Question about Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed
Dies when clutch disengaged - Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed
Theres something under your seat the seat has to be positioned right in order for it to continue running adjust your seat
Posted on Oct 05, 2010
Idle and clutch issue
main jet blocked and clutch damage maybe bent clutch push rod or plates seized together
Feb 19, 2013 | 1991 Yamaha FZR 1000
What's your problem?1995 yamaha virago 1100 that sometimes you you put into gear and immediately dies
The Clutch on some bikes will disengage the starter motor. Yamaha will not allow you to engage gear when the side stand is down. Hope this gives you some idea
Nov 27, 2011 | Yamaha Motorcycles
When holding clutch and putting into first gear, completely dies
whats happening is your clutch plates are sticking together. try tightening up the clutch cable a bit. im not sure if it is cable, it may be hydraulic? if it is, then bleed the clutch to get any air out of the system. if that doesnt work, then try an oil change. sometimes old, thick oil wont let the clutch plates seperate, and you get that jerking when your engine is cold. use a light oil. maybe 5-30 or 10-30. a light oil will make it easier for the clutch to disengage.
Aug 09, 2009 | 1994 Suzuki GSX 600 F (Katana)
It sounds like the seat switch is disconnected or failed. Check it out. If it thinks there is no **** on the seat it will cause your symptoms.
May 25, 2009 | John Deere Garden
I have 2003 kawasaki kx 125 when you put it in gear with clutch in it jumps forward and dies. where do i start with this?
make sure clutch ,is disengaging properly when you pull in clutch lever,adjust lever until you have about 1/8" freeplay.if still not disengaging, you need to drain gearbox oil, take clutch cover off & inspect clutch pack, you may have friction plates sticking together.
Feb 18, 2009 | 2003 kawasaki KX 125
1100 wierd clutch disengage problem
Bleed your slave cylinder on the sprocket cover and refill the hydraulic fluid. If you have any leaks you will get air in the system and it will not fully disengage the clutch. As for the 750, they have cable clutches and you just need to adjust the slack of the cable.
Nov 20, 2008 | 1992 Suzuki GSX 1100 GN
Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed Logo
41 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
