posted by steelerector on May 17, 2008
how hard is it to install a lamp
Comment by steelerector, posted on May 20, 2008
how do you reset the timer
Solution #1
posted on May 19, 2008
Hi steelerector
It is really easy to do , you will normally get a little manual on how to do this with the replacement lamp.
Provided that the lamp is a original Sony lamp.
If not , then just unscrew the lamp door at the bottom , take out the two screws that fastens the lamp to the Projector's inside , replace the lamp and screw it back in and then put back the lamp door.
Then just remember to reset the lamp timer.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Sony XL-2000U Projector Lamp for
Email this problem
Email this problem
Can you Help with these Multimedia Projector Replacement Lamps problems?
magnavox replacement remote...
a some where to purchase one in... Answer This...
image is flickering
image is flickering
The ?flickering? of the... Answer This...
Repair Service
Find Multimedia Pro. Repairman Near You:
