Question about Bissell 8910 ProHeat Clear View Upright Vacuum
Brushes will not turn. belts are good. what else can be wrong.
  • Bissell Master
  • 43,501 Answers
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Posted on Sep 17, 2010
Brushes will not rotate
I can't tell for sure from the pictures, but there are two possibilities - the drive belt to the brushes broke, or the brush can't turn due to excessive hair wrapped around the shaft. If the belt is OK but the brush does not turn, you should smell burning rubber.
If the belt is broken, you have to remove the bottom plate to expose the brush, remove the brush and the broken belt, and replace the belt, and put it back to gether. While you have the brush out, now would be a good time to clean it - remove the hair, etc from the brush and around the shaft. Good Luck!
Dec 19, 2012 | Hoover F7210-900 SteamVac V2 Upright...
When we first turn on the cleaner, the brushes will turn, but then they stop. What do you think is wrong? Thanks
The belt is shot and when it heats up it strecthes even more so that the brush will not turn then... change the belt and your good to go...
heatman101
Apr 28, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Belt keeps slipping off need to check the correct belt number and what can i do
What does it slip off of, the brush or the motor? Are you sure that it is in correctly, as there are usually 2 ways of putting the belt on. If put on correctly, it should not contact any part of the vacuum except the motor shaft and the brush. Also check check there is not a buildup of hair, etc. where the belt goes around the brush. I would try turning the brush by hand and see if anything is interfering with the path of the belt. There is always a chance that some part of your vacuum has broken or malfunctioned and is touching the belt and making it come off. Also, make sure that the brush is correctly installed.
The tension on the belt should be pretty high so that it is hard to pull out of place. If not, you could have the wrong belt. I believe that this takes a type "U" belt if that is any help. Hope this helps and good luck!
Mar 15, 2010 | Eureka Whirlwind LiteSpeed 5843 Upright...
Turns on but doesn't turn over.
I would first check your filter as a dirty filter will sometimes produce this probIem. If that doesn't work take a look at the brush bar. I don't believe that these vacuums have a belt (I could be wrong about this and a broken belt will disable the brush) so the only thing that I can recommend is to unplug it, turn it over and see if there is anything obstructing the roller brush such as string, tinsel, rocks, etc. See if you can turn it with your hand without using much force. Good luck!
Mar 15, 2010 | Bissell Lift-Off(R) Revolution(R) Turbo...
Brush won't spin. Put it back on the ribbed belt
Make sure the driving motor (power on) is turning (without the belt attached). Make sure the brush turns freely when the belt is off (it's probably jammed with wound-up hair, thread, and other debris--remove the brush and clean/lightly oil the bearings). Check the tension of the belt which should be fairly firm--replace if sloppy. Rotate the motor shaft by hand when everything is back together and make sure the brush can be driven without the belt trying to jump off. Hope this helps!
Mar 03, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
Carpet roller brush will not turn
You probably need a new belt. You can get kenmore belts here:
Kenmore Belts
Jan 02, 2010 | Vacuums
The rotary brush stopped spinning. I believe its
I have seen belts wear faster than that, believe it or not. Here is a link to the belt you need and a link to the manual:
Bissell Health Home Replacement Belt
Bissell Healthy User Guide (PDF)
Nov 17, 2009 | Bissell Healthy Home HEPA Bagless Upright...
Kirby g4 problem
1. Take the brush roll and belt off the vacuum. Put the head back on the vac.
2. Turn it on and see if the bag inflates with good power. Does it sound normal? This will tell you if the problem is with the motor. If you have a good inflation of the bag and a bad noise in the motor, you need to take it in for service. If the motor is fine, you need a new spinning brush assembly.
The screw heads of the brush roll face towards the floor so you can adjust them while the brush is in the vacuum. When you turn them clockwise the brush comes down and gets closer to the floor for better carpet cleaning. You should also change the belt on that vac once a year. Just because the belt isn't broken doesn't mean it's o.k. Once they stretch out the power from the motor is lost and the brush won't clean anything.
Oct 05, 2009 | Vacuums
Belt will not spin
3 things may be wrong. 1 - brush motor burned up or disconnected. 2 - belt damaged, stretched or missing cogs on belt. 3 - belt is turning but brush roller is not turning due to bearings froze. In all 3 of these cases, the vacuum should be taken in to a repair shop.
Jun 27, 2008 | Hoover Vacuums
Bissell 8910 ProHeat Clear View Upright Vacuum Logo
41 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
