Question about Marantz SR-780 Receiver
Marantz PMD661 will not turn on with AC or batteries. No power.
2 Suggested Answers
  • 5603 Answers
SOURCE: Hi I have a marantz
If you let the input "float" with no connection it very well may buzz. The input needs to be tied down with a driving source.
Posted on Feb 15, 2011
I have marantz 7'300 an the standby light is on but wont power on no screen no sound idk help please
Unplug it from ac for 10 minutes and then try it. If that does nothing you need to get it to warranty service. It has a 3 year warranty so should still be covered. No Video or audio output on MARANTZ nr1602
Jun 14, 2016 | Marantz Audio Players & Recorders
Use 8 gig sd card
Yes you can simply replace 4gb card with 8gb, 16gb, ect...
the device doesn't know the difference, it just gives you more storage capacity... hope this helps?
Mar 02, 2015 | Marantz Pmd661 Portable Field Flash...
No power going into my marantz 44se amp.
Check AC main fuse inside the amp located next to the power transformer, if the fuse is open, just put another and if it blows let the amp as is, because if you put more fuses and blow them you just add more damage to the amp, let me know your results.
Oct 12, 2013 | Marantz Audio Players & Recorders
Can't get rid of background noise on my marantz pmd660
Did you ever find a solution to this problem? I have tried new AC adapter cord and it still has background noise. The only time it doesn't is with the batteries.
May 15, 2012 | Marantz PMD660 Digital Voice Recorder
Hi I have a marantz pmd661 with a buzz on record when set to ext mic/line with no i/p regards
Feb 15, 2011 | Marantz Pmd661 Portable Field Flash...
PMD660 Handheld Digital Voice Recorder: I have a Marantz PMD 660 digital audio recorder. T...
This implies that there is not enough current going to the device when running on battery (only back-light but no data) whereas running fine on AC means that the device board is most likely in a good operational condition.
I think maybe once a leaked worn battery which left forgotten inside battery compartment damaged the battery terminals or at least the wires connecting these terminals to the main board, i would recommend you to open and check on that.
Sep 23, 2017 | Marantz PMD660 Digital Voice Recorder
My marantz sr5200 powered off and won't turn back on. What do I do? There is a light flashing red. this is not an overheating problem or fuse problem. It happened when I was trying to program the...
try to reset the memory circuits, the info on them may be corrupted, try this:
1 disconnect the plug from the AC line supply
2 wait 10 minutes then, reconnect the plug to the AC
outlet
3 try to operate the equipment.
now.. if above does not work you may have to contact the manufacturer as
the issue could be related with the internal circuitry.
good luck!
Apr 11, 2010 | Marantz SR-5000
Marantz PMD 660 won't power up from batteries
I would suspect the battery tray connections are defective most likely due to a broken wire.
May 01, 2017 | Marantz PMD660 Digital Voice Recorder
Marantz PMD201
Check the outlet voltage and set the AC adaptorfor that voltage fter words, insert the AC adaptor's output plug into the 4.5 V DC jack in the recorder. see attache image
Feb 02, 2006 | Marantz PMD201 Desktop Cassette Voice...
Marantz PMD201
If you are getting a low battery light (that may be the cause of you problem), you should check that the AC outlet settings are right. If the settings are correct, you should take out the AC adapter and try it with batteries (do not forget to disconect the AC from the power and from the recorder!!!). hope this will help. Daniel
Jan 20, 2006 | Marantz PMD201 Desktop Cassette Voice...
Marantz SR-780 Receiver Logo
260 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
