Question about Emerson EWV403 VHS VCR
What channel does the vcr need to be on to play a tape?
  • Emerson Master
  • 17,130 Answers
If you meant to conncct the RF out of the VCR to the RF in of the TV then mostly the RF outputs come in the bands VHF1 CH3 or CH 4 . Also it comes mainly set from factory in the UHF CH36.
Iff there is interference in your area due to local channel the channel can be shifter by trimming the modulator.
So tune the VCR accordingly or Use the AV inputs, video out to video in and audio outs to audio in of TV.
Posted on Sep 17, 2010
Troubleshooting vcr/cable box
Seriously? You are still using a VCR?
Feb 03, 2018 | Computers & Internet
I have recently moved to another state and need to change my channel that receives signals from 4 to 3. how do i do that? thanks.
My Emerson EWV603 VCR came up on channel 3.
My manual says to put a tape in, push play at the VCR.
After 2 or 3 seconds, push play again AT THE VCR. This
changed my default channel to 4. Maybe you can do the
same to go from 4 to 3.
Nov 08, 2009 | Emerson EWV603 VHS VCR
Setting up used VCR
did you check the channel select swith on the toshiba?
Sep 06, 2009 | Toshiba W612 VCR
Can't record from camcorder to VHS tape on LG Model VCR
ok,uve gone OUT of cam and IN to VCR player?,then press play on cam and record on VCR,u should see whats recording as long as your on your normal video channel
Aug 17, 2009 | LG V181 DVD Player/VCR
I purchased a RCA DRC-8335 DVD/VCR RECORDER COMBO
For anyone who has an RCA DRC 8335 with dvd Recorder, here is a suggestion.
If your tapes have been recorded in SLP Mode, om another player, I can tell you they will NOT play on this thing!!
So, merely take another VCR, and a blank tape, Place the blank tape into the RCA DRC 8335 VCR side, and then, go to its Set-Up Menu, and go to OUTPUT. On the "ACTION BAR"Change the the RCA's output to "FRONT" and then, play the VCRr you stuck on top of the RCA!!
When the inage on the "Source tape is shown,
Record onto the RCA, in SLP Mode, Now, it will play, just fine.
Hope this helps. Jon (Found BY Accident!!)
Jul 31, 2009 | Televison & Video
Sharp VCR hooked up to cable tv, i/p to vcr then out to tv.
I believe that I have the solution to that problem... When you are hooked up to cable or dish and use a VCR, you MUST have the program you wish to tape playing on the Cable or dish program, therefore the VCR needs to be tuned to channel 3 or 4 {whichever is the unused channel in your area) I believe that all you have to do is make sure that the TV is tuned to the channel you wish to tape and program the VCR to Channel 3 (at my area) or channel 4.
I hope this works for you. I have VCRs hooked up to all my sets and this is how mine work.
annabanana
Jan 23, 2009 | Televison & Video
Philips DVP 3200V/37
Hey there, Here are some ideas; I would clean it one more time to make sure that its nice and clean try playing a different tape on your VCR and check the channel on your VCR, and thats if you are using a channel 3 or 4 on your VCR, concur with each other. Meaning if you have Channel 3 on your TV you should have Channel 3 on your VCR. Thats a really old method. If you use a coxial cable unplug it and replug it in again sometimes there is no contact at one of the ends therefore disconnecting or connecting it again would help. Just see if that works and usually that was the problem when i use to have problems with my VCR. Let me know if that works out for you alright.
Oct 04, 2008 | Philips VR621CAT VHS/S-VHS playback VCR
VCR plays tape with only sound and some channels seem deleted.
Needs the vcr heads cleaned, and get a universal remote with a menu button to change the tuner setup.
Jan 25, 2008 | Toshiba MV13P2 13 in. TV/VCR Combo
Tapes not playing
Hey do the tapes play at all? sometimes some tapes recorded
on other machines won't play on others. maybe you need to adjust the tracking on the VCR you are playing it on. If the tape
was recorded on a VCR that is misaligned it might not play back
on another VCR. Also the tape may have been recorded on a
super VHS VCR in et (extended definition) mode if so they won't play on just any VCR. If the picture looks scrambled like a
premium channel on analog cable then it's probably recorded in et.
and if its recorded on super VHS tape it may eject out of your VCR.
They don't make these S-VHS vcrs anymore but people still
have them around. There is also Digital VHS they're not
compatible with VHS either. A VHS recorded in et mode will
play on some more expensive vcrs it should say so on the box
or instructions.
Nov 14, 2007 | RCA VR634HF VHS VCR
VCR won't tape and get no playback
First check how good / bad are your recordings. Take a current / recent recording done after this problem cropped up, and play it back on another VCR - maybe a friend's. If the recording plays back badly- showing the symptoms you described, then the problem is still dirty or worn out Video Heads. If the Recording plays back perfectly on the friend's machine, but plays back badly on your machine, I still suggest that you try cleaning the Heads one more time, and if the problem is not resolved, it is time to trash the VCR. One last question, you say that you have reset the channels. Are the reception channels' images clear? I may be able to give some more suggestions, based on this response.
Apr 17, 2007 | Goldstar GVR-E435 VHS VCR
Emerson EWV403 VHS VCR Logo
94 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
