Question about Dishwashers
My frigidaire gallery ultra quiet III dishwasher does not spray water within the barrel case; is my surge pump gone?
  • 17,130 Answers
Yes Yourr Pressure pump that does teh high pressure spray is not working. Now identify the wires to the pump and check the voltage during the cycle .If present the pump is faulty and must be replace. However if there is continuity on the coild ccheck to see that a reset can make it work from a strck up condition.
If there is no voltage on the pump the controller unit is faulty.check relay , check board..
Posted on Sep 17, 2010
Frigidaire ultra quiet iii top rack not cleaning - bottom rack is great.
Use a magic eraser.
Also there is an excellent product from Home Depot, Krud Kutter.
Also googone, not goof off ( Goof Off is a stronger , more potent chemical and Goo Gone isn't as dangerous but very effective and works great!)
Goo Gone is at almost every store.
If these don't work, let me know.
Thanks and good luck !
Jan 02, 2015 | Frigidaire Dishwashers
Loud sounds
Many Frigidaire dishwashers come with the promise of being the "quietest dishwasher in its class," according to Frigidaire. However, a quiet dishwasher doesn't necessarily mean that the dishwasher is silent, as some noises are normal. It can take some troubleshooting at times to determine if a noise coming from the dishwasher is typical or if it indicates a larger problem Listen for the sound of water filling and draining throughout the wash cycle. These sounds are normal and do not indicate an issue.
  • 2 Pay attention to the drain motor, which operates at the beginning of each cycle. This noise should be fairly quiet and should not sound like a loud, grinding or banging sound.
  • 3 Note that the sound will change when the wash cycle moves between the lower and middle spray arms. This sound should be temporary and fairly quiet.
  • 4 Look for hard items in the dishwasher grinder or filter if a loud crunching, buzzing or grinding sound is heard. The dishwasher can typically grind up these items within one or two cycles, but the item may be lifted out and discarded to eliminate the sound.
  • 5 Remove the bottom rack and spray arms from the bottom of the dishwasher if there is a loud noise coming from the dishwasher that does not resolve itself. Look inside for the impeller, which is round and spins. Remove any debris that may be clogging up the impeller or pump.
  • Oct 07, 2011 | Frigidaire Professional Series 24 in....
    The upper spray arm doesn't seem to be moving or spraying water properly. It does move freely
    Assuming top spray arms are clear of debris It sounds like your pump/motor assembly is bad and needs to be replaced.Thanks
    Feb 01, 2011 | Frigidaire 24 in. GSB5712BC Gallery...
    Will not drain water from Ultra Quiet III dishwasher?
    Here is a tip that I wrote that will help you with your dishwasher not draining problem...
    Dishwasher Problems - Water will not drain out
    heatman101
    Sep 25, 2010 | Frigidaire Dishwashers
    My frigidaire ultra quiet spray arm doe's not move.Water trickles out the holes,no pressure.
    water does not spray on the top arm until a later cycle...only one arm spins at a time... a fridgidare thing
    May 11, 2010 | Frigidaire 24 in. FDB126RB Built-in...
    I have a frigidare gallery ultra quiet III that is approximately 10 years old. It is not draining water to the point that it is leaking on the kitchen floor.
    Hi
    Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
    Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
    First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
    Please do rate the solution and revert for further assistance.
    Thanks
    Rylee
    Nov 03, 2009 | Frigidaire Dishwashers
    Fridgidare ultra quiet III
    how old is this unit and what is the model #?
    Feb 13, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
    Frigidare dishwasher
    can you give me the exact model # on your dishwasher and i will check for you.
    Sep 03, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
    Dishwasher not pumping the water out?
    hi
    the larger motor housing underneath the unit is what moves the water around to wash, the smaller pump is the drain pump, if you don't hear that running it is likely in need of replacement. check your paper work for warranty, if it's out of warranty try to find a deal online and it's relatively easy to replace
    Mar 20, 2008 | Frigidaire 24 in. FDB750RCC Stainless...
    Dishwashers Logo
    451 people viewed this question
    Top Dishwashers Experts
