Question about Samsung HCN4226W 42" Rear Projection HDTV-Ready Television
NO PICTURE I have a HCN4226W projections tv, had it repaired 2 months ago by a designated repair center, was a CG amp and G/CRT drive, a few days ago went to turn on tv and have no picture just sound. Please help can't afford another 400 dollar repair. Mary
  • Samsung Master
  • 8,617 Answers
Sounds like the vertical output is causing the CRTs to shutdown for protection. Try resoldering the vertical output IC that will often correct the problem. If not the vertical output IC may be defective.
Posted on May 18, 2008
Distorted picture
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs. To get fixed either call in a local TV repair company or goto sites such as Tv Repair Kits to get a repair kit with instructions. Here is there link.
http://www.tvrepairkits.com/xcart/home.php?partner=papa1dude
They have put together complete kits for most models that include the parts, step by step photo instructions, repair assistance, etc.
Jan 16, 2010 | Samsung HCN4226W 42" Rear Projection...
Coloring is off and there is a ghosting effect
Part # BP95-00142E is the correct convergence amp board for a model # HCN4226W. Part # BP94-00155A is listed as a "CG Amp assembly board" also, but is not correct for a model # HCN4226W. They are both basically convergence amp boards. Here's a link to order the original Samsung covergence amp board for this model (HCN4226W) from a major parts distributor:
Samsung HCN4226W Replacement Part Convergence Amp Board
Jan 30, 2009 | Televison & Video
Picture from 60" to 19" then gone.
The fluid is a fairly easy replacement. They just need to remove the CRT with the bad fluid and drain the old fluid and clean the CRT and then replace the fluid. The Shrinking is just a Vertical Deflection problem which is also an easy repair. A new Vertical IC and a couple Capacitors. In my shop it would run @ $200.00 to fix both.
Dec 19, 2008 | Philips Magnavox 9P6034C 60" Rear...
Samsung HCN4226W 42 in.
Try first unplugging power cord for fifteen minutes.
Oct 10, 2008 | Samsung HCN4226W 42" Rear Projection...
Sound went out
Please help ! I moved my Samsung hcn4226w and reconnected. The picture is fine but, no sound now and cannot use all functions on the remote. Any suggestions would be great. Thanks.
Jun 29, 2008 | Samsung HCN4226W 42" Rear Projection...
Red color lamp going in and out, how much if replaced
A shop would charge about 350 to 400 for the CRT and at least 150 to install it.Its an expensive repair as the crt is pricey. Have you tried to trouble shoot the red drive circuit as it may be something simple such as an output transistor being faulty, or a solder connection on the CRT socket itself.
Mar 29, 2008 | Samsung HCN4226W 42" Rear Projection...
Red picture
sounds like u may have a picture tube problem/CRT, would be high price repair
Oct 27, 2007 | Zenith A25B33W 25" TV
Samsung HCN4226WX/XAA Rear Projection 42" TV Wont Turn On
take off the back there is a board at the top right with two black stk-392-040 chips on it unplug the red connector at the left side of the board then plug set up and see if it comes on if so the chips on the board are bad or replace the board about $100.00
Aug 02, 2007 | Samsung HCN4226W 42" Rear Projection...
Bad picture
You have a bad picture tube or a bad driver signal that drives the CRT. Could be a bad capacitor in the boost voltage circuit also. if you have no TV repair experience, contact an Authorized Sony repair center to have a look and assist you in the repair of this TV set. Good Luck
Jun 13, 2007 | Sony KP-65WS510 65" Rear Projection...
Samsung Convergence Problem
It requires some pretty good solder skills and there may be a couple of resistors that need to go also. Take that CG board out it probably doesn't need it and you will likely have to completly re-align the set after repairing it with the new CG in there, just the IC's and resistors usually require minimal alinment
Apr 19, 2007 | Samsung HCN4226W 42" Rear Projection...
Samsung HCN4226W 42" Rear Projection HDTV-Ready Television Logo
56 people viewed this question
Henry  Thomas
Henry Thomas
