Question about General Electric Adora GHDA670N Built-in Dishwasher
How do I turn off my GE QuietPower3 dishwasher once I have turned it on? I opened the door, the lights are going on and it beeps periodically. Tried pressing the start button and holding it for 5 seconds--that didn't work.
  • 83 Answers
If you just want to shut it off, press the cancel button twice--If you press it once it will drain before shutting off
Posted on Sep 17, 2010
We have a whirlpool ADG 7800 dishwasher ,getting a beeping sound and start button flashes 12 times? Any help
Hi
Ok try this and see what happens.
Hold the start button again till it beeps
Then select the first cycle on the left which should be the rinse cycle
Then turn the dishwasher off
Then press and hold the start button and with this held in turn the dishwasher on.
Once the start light is flashing let go
Now press the start button once and close the door.
Now it will run a 12 minute test cycle. If it goes wrong it will drain the water out and beep. So open the door and count the number of flashes from the start light inbetween the pause and let me know.
Regards
Oct 11, 2014 | Whirlpool Dishwashers
Dishwasher turns itself on and beeps periodically but does not start
Seems to be a faulty door latch...it wants to start but the computer thinks the door is still open and wont allowing it to continue, thus turning off. Try playing with the door latch before opening it up and looking within the latch.
Dec 02, 2013 | LG Dishwashers
I have a GE QuietPower2 (Model GLD5800L00BB) and the lights are blinking and there is a beep about once every 60-90 seconds or so. I have reset the circuit breaker but when I turn it back on, same issue. ...
This model has a known problem with the door switches. There are two switches and they both need to work right, otherwise the panel switches will not work right. Turn off power before working on the switches. They both have to open circuit when the door is open and the both have to close when the door closes. I had to put in some small spacers behind them to get them working right.
Nov 28, 2009 | General Electric Adora GHDA670N Built-in...
GE profile PDW9880J00SS dishwasher just beeps
appears control is going bad,or problem with control circut
Oct 16, 2009 | GE 24 in. Profile PDW9280JSS Built-in...
I have a GE QuietPower3 dishwasher... the normal wash, heated dry, hot wash and hot start buttons are all flashing... can you tell me what is going on please?
try this, I was researching and found that this solution worked. While all the lights are blinking, close the dishwasher door and let the machine run through the cycles. This actually happens pretty fast. Then it will stop and quiet down and all the blinking lights will shut off. Then just press the buttons you want and hit start and the machine will start. The time it takes for the blinking light to shut off is about 1 to 2 minutes. It worked for me.
Aug 09, 2009 | GE Dishwashers
GE triton II dishwasher normal light flashes and beep sounds
Ran across this today. Ge dishwasher normal light just blinks and beeps when latch is locked. I had to replace the control module and it repaired issues right away. Hope this helps
May 10, 2009 | GE Dishwashers
GE Profile PDW7880G00SS Dishwasher will not Start
Re: My dishwasher start light flashes and the timer display is blank.
That is a fault condition, if the display is blank it is probably a faulty control board.
Unplug the appliace from main, or trip circuit braker to cut power for ten minutes.
If display is still blank on startup, then replace the timer control assembly.
Mar 13, 2009 | GE 24 in. Profile PDW7880G Built-in...
Dose not finnish washing and starts bleeping and start light keep flahing. water is hot by have not dryed
Neighbor had a similar problem with a GE dishwasher except it wouldn't start and kept beeping when door was closed. So the door was left closed, and while it was beeping, turned off the circuit breaker that fed power to it. Waited about 30 seconds, turned circuit breaker back on, bleeping had stopped, dishwasher was reset. Normal and heated dry were already selected, (since I had tried pressing those two before all this to force a reset), then pressed start and it ran again. Hope this might help you.
Jul 25, 2008 | Whirlpool Dishwashers
Problem with GE Profile Dishwasher
My delay start switch does not work and the dishwasher beeps periodically throughout the day. Also, I have it set for a 109 minute cycle and after about 20 minutes it says that I only have 35 minutes left in the cycle! Any suggestions?
Mar 04, 2008 | GE 24 in. Profile PDW9280JSS Built-in...
General Electric Adora GHDA670N Built-in Dishwasher Logo
995 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
