Question about HP KQ495AA Pavilion A6500F Desktop PC
I have a HP Pavillion a6500f and receiving the BIOME-1 error. I removed both memory cards and tested each individually and they worked fine (as single units), but when I plug both in I receive the BIOME-1 error. What else can I do?
  • 388 Answers
You have a faulty port on the motherboard most likely, try the ports and see which one fails. You can either buy a new motherboard or just buy a bigger chip to use on one port.
Posted on Sep 17, 2010
HP Pavillion won't recognize Plug n play devices
Look into the Bios or System Setup and make sure Plug and Play is enabled. When you turn the system on notice what key it says to hit to get into the Bios or System Setup. Hit that key and check the Plug and Play to be sure it is enabled.
Apr 24, 2012 | HP Pavilion Media Center m9340f Desktop PC
HP a6500f will not come on...no HP Logo...no beeps...black screen...fans run
if u have system mechanic, you can use the disc to boot from and it'll read your MBR....it is probably messed up....and needs to be repaired. Have you ever used a registry cleaner? if not, you also may have tons of registry errors....and registry errors can also give you blk screen of death.if you have no system mechnic disc nor can borrow one, then try this.....http://download.cnet.com/MbrFix/3000-2094_4-10485990.html?tag=mncol;1
please post back you findings
Apr 22, 2012 | HP KQ495AA Pavilion A6500F Desktop PC
How do I fix error code BIOME-1? That's what
One or more of the RAM memory modules are bad and must be replaced. You will need 2 of these if you have the pc above
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2968664&CatId=1872
Instructions http://www.youtube.com/watch?v=SiFIgSQOY7g
Jun 18, 2011 | HP Pavilion Desktop with Intel Pentium...
Hi. happy new year! my problem is it's not booting cp. i has check problem it come out memory (4096mb) error code(BIOME-1). what's problem that? can i change just new memory? thank you.
First try re-seating your ram modules to make sure they are properly seated. If that doesn't help try removing each module one at a time and restarting each time to see if start up is normal. Keep in mind to keep each module in it's original slot!!
You can also try this free test:
http://www.memtest86.com/ memtest86
hope this helps
Jan 07, 2011 | HP Computers & Internet
Is there a fix for biome-1 error
I purchased 2x2gb Ram sticks... along with a new case, I had them all installed by a client of mine who owns an IT company and I had the pleasure of waiting around for 4 hrs while they ran through all the RAM tests... PC works fine however as soon as I'm away for it for any length of time I come back and its continually rebooting. diagnostic says RAM test failure Biome-1.
Removed the RAM and fitted fresh, problem solved.
Hope that helps.
Jan 03, 2011 | HP Pavilion a6712f-b PC Desktop
Hp pavillion dv6227 pc notebook black screen during start up?
Start taking your laptop apart piece by piece and test it after each removed component:
1. Remove the hard drive and test the laptop.
2. Remove the DVD drive and test the laptop.
3. Remove the wireless card and test the laptop.
4. Unplug the display panel from the motherboard/video card and test the laptop.
etc....
Continue taking it apart until you have only three major components connected: motherboard (with video card), processor, and memory. If you still experience the same problem, most likely it's bad motherboard.
By the way, before you start, try reconnecting the memory module. If you have two modules installed, try removing them one by one and test the laptop with each one separately.
Sep 21, 2010 | HP Pavillion DV6227 Notebook
Ran hp diagnostics and got error code biome-1 It also said test memory 8192 mb. What does this mean and how do I fix it
The error simply means that you have a defective memory modules. If you have more than one memory module, remove all then install one at a time, this is to isolate the defective module.
Good day and good luck.
TedMac
Sep 14, 2010 | Computers & Internet
Hi there. I have an HP a6500f. Came pre-loaded with 4GB RAM. Worked fine for a year then started freezing/restarting/BSOD randomly. Ran memory diagnostics and got a BIOME-1 error with both sticks, but...
Try manually setting the ram timings in bios but....
i would think its a motherboard issue too by the sounds of it. find one that has a similar specification and fit it, I will suggest one if you need me to, just give me a list of the hardware you have installed on this current machine
Jan 14, 2010 | HP KQ495AA Pavilion A6500F Desktop PC
My hp pavilion a1330n computer freezes on the HP
the dreaded Blue-Screen of death.
Usually caused by:- Ram Failure ( memory Modules )
CPU Failure ( Processor Failure )
Hard-Disk faulty, not spinning et,c.
Cmos battery fault.
Missing/deleted/corrupted operating System files.
Possible Solutions:- remove cmos battery, from Motherboard for 10 seconds and replace. ( eliminates cmos/bios errors )
remove 1 stick of Memory ( Ram ) and test individually ( eliminates 1 or More Faulty sticks Of memory Or Slots )
remove, CPU Fan/heatsink, remove CPU and re-seat, re-grease with Artic-Silver or similar ( thermal-Compound ) replace heatsink/Fan. test.
Hope this points you towards a Sucessful repair.
Mike @ Compurepair. No-Links No-Nonsense Just Good Practical Advise :-)
Nov 04, 2009 | HP Pavilion Media Center a1330n - AMD...
HP KQ495AA Pavilion A6500F Desktop PC Logo
751 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
