Question about Miele Novotronic T1515A Electric Dryer
Miele T1515 - has started to make my laundry room feel like a sauna - why?
  • 32 Answers
Check the exhaust hose. it sounds like it has separated from the outlet and is spilling the hot exhaust into the room rather than through the vent outside
Posted on Sep 17, 2010
Heilsa Pellet Stove Manufacturers Information
pellet stove tp440 Pool & Spa Heaters Questions & Answers ...
www.fixya.com > Forum > Tags > pellet stove tp440
Pool & Spa Heaters pellet stove tp440 questions and answers. ... for a manual orinformation on this stove it is an older stove we just don't know how old. ... heilsa pellet stove model qcps-28000 my pellet stove is smoking how to change ...
General Infrared Sauna Heilsa Sauna Supplier, Find Best ...
www.alibaba.com/general-infrared-sauna-heilsa-sauna-suppliers.html
Suppliers who can match your search. .... Outdoor Spa,Sauna Room,Jacuzzi,Swimming Pool,Sand Filter .... Infrared sauna room,Portable steam sauna,Infraredheater,Pellet stove,Clothes dryer ..... updates on topics such as trending hot products, buying requests and supplier information - sent directly to your email inbox!
Good Quality Far Infrared Sauna Supplier, Find Best Good ...
www.alibaba.com/good-quality-far-infrared-sauna-suppliers.html
Suppliers > .... Outdoor Spa,Sauna Room,Jacuzzi,Swimming Pool,Sand Filter ...Infrared sauna room,Portable steam sauna,Infrared heater,Pellet stove,Clothes dryer ...compare heilsa infrared sauna with good infrared sauna accessories ..... buying requests and supplier information - sent directly to your email inbox!
Jan 06, 2016 | Pool & Spa
Can I wire my Miele W1918 washing Machine to work on 120 . And if not can you walk me through wire set up.
if the machine is 240 volt system and the mains voltage is 110 volts you can use a step up transformer
Dec 25, 2014 | Miele Washing Machines
Sauna wont get hot enough
When I'm in a traditional sauna like this, I expect the temperature to be between 70 and 90C so that's what I assume you are trying to reach. There could be several reasons for this so make sure each point is checked:
1. Stating the obvious, to increase the temperature inside the sauna, you'll have to ladle water onto the hot sauna stones.
2. Maybe the insulation within your sauna isn't good enough and heat is escaping.
3. Your sauna room could be too big for this heater to heat properly.
4. Maybe the element on the heater isn't performing properly and needs to be replaced.
These were some pointers which Di Vapor gave as possible reasons for lack of heat.
Sauna Electric Heaters Spares
Feb 15, 2014 | Amerec 4.5KW Heater w/ Built-in Dial...
Needing to move sauna
go get two furniture carts put one under each end(after emptying the tub) you cn raise the tub with blocks and a 5 foot long 2x6..raise the tub until the cart fits under it..do the other end the same way..then it should roll..be sure the new outlet is heavy enogh to run the tub or it will burn it up..
Jan 05, 2014 | Golden Designs Pool & Spa
What is a sauna?
"A sauna is a small room or house designed as a place to experience dry or wet heat sessions, or an establishment with one or more of these and auxiliary facilities.
A sauna session can be a social affair in which the participants disrobe and sit or recline in temperatures typically between 70 degrees C (158 degrees F) and 100 degrees C (212 degrees F). This induces relaxation and promotes sweating.
Saunas can be divided into two basic styles: conventional saunas that warm the air or infrared saunas that warm objects. Infrared saunas may use various materials in their heating area such as charcoal, active carbon fibers, and other materials."
Oct 03, 2013 | Pool & Spa
Miele T1515 electric dryer - overheats and laundry room feels like a sauna. What can I do about it?
is your dryer vented to the outside? Check the exhaust vent to be sure it is still attached to the duct and not plugged with lint
Sep 17, 2010 | Miele Dryers
How do you remove the top of the Miele T1515 vented dryer?
hi,
on each side of the lid at the front there is a plastic white cover. remove this with your fingers or a small knife. then using a T20 screw driver unscrew each screw a few turns and then push the screw heads in with your finger. do not unscrew the screws too far or remove them.
last push the lid back a few inches and it will lift off. once off you will see the locking clips that you just unscrewed which hold the lid down. when re-fitting the lid do the reverse and just tighten up the screws.
Apr 12, 2010 | Miele Novotronic T220 Electric Dryer
Moved our miele washer to our new laundry room and now will not turn on, there is power to the machine. We moved it with care.
Dear sarnt,
ngfam at you service!
Balance weight could be out of position! Like in the neptune!
When you get an error its best to call service
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
PS.Before you sign off!
PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM
Aug 25, 2008 | Miele Washing Machines
Miele Novotronic T1515A Electric Dryer Logo
131 people viewed this question
Top Miele Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Are you a Miele Dryer Expert? Answer questions, earn points and help others
