I have installed my Honeywell RTH2310 thermostat from an older mercury one properly and it seems to work fine. However, I am unable to get it to operate at the set temperatures. I set the programming to 27.5 degrees Celsius throughout the day (7 days a week) but to 20.0 Celsius from 8pm till 8am. The thermostat continues to operate at 19.5-20.5 Celsius no matter what I try. I even tried to change it temporarily and permanently as per the user manual but to no avail. Please help, Vincent
  • 455 Answers
Hello Vinny Fear not the thermostat has a built in (factory) deadband of 1 or 2 degrees on purpose to keep the unit from shortcycling.It needs to maintain a minimun run time for the equipment's sake.This is normal and can't be adjusted.
Posted on Sep 17, 2010
Operating manual honeywell rth2310
Honeywell has the manual for the RTH2310 programmable thermostat on the product page: http://yourhome.honeywell.com/home/Products/Thermostats/5-2-Day-Programmable/RTH2310B.htm . The direct link to the English/French version of the operating manual is http://customer.honeywell.com/techlit/pdf/PackedLit/69-2229EF.pdf .
I hope this helps.
Dec 13, 2011 | Honeywell Programmable Thermostat Heater
The backlight is not working on my newly installed Honeywell RTH2310 thermostat.
Hello.The thermostat needs a COMMON wire.The letter C on the back of the thermostat.In the unit it runs there is a COMMON connection for that reason.I hope there is a spare wire strand to use because a lot of thermostats don't need a common to work (uses battery)but honeywell does.
Oct 31, 2010 | Honeywell Focus 6300B 5-2 Days...
I replaced my old mercury thermostat with a honeywell rth2310 and now the compressor doesn't seem to run.
recheck wires on t stat. white wire to W .yellow wire to Y.green wire to G .red wire to R .or r/c if their is a red jumper wire leave it connected ..good luck
Aug 23, 2010 | Heating & Cooling
Just installed a new Honeywell rth2310 thermostat for my rheem rbha-21 and the heater does not start... AC runs fine need help
Do you have 4 wires going to you thermostat and do you have an R and Rh terminal or R and Rc terminal on your new thermostat?
If so then you need to put a jumper wire from R to Rh or R to Rc.
Dec 31, 2009 | Heating & Cooling
My husband just installed the Honeywell RTH2310 thermostat. The fan turns on, but the furnace does not. What's our next step? (It's a natural gas furnace and he made sure that it is on correct h/e setting....
need to make sure there is a jumper between RC and RH if the red wire is connected to the RC terminal the heat wont work you will need a jumper wire to tie the RC and RC together with the red wire.
Oct 20, 2009 | Honeywell Focus 6300B 5-2 Days...
Wiring new RTH2310 DIY Honeywell
sounds like you've got bear wires touching at the new tstat
Sep 18, 2009 | Honeywell Focus 6300B 5-2 Days...
Household Thermostat Replacement
you have to configure the thermostat to run the fan when there is a call for heat. look at the installation instructions and they shoud ask you if it is gas or electric heat if its electric then you are gong to have to configure it to makr e the fan come on with the heat. Good luck
Jan 25, 2009 | Honeywell Electronic Programmable...
Heating & Cooling Logo
352 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
