Question about Frigidaire GLGR341AS Gas Dryer
For frigidaire dryer GLGR341AS1 how do you fix belt?
    Master:
    Sergeant:
  • 449 Answers
You have to tear down the unit and replace the broken one not a job for novices
Posted on Sep 17, 2010
My Frigidaire gallery dryer stopped working it will buzz when I turn the starter knob but never starts nor does the drum turn ,then I smell a burning smell
if you can hear the motor running then probably the belt is either too loose and/or broken (you may hear a rubbing or squeeling sound).....if you cant hear the motor running then it may be burned out....a very acidy smell.
Either problem requires taking the dryer apart to fix (new belt or new motor)
May 03, 2016 | Frigidaire Dryers
I have a squeaky dryer
You have a belt that goes around the barrell and the belt has a tension pulley on a tension arm. Those pulleys go bad. It is an easy fix. It takes longer to get to the pulley than to fix it. It is a 4 minute fix, but it will take a while to take off the housing to get there.
May 08, 2015 | Frigidaire FER641FS Electric Dryer
Where is the belt on the Frigidaire electric dryer?
This dryer is a frigidaire electric dryer. In this video I show the belt location. It mounts around the drum. You must remove the front panel to replace it:
Aug 07, 2012 | Frigidaire Dryers
Hi. I need help for replacing my dryer belt on a frigidaire mex731cfs. Please provide me with a step by step process, preferably with diagrams & pictures. Thanks!
http://www.ehow.com/how_6103112_replace-belt-frigidaire-dryer.html
here is a belt configuration:
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
Mar 30, 2011 | Dryers
My frigidaire dryer glgr331as4 is not spinning
Hi there
i read your report. OK try this tip. Open your dryer and spin it with your hand and its spins freely with no resistance then it's your belt is bad. Try this and let me know how it goes. Ty for writing to fix ya.
Best Regards Richard
Dec 03, 2009 | Frigidaire GLGR331A Gas Dryer
Need belt for stackable frigidaire washer and dryer. Model is FEX831CS The washer jerked and threw a breaker. Now the dryer won't work and the washer lets water run in and the inside starts jerking hard
If you think that the washing machine belt is the cause of your troubles you can find it in the very bottom of the machine (behind the front panel)
Would need more info on the dryer problem, (Is it running with no heat or not running at all)
the washer drive belt is the only easy fix on this model.
Good Luck
Quentin
Aug 21, 2009 | Frigidaire FEX831CS Top Load Stacked...
Dryer drum spins but no heat
These units have a limit switch is located near the burner compartment. It is about the size of a dime or penny with 2 wires going to it. In between the wires, there is a small button that you can depress firmly. This should reset the limit. If it trips again, you will need to replace the limit switch. Hope this helps.
Apr 11, 2009 | Frigidaire Dryers
I HAVE A FRIDIDAIR GLGR341AS1 MODEL DRYER. HAD SOME THIMPING IN THE DRUM AREA. TOOK OFF THE DRYER FACE AND NOW CANNOT GET IT BACK ON. THE CLIPS ON THE BOTTOM SEEM TO NOT SET CORRECTLY. ANY SUGGESTIONS ON...
have to set the bottom first then lift drum to clear felt on front panel make sure the tabs on the fornt bottom corners are not bent or broken they should be up at an angle
Feb 22, 2009 | Frigidaire GLGR341AS Gas Dryer
My front load frigidaire dryer stopped going around and around.
call someone in to fix it...it will be easier and the belt can be a pain to put on again.
Jan 07, 2009 | Frigidaire FGQ332ES Gas Dryer
Our Frigidaire GLGR341AS1 Does Not Start
see if you can turn the drum my hand... Makeing sure nothing is stuck in blower fan... if you can... sounds like motor my be bad
Oct 13, 2007 | Frigidaire GLGR341AS Gas Dryer
Frigidaire GLGR341AS Gas Dryer Logo
75 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
