Question about Car Audio & Video
Need a radio wiring for a 1990 do0dge dakota - Car Audio & Video
  • 625 Answers
Battery red
Accessory red/white
Ground black
Dimmer orange
LF + blue/white
LF - black
RF+ violet
RF- green
LR + black/yellow
LR - gray
RR + blue/white
RR - blue/orange
Posted on Sep 17, 2010
1990 Dakota V6 between 0-6 degrees C. and wet outside, truck doesn't want to start. All other times fine. Where do I start?
I'd try WD-40 on all spark plug wires and system. It helps remove
the moisture that most likely the issue. If it helps, you need new set. Spray inside the distributor cap also.
Feb 13, 2015 | 1990 Dodge Dakota
1990 dodge dakota, dash lights will not work,keeps blowing the fuse
u probaly have the wrong fuse and need a higher amp fuse like 15 or 20 or u have a short u probaly should trace all ur wiring its probaly gone bad. have a profesonal look at it.
Nov 03, 2011 | 1990 Dodge Dakota
Spark plug wire diagram on a 1990 dodge dakota
Check this for 1990 Dodge Dakota 3.9 liter V-6 VIN "X"
Hope this helps (remember to rating this free answer).
Oct 04, 2011 | 1990 Dodge Dakota
Radio screen is blank and no sounds come out of the speakers, but the radio numbers and letters come on when I turn on the lights
Hi, run a new wire from the hot buss of the fuse panel to the pink wire behind the radio. Cut the pink wire and tape it off. Let me know if this doesn't fix the problem or if you have any questions.
Jul 19, 2011 | 1990 Dodge Dakota
I HAVE A 1990 TOYOTA CAMRY AND I NEED A WIRING DIAGRAM FOR RADIO INSTALLATION.
does this help, or do you need more?
1990 Toyota Camry Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Blue/Yellow
Radio Switched 12V+ Wire: Gray
Radio Ground Wire: Brown
Radio Illumination Wire: Green
Radio Dimmer Wire: N/A
Radio Power Antenna Trigger Wire: Black/Red
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 3 1/2?
Front Speakers Location: Dash
Left Front Speaker Wire (+): Pink
Left Front Speaker Wire (-): Purple
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Blue
Rear Speakers Size: 5 1/4?
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Black
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Red
Right Rear Speaker Wire (-): White
Oct 17, 2010 | 1990 Toyota Camry
Fan switch broken, does dash need to come off, 90' dodge dakota
The bezel surround for the gauges and dash center (radio area) need to be removed to gain access to remove the switch. Should be about 10 torx screws and then pull straight out.
Should pull out easily when all screws are removed.
Nov 25, 2009 | 1990 Dodge Dakota
Wiring color codes for stereo system in a 1990 dakota
Dodge Dakota http://www.installdr.com/Harnesses/DCP-Wiring.pdf
1991 Chevy Cavalier http://www.installdr.com/Harnesses/GM-Wiring.pdf
Here is a link that should help you get your radio wired up again, good luck.
Jul 29, 2009 | 1990 Dodge Dakota
1990 Dodge Dakota Will not charge
the computer acts as a voltage regulator. it may be going bad
Nov 18, 2008 | 1990 Dodge Dakota
Clock radio 1990 doge dakota
you will need to use a pen or something small enough to insert in the two holes located by the clock to set the hour and minute.
Sep 16, 2008 | 1990 Dodge Dakota
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
