Question about LG VX5500 Cell Phone
Phone says incorrect software powering off when i put the battery in
White screen 8530
Have you tried a reset or a reboot? Try these steps:
1. Power off the cell phone by holding down the power button for at least 5 seconds. The screen should turn black. Now, let go of the button and press it again until the screen lights up again.
2. If the screen is still white while holding down the power button, open up the back of the cell phone and remove the battery. Wait for 30 seconds before putting the battery back in, to allow the software to reset itself. Put the battery back in and press the power button until the screen lights up again.
3. If you removed the battery and you still have a white screen, you may have a software issue. Go to a local cell phone repair company and have it replaced or fixed.
Apr 18, 2012 | RIM Blackberry Curve 8520
Okay, I have a Samsung Seek on the sprint service. Recently when I've been charging my phone, I get this message that says Wrong Battery. Powering Down. I don't know what to do to fix it. ...
This issue might due to some incorrect setting on your phone. Youve done the right alternative option by restarting your phone and taking the battery in and out. You need to contact samsung technical support so they can help you. Please see below SAMSUNG technical support number:
Mobile phones 1-888-987-HELP(4357)
Mon - Fri : 7am - 9pm (CST)
Sat : 9am - 6pm (CST)
Thank you for using fixya
Please rate me and give testimonials if ever to continue my assistance
Jun 02, 2011 | Cell Phones
What do i do if my phone says puk on the screen and only sos ?
PUK stands for Personal Unblocking Key. This is a uniqueeight-digit code specific to your SIM card. This is required when the PINnumber to unlock your mobile phone is entered incorrectly 3 times. You are thengiven 10 attempts to enter your PUK code. If an incorrect PUK code is enteredafter the 10th attempt, you will block your SIM card permanently and willrequire a new SIM card from your mobile phone provider.
PUK codes can be obtained through the following ways - The PUK code is in your SIM card documentation Starter Pack.If you do not have this then -Please contact your phone service provider.
Your cell phone service provider can give you the PUK code once you give themyour account details and they have confirmed your identity.
Mar 20, 2011 | Samsung B3410 Cell Phone
I have an Apple iPhone 3GS with the 4.1 software. The iPhone keeps switching itself off. I would lock the screen and want to unlock it a couple of minutes later and then it is switched off. The battery...
Software glitch or battery issue. Backup and save all your data and music. Then reboot and re-update the software. If that still don't fix it, then you got a problem with your battery power management. The system thinks the battery is low and automatically shuts off to preserve the contents. Try charging battery fully overnight with the power off and see if that helps. If not, then you will have to see the Apple dorks at the Apple store for a replacement phone. Cheers.
Nov 12, 2010 | Apple iPhone Smartphone
During a software update connection was lost and my phone is not coming on
open software update programme.
remove battery of phone.
connect the USB again, put the battery and connect the charger.
then press power key for a second (even if you dont see anything) then connect to software update and try again!
Aug 27, 2009 | Nokia E50
I put a code on black berry storm and i z=went to
I think that putting different incorrect codes must have completely locked your phone for security reasons. You have to thus change your software and get a new one for your phone. Thank You.
Aug 14, 2009 | Cell Phones
After resetting and downloading software for my sony ericsson w580i it shows now incorrect smartchip. I put in the normal chip i was ussing but still it says incorrect smart chip.?????
This means your phone is locked to some network you have previously used( Means u can't use other SIM Card unless ur phone is UNLOCKED) n r u having any contract with any network???
- Nicky
Jul 13, 2009 | Ericsson Cell Phones
Invalid battery
Pull out the battery *while the phone is on*. Wait 15 secs then put battery back in and turn phone on. That should fix it.
Nov 13, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Display screen says "invalid battery" All works fine, what does that mean?
your battery may be putting off an incorrect amount of voltage to the phone, and powering it on (yes) but frying it internally (no!)
Meaning, the battery may make it work, but it is not good for the phone.
NGK
Nov 03, 2008 | Motorola Mobility TracFone® V170 Cellular...
LG VX5500 Cell Phone Logo
262 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
