Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
I have a frigidaire refirgerator, side by side door. The ice dispesor is still working. but teh water dispensor is slowing down. I have changed the filters and this problem seems to keep getting worse. What could teh problem be.
  • 83 Answers
The water line is probably plugging with sediment. Even with the filter this can happen. Check the line to the water dispenser
Posted on Sep 17, 2010
I have a Frigidaire Gallery French Door (bottom drawer freezer) with a Water/Ice Dispensor in the door. The Ice dispensor works intermittantly. The Ice chute door always clicks open but sometimes it...
Cold is not the problem. The board or the wiring going to the board is defective or just has a bad connection. Because it worked while you held the board a certian way points to a break at the plug going to the board or a break on the board, Sea Breeze
Sep 25, 2013 | Frigidaire FRS23KR4AW Side by Side...
Frigidaire GLTF2940ES0 front load washer. turn it on and the water fills for 1-2 sec then turns off. replaced pressure switch and control panel. still does the same thing. someone mentioned the door...
does it ever agitate ... if it does than the door is locked ...there is a magnet that falls off these machines the detergent dispensor that tell the washer control board that the detergent dispensor is closed so water wont spray out if left open ,,,,magnet rectangle and size of a pencil rectangle shape .... you can try putting a large size magnet on the opening of dispesor shroud ,,,, usually when you replace the control board they have removed the magnetic dispensor reed switch and just jumped across the board eleminating this connection.
Jan 31, 2011 | Frigidaire Washing Machines
Not making ice
Hi: Change or just remove the water filter first. As your water dispensing slowed that is a clue. If the water filter is that clogged it will cause a problem with the ice maker. Plus the water you drink is not filtered anymore. City water is being run through 2 years of crud. If you don't replace it just remove it. I hope this helps, Jeff
Jun 03, 2009 | Frigidaire FRS3R5EMB Side by Side...
FRS26ZSH Water Dispensor Not Working
I have a GE 2005 Side by Side Refrigerator. Model GSS25JERF, Serial # FH242429. I get all kinds of Ice but no water. I replaced the water valve (p/n WR57X10050) and the Dispenser Display, 4 button ( p/n WR55x10443) Still no water dispensing from the water valve. What next ?????
Feb 28, 2009 | Frigidaire GLRS264ZA Side by Side...
GE side by side refrigerator: water/ice dispensor
I bought a brand new smartwater replacement filter and after a very short time, my water stopped coming through the door.. took out the new replacement filter and inserted a brand new one .. problem solved.. apparently some of the g.e. smartwater filter replacement cartridges don't have the high enough two plastic inserts which are attached to them at the top of the filter when you screw them on... if you have taken your cartridge in and out a few times, i think it wears down the plastic so it doesn't fit properly and won't put up whatever it is supposed to push up to make the water come through.. I personally think this is a g.e. problem with the replacement filters...
Jan 31, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice and Water dispenser
no manulal reset or fuse, buth tere is ususlly a "child lockout" feature prevent ing the dispensor from operating. check to see if the control has been placed, on, or perhaps the door is not closing fully, another reasom for the dispensor to stop
Jan 17, 2009 | Frigidaire FRS26R4A Side by Side...
Water dipenser broke
drip tray pulls foward (might take some serious finger strength but itll pull foward, revealling 2 phillips screws that will release the dispensor facade. before attempting i would unplug the harness atop the freezer door, you dont want to short circuit boards behind dispensor.
Oct 19, 2008 | Frigidaire FSC23F7DSB Stainless Steel Side...
Water dispensor does not dispense water. Ice maker works.
you have prime the system air out of the water lines this is easy to do
put a glass big enough to cover water dispensor outlet cause its going to project water out at you press and hold button till water starts to run smooth
these fridges will spit water at you when you prime the system at first cause theres air blockage in lines
May 20, 2008 | Frigidaire FRS3R5EMB Side by Side...
FRS6L7EES1
I am service tech. Try and replace the diode in the water valve connection. Part number 5303918287. This is a diode kit for the Frigidaire ref., instructions are in the package. This part regulates the water valve to make sure that water comes out the specific port in the valve.
Mar 15, 2008 | Refrigerators
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
527 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
