Question about Pentair Minimax NT Heater
I have a pentair minimax 250dv pool heater. burner is not coming on and have E04 error code. I have replace the starter and didn't change.
    Top Expert:
  • Pentair Master
  • 8,177 Answers
Fan
Posted on Oct 07, 2017
5 Suggested Answers
  • 61 Answers
SOURCE: Pool heater will not heat
Im no pro, but I know there is an air sensor behind the main board. If the fan is running you probably have a problem with that sensor. If your lucky the air hose could have just popped off.
Posted on Apr 04, 2009
  • 990 Answers
SOURCE: E04 comes on after fan purge cycle-Pentair minimax nt pool heater
This is a fan falure code. It can mean the fan has problems (not likley if the fan goes and isn't labored) You have a sensor in your exaust (probally not this if you don't get a good start) The culperet is probally in the negetive pressure sensor. This is a 2-3 inch disc with wires going to the controls and a rubber tube going to the fan. Pull the tube from the fan and make sure the fan fitting is clear (poke with a tooth pic) Be sure their are no kinks in the hose. If the heater is 4 years old the diaprahm could be bad in the pressure sensor. Check the other things first but this is probally your problem. Good luck, hope this helped.
Posted on Jan 26, 2010
  • 64 Answers
SOURCE: error code e04
If the fan was seized, it is likely bad, even if you freed it. If it doesn't sound the same, or is not as loud as it used to be, it is also most likely bad. If it doesn't move enough air to close the air pressure switch, then you will get an 04 fault, which is an air flow fault. HTH
Posted on May 24, 2010
heatman101
  • 43501 Answers
SOURCE: My pentair minimax plus 250 M pool heater won't
For most pool heaters, if they will not start up in the spring, the problem is corrosion in the wiring somewhere... I would remove and clean all wiring connections and then try. The amount of current is very small and so any bit of corrosion can cause the unit not to work.
It all so could the t-stat again, but you would need to check that with an OHM meter. No continuity when the heater should be on will confirm that the t-stat is bad...
heatman101
Posted on May 14, 2011
E04 minimax error code
check to see if you have adequate gas pressure sounds like it running out of gas pressure
Aug 04, 2014 | Pentair Minimax NT Heater
Since you said you replaced the fan, and flow valve. Did you re-install the pressure switch correctly? it will look something like attached image. This is more than likely the cause if you did not replace with the fan or reinstall correctly... or it might have been the cause in the first place...
Pentair e04 code
if ignitor glows see if voltage to gas valve if voltage ok check to see if clicking open if ok check burner tubes if no click bad valve if no voltage bad fenwal
Jan 20, 2018 | Pentair Minimax NT Heater
Error code e04
May 23, 2010 | Pentair Minimax NT Heater
Have a Minimax NT heater that was giving an E04 error. It was able to clear the error when I shut power off and on again. Got the error again then thet heater would trip the circuit breaker in the breaker...
e04 is just a signal that you have not flame clean the burners firs check the conectors . is t blower on ? see if all the hoses are conected wire loose or missibg conector. some thing is making the heater not to work and t tsensor is telling not flame
Sep 16, 2009 | Pentair Minimax NT Heater
I have E04 error code, fan runs but no ignition or gas or gas smell
troubleshot vaccum switch determined it was operational (Use Pentair's website for service instructions on the switch) Fan speed too slow due to worn out motor. Replacing blower assembly
Aug 01, 2009 | Pentair Minimax NT Heater
Mar 20, 2009 | Pentair Minimax NT Heater
Pentair Minimax NT Heater Logo
291 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
