Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Broken white lines across screen - Mitsubishi WD-52525 52" Rear Projection HDTV
Clean the dirt off the boards most likely cig smoke and it will react to the dust to become conductive enough to cause problems with the tv
Posted on Feb 10, 2011
Thin white line across laptop screen
check lcd display data cable if cable is fine problem in display unit
Apr 27, 2014 | Computers & Internet
Blue line across screen, not white
the lcd panels was broken,or the polarizer was broken,
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Feb 26, 2014 | Sanyo Office Equipment & Supplies
How do I Fix LCD White Screen?
If you see "fractured lines" across the screen, it would appear that your LCD screen is broken. That's the only way these kinds of lines appear.
You need to replace the screen.
May 14, 2012 | Computers & Internet
White flickering line across top of screen
Set the screen format using your TV's menu. Do not set the format of the screen using your provider's receiver. I had this prob with a few channels with a dish provider when I set the format with the remote from the dish provider. I picked up the TV's remote, went into the menu, set the format, problem fixed.
May 15, 2010 | Vizio GV42L 42 in. LCD Television
SAmsung has two white lines across screen with no picture
If the 2 white lines are in the centre of the screen it sounds like you have a fault called 'field collapse' . The 'x' or horizontal circuit on the tv deflects the beam across the screen which in your case is ok because the line runs across the screen ok. The 'y' or field circuit on the tv deflects the beam down the screen. Without a circuit diagram for your tv i cannot point to individual components.
Aug 07, 2009 | Samsung Televison & Video
Samsung LN-S4692D - Vertical lines (>15) & static on screen
this sounds like a scan board gone ,, if you check ebay youll see two things,
1, other tvs for sale with the same fault (It might give you a clue to the fault ie , which board )
2, the same tv as yours with a broken screen ,
i dont know how good you are with taking things to bits but i personally would buy the tv with the broken screen and start swapping over the internal boards ?
Have you checked your home insurance policy for broken tv,s
it may have fell of its stand when you were'nt looking?
May 16, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
Horizontal white lines across top of TV screen
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
White horizontal, zig-zagging lines
Sounds like the flyback transformer is bad. couple of 100 dollars if it is that
Dec 03, 2007 | Televison & Video
Picture faded with white broken lines
Hi, the problems you describe are indeed related... the cable that carries the data from the lower section (mainboard) to the top screen is also responsible for the sound and the speakers are connected to this cable near the top LCD screen. It sounds like the cable has become damaged and will need replacing which unfortunatley means a new top screen due to the way the cable is connected to the screen. I come across this problem frequently and I charge customers £35 for a replacement screen and fitting.
Sep 01, 2007 | Nintendo DS Lite Console
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
