Question about Samsung S3650 Corby / S3650 Genio Touch Cell Phone
My phone' screen says "no event" left mid and the screen does not function
  • signiel Sep 17, 2010
    The screen is locked and can't be unlocked by pressing thr lock/unlock button. Notheing works on the touch screen.
    President:
  • 3,278 Answers
Hello.
From Samsung Support:
To remove the 'no events' box, drag and drop it onto the tool bar. If you receive a message a green exclamation mark will appear in the tool bar.
Hope this helps.
Posted on Sep 17, 2010
  • NinaE Sep 17, 2010
    Try removing anf reinserting your battery.
    If still a problem and it's a frequent occurrence, go to a Samsung service center and ask them to do a software update/firmware re-install. That should resolve your freezing problem.
    anf = and
How do I edit my calendar on the samsung galexy S II
To add an event:
1. Click on calendar app icon2. Click menu button (bottom left below screen)
3. Choose 'Create' (with the + sign)
4. Set time, description, notifications and other data for the event
5. click 'save' (bottom left of screen)
To edit an existing event:
1. Click on calendar app icon2. Go to relevant day, and click on relevant event3. Click menu button (bottom left below screen)
4. Choose 'Edit' (with the pencil icon) - note this option is only for events you have created.
5. Set time, description, notifications and other data for the event
6. click 'save' (bottom left of screen)
Jan 04, 2012 | Samsung Galaxy S II
Why is the calender event icon on my screen, i dont have a calender event for today.
Actually, PiyushVig's answer is completely incorrect. The Calendar icon on both the front screen and the main screen are not always there. They only show up for a reason, and that is because there is a calendar event scheduled for that day. (Likewise there is no setting in the phone to show or not show the calendar icon. If you have an event scheduled for that day, the calendar icon will show and there is no changing that feature.)
Today I had the same problem as the person who asked this question. There are no events scheduled for today yet the phone displays the calendar icon on both the main screen and the front screen of my Samsun Convoy SCH-U640 cell phone.
So I just got off the phone with Samsung support to see if I could resolve this issue. They told me that there is no reason for the calendar icon to show up when there are no events scheduled for that day. They had me do a soft boot (shut off phone and remove battery for 20 seconds then replace battery and turn phone back on) and that did not work. I also tried actually programming an event for today and then erased it but that did not make the bogus calendar even alert icon go away.
So Samsung Support's conclusion to this issue is exactly what I suspected before I even called them; it's simply a software glitch (which is annoying for those Convoy users that really use and rely on the calendar function).
Apr 12, 2010 | Samsung Convoy Cell Phone
Suppose 1011 amt convert in words like 'One
Hiii
  1. Start Microsoft Excel.
  2. Press ALT+F11 to start the Visual Basic Editor.
  3. On the Insert menu, click Module.
  4. Type the following code into the module sheet. Option Explicit
    'Main Function
    Function SpellNumber(ByVal MyNumber)
    Dim Dollars, Cents, Temp
    Dim DecimalPlace, Count
    ReDim Place(9) As String
    Place(2) = " Thousand "
    Place(3) = " Million "
    Place(4) = " Billion "
    Place(5) = " Trillion "
    ' String representation of amount.
    MyNumber = Trim(Str(MyNumber))
    ' Position of decimal place 0 if none.
    DecimalPlace = InStr(MyNumber, ".")
    ' Convert cents and set MyNumber to dollar amount.
    If DecimalPlace > 0 Then
    Cents = GetTens(Left(Mid(MyNumber, DecimalPlace + 1) & _
    "00", 2))
    MyNumber = Trim(Left(MyNumber, DecimalPlace - 1))
    End If
    Count = 1
    Do While MyNumber <> ""
    Temp = GetHundreds(Right(MyNumber, 3))
    If Temp <> "" Then Dollars = Temp & Place(Count) & Dollars
    If Len(MyNumber) > 3 Then
    MyNumber = Left(MyNumber, Len(MyNumber) - 3)
    Else
    MyNumber = ""
    End If
    Count = Count + 1
    Loop
    Select Case Dollars
    Case ""
    Dollars = "No Dollars"
    Case "One"
    Dollars = "One Dollar"
    Case Else
    Dollars = Dollars & " Dollars"
    End Select
    Select Case Cents
    Case ""
    Cents = " and No Cents"
    Case "One"
    Cents = " and One Cent"
    Case Else
    Cents = " and " & Cents & " Cents"
    End Select
    SpellNumber = Dollars & Cents
    End Function
    ' Converts a number from 100-999 into text
    Function GetHundreds(ByVal MyNumber)
    Dim Result As String
    If Val(MyNumber) = 0 Then Exit Function
    MyNumber = Right("000" & MyNumber, 3)
    ' Convert the hundreds place.
