Question about Sta Rite STA-RITE CONTROL BOARD KIT - 42001-0096S
Sta rite heater won't fire. Control board only shows green LED lights. Prior to not firing water temp was 120 degrees. Almost burnt my foot off. Next day heater did not fire at all. Where can I go to test control board? Live in Long Beach, Ca. area.
  • 990 Answers
Could be your heat sensor has gone bad. follow the wires for the sensor from the board to the water manifold. Then simply unscrew the old one and put a new one in. Do this with the system off, good luck.
Posted on Sep 17, 2010
I have a Sta Rite 400 btu heater. Replaced the manifold with tall the sensors. Replace the circuit board as well. Heater runs and keeps running just fine. After about an hour the temp in the hot tub...
This is a curious situation. Where is all that heat going if not into the water? If the heater is firing normally, the water temp should be rising much faster, unless the bypass is stuck open. However in that situation the high limits should sense that the water is too hot in the exchanger and shut the heater off. Verify that your gas supply is sufficient, because after running for an hour that heat should show up somewhere. It's possible there may be blockage in the gas supply resulting in a low flame.
Mar 07, 2014 | Sta Rite Pool & Spa
Sta-rite Pool heater boot probem
bad temp sensor heater isn't reading to go on
May 14, 2012 | Sta Rite 333 Btu Natural Gas Heater...
Sta-rite pool heater won't fire...
www.cheappoolproducts.com/.../Max-E-Therm-manual.pdf - United States
https://www.gpspool.com/.../Sta-Rite/Tech%20-STA-%20Servicing%20the%20Heater%20Control%20Board%20%u2013...
Those manual should sort you out.
May 29, 2010 | Sta Rite STA-RITE CONTROL BOARD KIT -...
The heater won't fire and water temp reads 114 degrees. I've replaced the thermistor with no luck.
If the temp reads 144, the heater will not fire because it thinks the water is 144 ... entirely too hot and way beyond the safety limit of this heater.
I believe your trouble is in the thermostat sending unit.
Let me know what happens when you check this sensor.
Thanks for using FixYa.com
please vote
a
Dec 05, 2009 | Sta Rite Sr400na Max E Therm Pool & Spa...
Water Temprature read 126 on heater and will not fire. Pool temp @ 72 degrees. Heater set for spa @ 101 degrees. SR400NA Sta-Rite Heater
This is a problem with your thermister (heat sensor) You will find this on the left side of the water manifold about half way down. I'm not sure but I think it is a small tube that slides into the manifold and if you follow the wires back to the board it just plugs in. The part is reasonable priced for a heater part and very easy to install. Good luck.
Oct 04, 2009 | Sta Rite Sr400na Max E Therm Pool & Spa...
R8 Error
dont know what heater yuo got may be a board or temp sensor also post if automatic control
Sep 13, 2009 | Sta Rite STA-RITE CONTROL BOARD KIT -...
Sta Rite STA-RITE CONTROL BOARD KIT - 42001-0096S Logo
227 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
john h
Jim Goldsmith
Jim Goldsmith
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
