get time into program mode, then press 5 to set the Hour then 6 to set the min. Its that easy.
Mar 15, 2008 | Alpine CDE-7858 CD Player
Emerson Smartset Clock Radio Logo
304 people viewed this question
Top Emerson Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
