Question about Fargo DTC515 Thermal Printer
White line when printing
When the card comes out of the printer, it has two white lines on it that deface the picture.
  • 300 Answers
Try cleaning the printhead
Posted on May 17, 2008
White Lines over Black Colour?
MAKE PRINT ALIGNMENT
IF THE PROBLEM PRESENTS
FALLOW LINK
PIXMA MG5250
May 07, 2014 | Canon MG5250 Printer
My datacard group SP75 color is printing cards with a white line all across it_
First, try to determine if it is printing a white line, or if an obstruction is possibly scratching the card surface; if it is an actual white line, then you probably have a pixel out in your printhead. Your printhead must be replaced.
Apr 15, 2010 | Datacard Group SP75 Color Card Printer
Edge to edge print problem
The Fargo DTC550 will not be able to print an "over the edge" card. Any Direct To Card printers will have a white line on the edges. There are several printers that are able to print covering the entire card, those printers are called Reverse Transfer or Fargo's High Definition Printers. One printer that I do recommend is the Fargo HDP5000, you can read more about it at: http://printers.idcardgroup.com/productdetails.aspx?item=hdp5000
Apr 22, 2009 | Fargo DTC550 Thermal Card Printer
White vertical line in image printing
how can we take all fax sent and received print from hp 3050 printer.
Apr 01, 2009 | Epson Aculaser C1100 Printer
Fargo P C30
you probably have a scratch on the printhead.
Mar 14, 2009 | Fargo Persona C30 Thermal Card Printer
While printing photos my printer has white vertical lines
Sounds like you need to re-align the print cartridge . The reason the text comes out ok is probably because it is only using the black cartridge for text. The color cartridge is the one that's out of alignment. You may have some sort of Cannon utility running in the task bar that will allow you to easily allign the print cartridges. If not, go to the main "Printers and Faxes" window, RIGHT-click on the printer and select "Properties". You should be able to find a button in the properties that's labeled something like re-align print cartridges. It will print out a series of test pages and ask you to select the set of lines that looks the straightest and type it in. It's a good idea to do this every time you replace a cartrige. Hope this helps, If I was able to FixYa, please remember to rate me. Thanks.
Feb 22, 2009 | Canon MultiPASS F50 All-In-One InkJet...
Hp photosmart 7960
For Photosmart 7960...
Hit MENU
Select "TOOLS" by hitting OK
Select "Clean Cartridges" by hitting OK
Carefully review printed output for white lines on printed areas
If white lines appear:
Select "SECOND level cleaning" by hitting OK
Select "THIRD level cleaning" by hitting OK.
Jan 17, 2008 | HP PhotoSmart 7960 InkJet Printer
Faint white line observed on print
nope, the TONER OR INK CARTRIGE is running out in tat area, so you have to check it so that there is a new one. hope this helps. :)
Dec 08, 2007 | Minolta magicolor 2350 Laser Printer
White Line on Card
unfortunatly is sounds like a "print head" type of problem. By printhead I am refering to the assembly that causes the film to transfer to the card. I would suggest creating a card project that has a full photo as the background. This will show you if the streak runs the length of the card. It could just be dirt or an obstruction in the card path. Try the alcohol cleaning cards. Dissassembly of this printer is a crap shoot. I have done it once. It is one of those things that is best left to someone good at printers or best by someone experienced on these. if all else fails call a dealer like Datacard and ask about depot repair.
Sep 12, 2007 | Fargo DTC510 Card Printer
Fargo DTC515 Thermal Printer Logo
152 people viewed this question
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