    If Mid(MyNumber, 1, 1) <> "0" Then
    Result = GetDigit(Mid(MyNumber, 1, 1)) & " Hundred "
    End If
    ' Convert the tens and ones place.
    If Mid(MyNumber, 2, 1) <> "0" Then
    Result = Result & GetTens(Mid(MyNumber, 2))
    Else
    Result = Result & GetDigit(Mid(MyNumber, 3))
    End If
    GetHundreds = Result
    End Function
    ' Converts a number from 10 to 99 into text.
    Function GetTens(TensText)
    Result = "" ' Null out the temporary function value.
    If Val(Left(TensText, 1)) = 1 Then ' If value between 10-19...
    Select Case Val(TensText)
    Case 10: Result = "Ten"
    Case 11: Result = "Eleven"
    Case 12: Result = "Twelve"
    Case 13: Result = "Thirteen"
    Case 14: Result = "Fourteen"
    Case 15: Result = "Fifteen"
    Case 16: Result = "Sixteen"
    Case 17: Result = "Seventeen"
    Case 18: Result = "Eighteen"
    Case 19: Result = "Nineteen"
    Case Else
    End Select
    Else ' If value between 20-99...
    Select Case Val(Left(TensText, 1))
    Case 2: Result = "Twenty "
    Case 3: Result = "Thirty "
    Case 4: Result = "Forty "
    Case 5: Result = "Fifty "
    Case 6: Result = "Sixty "
    Case 7: Result = "Seventy "
    Case 8: Result = "Eighty "
    Case 9: Result = "Ninety "
    Case Else
    End Select
    Result = Result & GetDigit _
    (Right(TensText, 1)) ' Retrieve ones place.
    End If
    GetTens = Result
    End Function
    ' Converts a number from 1 to 9 into text.
    Function GetDigit(Digit)
    Select Case Val(Digit)
    Case 1: GetDigit = "One"
    Case 2: GetDigit = "Two"
    Case 3: GetDigit = "Three"
    Case 4: GetDigit = "Four"
    Case 5: GetDigit = "Five"
    Case 6: GetDigit = "Six"
    Case 7: GetDigit = "Seven"
    Case 8: GetDigit = "Eight"
    Case 9: GetDigit = "Nine"
    Case Else: GetDigit = ""
    End Select
    End Function
Hope this will solve ur problem
Regards.
G'Day
Sep 10, 2009 | Microsoft Office Professional 2007 Full...
How to remove no event
Maybe to try this advice.
Open your menu on the left side of the screen. Then simply drag the (no events box) over to the left side onto the calendar, it will then go off the screen and back into the calendar where it belongs.
Sep 05, 2009 | Samsung Lands Phones
'No Event' has appeared on the touch screen and I cant get rid of it - any ideas? The phone is a Samsung Tocco ultra Lite
very easy issue. touch your screen so that the side widget pops out from the left hand side. then simply touch the "no event" and slide it right on over onto your side widget then close it by touching the centre of the screen
Sep 04, 2009 | Cell Phones
Describe your RIM BlackBerry® Curve? 8330 Cellular Phone Problem Red light will not stop blinking
I own a Blackberry 8120. Have you tried a hard reset by pulling the battery and then restarting the phone? Also, events get caught in the phones memory process as well, causing reminder LED's to not clear after clearing the event. Go to options>security options>memory cleaning and enable the memory cleaning function. Set the icon setting to show on the home screen, memory cleaning is a function that many blackberry users under-utilize...the memory must be cleared just like a desktop PC, the rapid logging of events causes some to hang up. I believe one of these 2 solutions will help you out.
Jun 07, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Screen touch is not working
hello
try to press the mid black key where is the call and end call that is supose to unlock your phone
hope it works
Apr 23, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
How to convert numbers into words in MS excel?
1. Insert a module sheet into a workbook. To do this in Microsoft Excel 97 or Microsoft Excel 98, point to Macro on the Tools menu, and then click Visual Basic Editor. In the Visual Basic Editor, click Module on the Insert menu. In Microsoft Excel 5.0 or 7.0, point to Macro on the Insert menu and click Module.
