Question about Maytag Neptune MDG5500AW Gas Dryer
Sometimes it will heat for a few minutes and then it won't heat up at all. Seems to be an intermittent problem
  • Maytag Master
  • 3,361 Answers
Remove the connecting exhaust vent for a test only.
Run a dryer cycle with the vent removed.
If it works,repair your vent blockage.
If the same occurs,check the blower wheel on the end of the motor to make sure it is not spinning loosely on the shaft.
Next observe the glowbar ignitor.
Is it coming on and cycling after every extenguish?
If it comes on and does not light,replace the gas valve coils.
Posted on Sep 17, 2010
What causes my stove top to randomly beat approx 8 times in a row every 2 minutes for sometimes up to several hours, sometimes a few minutes, sometimes quite all day?
If you mean 'randomly HEAT', then I would suspect the control panel. There would be logic to detect the control touch and convert that into a signal to the controlling system that applies power. If the touch panel is faulty, it may signal for power intermittently.
Oct 27, 2014 | LG LCE3681ST Stainless Steel 36" Radiant...
My maytag W10199645 dishwasher won't start
Maytag model w10199645 was starting intermittently, and sometimes only when we pressed and held the start button for 10-15 seconds. Finally tonight it just wouldn't start, period. I unplugged it for 15 minutes, then used the Heated Dry/Normal/Heated Dry/Normal and it started back up on its own.
Mar 23, 2012 | Maytag Dishwashers
My flame keeps going out. i can press the reset button and some times it will work for a week sometimes only 30 seconds. It is an intermittent igniter. The flame seems to "roll back" when it...
Your GMS unit should not be intermittent ignition but direct electronic ignition. In any case the flame should never roll out of the chamber. There can be a few reasons for the roll out but sometimes a good cleaning of the heat exchanger and a combustion analysis can cure that. The intermittent flame issue is probably a dirty flame sensor and can be cleaned with light sand paper or steel wool. Be careful not to touch the igniter only the flame sensor. It is usually on the opposite side of the burners from the ignition source. Hope this helps :)
Jan 03, 2011 | Goodman GMS90703BXA Heater
Grinding noise in my car
Disc brakes could need fresh oil in lines .
Apr 14, 2010 | 2000 Volkswagen GTI
Dryer heat shuts off after a few minutes.
replace the 2 black solenoids on the gas valve ..after heat up they sometimes will go bad and burner will not reignite even though the ignitor glows
Sep 23, 2008 | Dryers
Roper gas dryer works intermittently!
suspect coils on gas valve if ignitor glows timer is working
Jun 30, 2008 | Roper REX3614KW Electric Dryer
Intermittent convergence (IC?) problem
Can be bad solder connections on IC pins, but intermittent
conditions can damage IC's, so we usually replace because
the labor to get the board out is the same ..........Three to five
years on a pair of convergence IC's is normal.........T.
Nov 04, 2007 | Sony KP-51WS510 51" Rear Projection...
Maytag Neptune MDG5500AW Gas Dryer Logo
646 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
