Question about GE Profile PFSF6PK Bottom Freezer French Door Refrigerator
The push and hold did not work for me. Still Fridge and Freezer displays 88 degrees. Another web forum said it maybe the motherboard.
  • GE Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then checkout the last two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 17, 2010
KBFA20ER Turns Off
Holding fridge door open allow warm air into fridge/freezer that's why temp is going up .Maybe you device have a temp cutout which in your case 46 degrees.
It is like a energy saving
Jun 01, 2017 | KitchenAid KBFA20ER Bottom Freezer French...
Samsung side by side RFG297AAWP display shows 88 88
Press and hold the energy saver button, and the lighting button at the same time until it beeps and clears, 10 seconds. When it goes back to normal panel do the same thing again which will put the fridge in a running diagnosis mode and see if any parts of the 8's are flashing, if so look on the back of the fridge at the error codes.
Nov 24, 2011 | Samsung RFG297AAWP Side by Side Bottom...
I have a Samsung RF268ABRS Unit all food in bottom freezer thawed. Unit is running and ref is cool. I notice that the fan dosent seem to blow. Closed freezer up and its cold, but no air moving. How do...
I had a similar problem. my samsung freezer would only cool to 20 degrees, which also resulted in the freezer ice maker not functioning. (fridge door ice maker still worked) If you hold the power freeze and power cool buttons down together for 8 seconds it will a diagnostic. found the answers on http://appliancejunk.com/forums/index.php?topic=8206.0 , as too what the codes meant. Mine was throwing a freezer fan code error. ordered one online $30 and replaced it. seems to be working. TIP -The fan is located behing the rear panel in the freezer. I had two fans. The regular looking one is the freezer fan, the squirrel cage fan feeds the fridge ice maker. Also the new fan motors don't come with blades, just pull the blades off the old one and put it on the new motor. Don't push it on too far, make sure there is enough clearance so it spins freely.
Jun 28, 2011 | Samsung RF267AB (25.5 cu. ft.)...
My digital display reads 88 degrees for the fridge and the freezer. The 88 display on the right is flashing. None of the buttons work when pressed.
reads 88 deg/ ok is frig that warm also .. if so replace the p c control as it has gone bad . in some models they call it a jazz board . / there is a update and it works much better .. mm
Dec 23, 2009 | Samsung RF265AA Bottom Freezer French Door...
Control panel not working Samsung refrigerator model rs2533sw. Not cooling.
I have a samsung refrigertor rs2555sl and my control panel stopped working after I turned the power off to the house (to install a light fixture elsewhere). There was one green light blinking on the refrigerator temp display.
Hold down the "power freeze" and "power cool" buttons at the same time for at least 8 seconds. This is a self diagnostic program. A number should appear on the refrigerator temp display (1-9)...it will hold for 30 seconds and then the panel should function again.
In my case the number that appeared was "3" which can indicate a multitude of things including a short circuit or power outage (which was it was for me).
Hope this helps!
Apr 02, 2009 | Samsung Refrigerators
Fridge and freezer not cooling down
It seems it's the defrost sensor (freezer side). Waiting for it to come, ordered this morning. It appears to be a defrost fault, having read on the web it seems you can check the defrost sensor with a meter across whilst holding the actual sensor in your hand tightly to see if the resistance changes, anyway it didn't. Will post when the new one comes and I change it.
Sep 12, 2008 | Samsung Refrigerators
New GE profile refrigerator bottom freezer model pfss6pkwass. Will not run, stuck in display mode. Lights are on but when setting temp on panel it goes back to off after a few seconds. After spending...
Ok, I had the same problem with this fridge. It is in "demo" mode. You have to push in and hold the Energy Save and Adjust Freezer buttons at the same time. Hold these in until the display starts flashing. You should hear the compressor kick on. I did this, and it was fixed and started cooling in a matter of seconds.
Aug 13, 2008 | Refrigerators
GE Profile PFSF6PK Bottom Freezer French Door Refrigerator Logo
105 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
