Question about Maytag 21.6 Cu. Ft. Counter-Depth Side-by-Side Refrigerator - Stainless-Steel
Not making a lot of ice and water not cool have change filter and filter still on
  • 83 Answers
Your freezer is probably too warm- you need to adjust the freezer temperature
Posted on Sep 17, 2010
The ice maker stopped making ice. Any solutions?
A lot of filters ( not all ) do not even access the ice maker . Only the water dispensor . If your water dispensor is working fine , then you need to replace the dual water inlet valve behind the refrig . This is the piece the wall water line connects to . It is called a dual valve because there are 2 coils on the valve . 1 for the ice maker and 1 for the water dispensor .
Oct 23, 2009 | Kenmore Refrigerators
Our Maytag icemaker stopped making ice suddenly after we changed the filter. It dispenses water only.
Does the water have a good flow ? Did you try putting the old filter back in ? Never change the filter just because a little red light comes on . Only replace when the ice cubes get small or the water dispensor flow gets slow . I have found new filters that were bad . Distributors make a lot of money for filters just because of that little red lite . Not just maytag , but all other brands also . Try pouring about 1/2 cup of water into icemaker . If it dumps the cubes but doesn't fill , replace the water valve . If it doesn't dump , and holds the cubes for a long period of time , replace the icemaker . Also , you may need to clean the coils of dust , lint , etc....
Aug 20, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Slow making ice. It is taking forever to fill the ice bin. What can I adjust to make it produce ice faster?
Clean the coils under the ice box so that the flow of air cools the condenser mo propah my amigo.
Jun 14, 2009 | LG LSC26905TT Side by Side Refrigerator
The ice maker stopped workingand the fillter has water in it
bobdmartin
The melt arm must be down to make ice and the freezer must be at least 10 degrees to make ice, as for the water in your filter that happens if the filter is not placed in there right and you might need a new filter in which will make ice, first check the water pressure, how to do that is draw water from the front of your refrigerator if it is bearly flowing the filter has a lot to do with that so go get yourself a new filter at your local hardware store. And see what happens next.
May 20, 2009 | Samsung Refrigerators
I have a side by side Fridiaire FRS6R5ESB. I came
I solved my own problem. Just realized the red & green dots are not lights
The only LIGHT is the top signal light marked " water filter." which is green
when filter is ok & turns red when filter needs changing. The red & green
dots are not lights but are indicators for the water filter light. Red dot meaning
"change filter" and the Green dot means "filter ok"
May 01, 2009 | Frigidaire FRS6R5EMB Side by Side...
Water to water dispenser but no ice. Changed out filter,pump
first off you are going to have to turn down the freezer . Also oyu need to remove the air thats in the line. Then wait for the box to cool down and make ice. Thanks for using FixYa!
Dec 25, 2008 | Whirlpool GS6NBEXR Side by Side...
Filter
Hello culmer4
You wrote, the red filter light comes on but i do not use the water nor do i make ice because it is not connectrd i only yse yhe fridge to cool and freeze things what's my problem?
If you do not have the water connected then the light only went on to remind you to change the filter because of the time that lapsed since you started your fridge.
If you do not use it or need it do not change it and you are okay.
Then it means nothing to you and will not harm anything being lit.You are safe.
So your worries are solved.
Thank You Huuum
Please remember to leave a rating
Oct 25, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker not getting water
check your water valve you have 2 located at lower back of refrig.
Dec 11, 2007 | Whirlpool GD5SHAX Side by Side...
Daewoo refrigerator water filter red light still on after replacing the filter
Press and hold "ICE MAKER LOCK" button, and while holding it shortly press "LOCK" button, and the light will change to green LED.
Ivan
Oct 08, 2007 | Refrigerators
Maytag 21.6 Cu. Ft. Counter-Depth Side-by-Side Refrigerator - Stainless-Steel Logo
47 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
