Question about Hitachi 51F59 51" HDTV Projection Television
I have a 51 f 59 picture looks pink, adjusting color ant tint does not help
  • Hitachi Master
  • 17,130 Answers
Possible that the fault relates to the weakness/absence of the G- signal process in the RGB network. It can be related to many issues, the failure of the IC, dry soldering of the IC or related circuit or failure of passive compoents here.
Need a check with a schematic to find the fault.
Posted on Sep 17, 2010
Red Tint on Screen
This is normal and is a color calibration issue.
For correct color, NEVER use the "WARM" setting. Why? Too red. You cannot get REALISTIC or ACCURATE color using the "Warm" setting.
Since we are speaking of Samsung, first avoid the "Flesh Tone" adjustment. When things are set correctly there is no need for this adjustment. It is a quick fix and not for the "discerning eye".
1. First, access the "Color Temperature" menu. From here select "Cool2" or the coolest temperature setting.
Note: For Samsung use "Cool2", or if not available, "Cool1". Samsung has inadvertently increased calibration confusion by issueing TVs that have just "Cool1", and TVs that have both "Cool1" and "Cool2" :0[
For other brands, use "Cool", or "High", or "+6500k". Anything lower artificially reddens the picture and compromises detail.
2. Now return to the color settings and reduce "Color" to between 30 and 40 (on a 100 scale). The sweet spot is just near the place where the color rapidly washes out.
3. To round out the color palette, move to the "Tint" adjustment and ADD a couple (3-5) clicks to the GREEN.
Adding the touch of green is what is needed to take out the last bit of "pink" and will make all the tones and all colors display properly.
I hope this helps!
To further increase the quality of your picture visit
http://www.wowvision.tv/main.htm
Highdefjeff :0]
Jun 15, 2010 | Samsung LN46C630 TV
Images on screen are very red. Tried adjusting everything in the menu but still every thing is like glowing red.
Color balance is labeled "Tint"
Color amount is labeled "Color"
Both are in the "picture" adjustments menu.
Either your tint is swung too far to red, or the color setting is wide open making normally pink faces look sunburned...likely it's a combination of the two; Too much red, and a bit too much color.
Going back to the "default factory setting" in "setup" will also drop all settings to center.
Mar 30, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
My hitachi 43fdx20b has a pink tint to it. I have noticed that if i move the tint slider one way or the other it will turn the screen green, but now it doesn't. Does this have something to do with my...
My 43fdx20b had a pink tint to it also. The picture was clear otherwise. I found, on mine, I needed to adjust the Red Screen control. It was located behind the front panel. I removed the two screws on either side of the front panel and was able to remove the panel. Then I adjusted the Red Screen control. I found that if I tuned in an old Black and white movie I could adjust the color fairly accurately. Good Luck.
Jan 02, 2010 | Hitachi 43FDX20B 43" Rear Projection...
I just replaced the bulb in my Sony 55'' Grand Wega. the picture looked fantastic the first day. turned on the TV the next day and everything that should have a ''white color'' looked pink. the blues...
Please adjust TINT control of Video Settings in Menu that will adjust color tone of TV. I do not think this problem is related with Lamp because TV screen does not have any color blobs or spots.
Above solution is for Sony KDF-55WF655 model TV, if your model number is different, let me know.
Thanks.
Nov 29, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony KV-36FV27 too dark, pink or green tint, 5 blink error,
Fuzzy,blury picture in CRT tv tube.Tv in long use not repairable.Tv tube is dying,it junk.
Mar 27, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
Magenta Color
Here is something that may help from the toshiba.com website under your model number television. Q. Why are people on my screen green?
Models: 32HL17, 37HL17, 42HL17, 42HL167, 47HL167, 52HL167, 42HL167, 42LX177, 46LX177, 52LX177, 57LX177
REF:FAQLCD00107
If the problem is not the connections, try adjusting the tint on your television. A high tint setting will usually create a green
image on the screen where as a low tint will create a more red hue. In order to access your television's tint:
1. Press the “MENU” button on your remote control and use the LEFT or RIGHT arrow keys and select the
VIDEO menu.
2. Then use the UP and DOWN arrow keys to highlight PICTURE SETTINGS and press the "ENTER" button on
your remote.
3. Next use the UP and DOWN arrow keys to highlight TINT then use the LEFT or RIGHT arrow keys to adjust the
TINT. If the picture is too green the tint will need to be lowered.
4. Once you have adjusted the tint to your liking, use the DOWN arrow key to highlight DONE and press ENTER. The toshiba customer service telephone number is : 1-800-631-3811. I hope this helps you with your problem.
Feb 01, 2009 | Toshiba 42HL167 42 in. LCD Television
TV Picture is tinted pink
depending on how much you paid for the tv , the cost of the repair may be more than the tv is worth. but if this is a large tv , then the repair would be most likely worth it
Dec 29, 2008 | Televison & Video
Pink tint problem with a sharp T.V
Go to TV Menu and check Color System. Change it to NTSC and Tint option will be enabled. Your TV is now working on PAL color system.
Jul 27, 2008 | Sharp Televison & Video
Red color abunDANT
Please verify model # from rear of set.PVAT! Look closely at signal PCB for signs of CRT coolant leak.
Oct 03, 2007 | Toshiba 42H82 42" Rear Projection...
Hitachi 51F59 51" HDTV Projection Television Logo
57 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