2. Type the following code into the module sheet.
Option Explicit '**************** ' Main Function * '**************** Function SpellNumber(ByVal MyNumber) Dim Dollars, Cents, Temp Dim DecimalPlace, Count ReDim Place(9) As String Place(2) = " Thousand " Place(3) = " Million " Place(4) = " Billion " Place(5) = " Trillion " ' String representation of amount. MyNumber = Trim(Str(MyNumber)) ' Position of decimal place 0 if none. DecimalPlace = InStr(MyNumber, ".") ' Convert cents and set MyNumber to dollar amount. If DecimalPlace > 0 Then Cents = GetTens(Left(Mid(MyNumber, DecimalPlace + 1) & _ "00", 2)) MyNumber = Trim(Left(MyNumber, DecimalPlace - 1)) End If Count = 1 Do While MyNumber <> "" Temp = GetHundreds(Right(MyNumber, 3)) If Temp <> "" Then Dollars = Temp & Place(Count) & Dollars If Len(MyNumber) > 3 Then MyNumber = Left(MyNumber, Len(MyNumber) - 3) Else MyNumber = "" End If Count = Count + 1 Loop Select Case Dollars Case "" Dollars = "No Dollars" Case "One" Dollars = "One Dollar" Case Else Dollars = Dollars & " Dollars" End Select Select Case Cents Case "" Cents = " and No Cents" Case "One" Cents = " and One Cent" Case Else Cents = " and " & Cents & " Cents" End Select SpellNumber = Dollars & Cents End Function '******************************************* ' Converts a number from 100-999 into text * '******************************************* Function GetHundreds(ByVal MyNumber) Dim Result As String If Val(MyNumber) = 0 Then Exit Function MyNumber = Right("000" & MyNumber, 3) ' Convert the hundreds place. If Mid(MyNumber, 1, 1) <> "0" Then Result = GetDigit(Mid(MyNumber, 1, 1)) & " Hundred " End If ' Convert the tens and ones place. If Mid(MyNumber, 2, 1) <> "0" Then Result = Result & GetTens(Mid(MyNumber, 2)) Else Result = Result & GetDigit(Mid(MyNumber, 3)) End If GetHundreds = Result End Function '********************************************* ' Converts a number from 10 to 99 into text. * '********************************************* Function GetTens(TensText) Dim Result As String Result = "" ' Null out the temporary function value. If Val(Left(TensText, 1)) = 1 Then ' If value between 10-19... Select Case Val(TensText) Case 10: Result = "Ten" Case 11: Result = "Eleven" Case 12: Result = "Twelve" Case 13: Result = "Thirteen" Case 14: Result = "Fourteen" Case 15: Result = "Fifteen" Case 16: Result = "Sixteen" Case 17: Result = "Seventeen" Case 18: Result = "Eighteen" Case 19: Result = "Nineteen" Case Else End Select Else ' If value between 20-99... Select Case Val(Left(TensText, 1)) Case 2: Result = "Twenty " Case 3: Result = "Thirty " Case 4: Result = "Forty " Case 5: Result = "Fifty " Case 6: Result = "Sixty " Case 7: Result = "Seventy " Case 8: Result = "Eighty " Case 9: Result = "Ninety " Case Else End Select Result = Result & GetDigit _ (Right(TensText, 1)) ' Retrieve ones place. End If GetTens = Result End Function '******************************************* ' Converts a number from 1 to 9 into text. * '******************************************* Function GetDigit(Digit) Select Case Val(Digit) Case 1: GetDigit = "One" Case 2: GetDigit = "Two" Case 3: GetDigit = "Three" Case 4: GetDigit = "Four" Case 5: GetDigit = "Five" Case 6: GetDigit = "Six" Case 7: GetDigit = "Seven" Case 8: GetDigit = "Eight" Case 9: GetDigit = "Nine" Case Else: GetDigit = "" End Select End Function To use this UDF push Alt+F11 and go Insert>Module and paste in the code. Push Alt+Q and save. The Function will appear under "User Defined" in the Paste Function (Shift+F3).
Jan 19, 2009 | Microsoft Excel for PC
Samsung S3650 Corby / S3650 Genio Touch Cell Phone Logo
115 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
