Question about Toshiba Satellite A135-S2276 Notebook
Drivers had code 39 on my driver uninstalled and reinstalled now have a code 19
  • 3,940 Answers
Normally, these steps will resolve.
http://support.microsoft.com/kb/270008
Posted on May 17, 2008
It gives code 10 error. device can not start
HI
A Code 10 error is generated whenDevice Manager can't start the hardwaredevice, a situation usually caused byoutdated or corrupted driver A device mayalso receive a Code 10error if a driver generates an error that Device Managerdoesn't understand. Inother words, a Code 10 error can sometimes be a verygeneric message indicatingsome kind of unspecified driver or hardware problem.Uninstalling and then reinstalling the drivers for the device is alikelysolution to a Code 10 error. If reinstalling driver is not working than try torollback the driveror restore the system on previous date..
regards
sandy fixya
Jul 18, 2011 | Lexmark International Lexmark X422
My CD Drive is no longer working it says code 39. I also tried my external DVD drive it says code 39 as well. How do I fix this?
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
Oct 21, 2010 | Compaq (120192-B21) CD-ROM Drive
Code 19
Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. To fix this problem you should uninstall and then reinstall the hardware device. (Code 19)
Try these options:
•Click Uninstall, and then click Scan for hardware changes to load a usable driver.
•Restart the computer in Safe Mode, and then select Last Known Good Configuration. This rolls back to the most recent successful registry configuration.
Hope it helps.
Jul 10, 2010 | Microsoft Windows Vista Ultimate Edition
I have HP Pavilion 9500,Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19)
Code 19 Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. To fix this problem you can first try running a Troubleshooting Wizard. If that does not work, you should uninstall and then reinstall the hardware device. (Code 19) Recommended resolutions
A registry problem was detected.
This can occur when more than one service is defined for a device, if there is a failure opening the service subkey, or if the driver name cannot be obtained from the service subkey. Here are some things that you can try to resolve this problem.
Uninstall and reinstall the driver
Uninstall the driver from Device Manager and scan for new hardware to install the driver again.
You may be prompted to provide the path of the driver. Windows may have the driver built-in, or may still have the driver files installed from the last time that you set up the device. However, sometimes, it will open the New Hardware Wizard which may ask for the driver. If you are asked for the driver and you do not have it, you can try to download the latest driver from the hardware vendor’s Web site.
  1. On the device Properties dialog box, click the Driver tab, and then click Uninstall. Follow the instructions.
  2. Restart your computer.
  3. Open Device Manager, click Action, and then click Scan for hardware changes. Follow the instructions.
Revert to the most recent successful registry configuration
This content is designed for an advanced computer user.
The Last Known Good Configuration feature is a recovery option that you can use to start your computer by using the most recent settings that worked. The Last Known Good Configuration feature restores all the registry information and driver settings that were in effect the last time that the computer started successfully.
For more information about the Last Known Good Configuration feature, click the following article number to view the article in the Microsoft Knowledge Base: 307852 (http://support.microsoft.com/kb/307852/ ) How to start your computer by using the Last Known Good Configuration feature in Windows XP Edit the registry
As a last resort, you can edit the registry directly. For more information, see the Registry Reference in the Microsoft Windows 2000 Server Resource Kit at the following Microsoft Web site: http://www.microsoft.com/technet/prodtechnol/windows2000serv/reskit/default.mspx?mfr=true (http://www.microsoft.com/technet/prodtechnol/windows2000serv/reskit/default.mspx?mfr=true) The registry information applies to Windows XP
hope this helps
please leave feedback
thanks
Robb
Apr 21, 2010 | Computers & Internet
My computer keeps showing a code 19 everytime i tried to install a driver for my cd drive hl-dt-st dvdram gsa-t20n ata device. i recently installed norton and since then i cant load or run any cd's
before you do all this i suggest you try going to start and running system restore under start programs accessiories system tools - system restore and restore to a previous point when you were not having these problems... if that don't work try the next best thing
First uninstall Norton from your add remove programs in your controlpannel
Download the norton removal tool from there site
Here Run the uninstall tool.. then uninstall any drivers that you have for your cd drive then try reinstalling the cd driver once you have everything working reinstall norton
Dec 08, 2009 | Acer Aspire 5315 Notebook
Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) Laptop Levono y530, device dvd rw optiarc AD-7580s I tried to uninstall & reinstall it, but...
Give this a whirl:
CD-Rom stops working. After checking device manager you find an exclamation mark on the drive. It doesn't mean the drive is dead. It could be an upperfilter or lowerfilter registry issue that is keeping you from accessing the cd drive.
This fix worked for my client:
http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
Also, try this fix from microsoft.
CD-ROM access is missing and messages cite error code 31, code 32, code 19, code 39, or code 41.
Try this before replacing the drive and remember that you may have to reinstall some burning software.
Oct 16, 2009 | Lenovo IdeaPad Y530-5243U
Code 39
hi,
error code 39 stand for (Windows cannot load the device driver for this hardware. The driver may be corrupted or missing.)
Reason
There are several causes of Code 39 errors:
  • A required device driver is missing.
  • A required binary file is corrupted.
  • There is a problem with the file I/O process.
  • A driver that is referencing an entry point in another binary file is unable to load.
Reinstall the drivers for this device.
Uninstall the driver from Device Manager, and then scan for new hardware to install the driver again.
Sep 26, 2009 | Computers & Internet
Error code 39,while installing wireless network adapter.
Code 39 means there is problem loading the driver, so make sure you have the right drivers and install them.
Might be best to uninstall the current drivers and the reinstall the new drivers.
Apr 09, 2009 | Acer Aspire 4315 Notebook
My comp says code 39 can you help
Code 39 Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)Cause
I am sending you a copy of this information in the hopes that it will be of some help in your situation.
Cheers!
Ron.
Dec 16, 2008 | Computers & Internet
Toshiba Satellite A135-S2276 Notebook Logo
20 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
