Question about Samsung DVD-HR735 DVD Recorder/HDD Recorder
Problem connecting Samsung DVD-HR737 DVD recorder to Set Top Box
I just bought this DVD Recorder and I tried to connect it via my Virgin Media Set Top box and I have not been able to get it to work.
Can someone help me pls so that I can record programmes from the set top box
  • amit77 Jul 28, 2008
    i have the same problem. i cannot seem to record . i want to connect the HDD to my Samsung LCD and virgin media box but each time i do it will not let me record. Done the basicis like make sure the memory ont he HDD is clear etc. Can any one help?
I had the same problem, if you go through the channels from your DVD-R remote it should give you the option AV-1 and then AV-2 ? on mine it's AV1 (test it out first and you have to watch what your recording) then it should record from the cable box
worth a try?
Posted on Aug 24, 2008
I have a samsung dvd recorder, whats the proper way to connect for it to work, do i connect to cable box, tv
How you connect it depends on your system. You need to connect the video out of the recorder to the TV. If you want to record programs, you need to connect the cable box to the recorder's video in. (The unit doesn't have a tuner if you have the unit listed above.)
Place the IR Blaster near the set-top box IR receiver. Connect the RF cable from the wall to your set-top box and then another RF cable from the set-top box to the TV (not to the DVD recorder). Connect a composite A/V cable from the set-top box A/V (composite) out to the DVD recorder's A/V in (AV1) port. (Composite video is a three wire cable - the plugs are yellow (video) and red/white (R/L audio).)
Next you need to connect the unit to the TV. Depending on the TV, you can use an HDMI cable (best results), component video or another composite video cable (labeled AV2 AV out). If you use component video, you'll need a separate cable to carry the audio. (Component video cables have 3 RCA jacks on each end (red, blue and green). The audio cable has the red and white plugs.
You will only get a 480 (SD) signal output if you use anything other than the HDMI cable. (The progressive scan feature is not compatible with all TVs; see the manual for details.)
You can obtain the manual from http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_mdl_name=DVD-VR375 .
I hope this helps.
(you have an additional A/V IN connection as well as a DV In port on the front of the unit)
Sep 12, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
Awa dvd recorder dr711 can this be connected to a set top box
If it's like the DR620 it will only receive analogue from the TV aerial. I connect the AV out connections on my set box to the inlet AV on the recorder and watch and record through the recorder's "rear AV input" selection.
Jun 16, 2009 | Durabrand DVD-1002 DVD Player
Connecting a dvd 250gb hard drive recorder to tv and virgin box
Right then, on the back of the virgin box there are 2 scart outlets, connect one scart from the TV scart port to the scart in on the DVD recorder, then connect one scart lead from the scart out on the DVD recorder to the TV.
Find the DVD recorder source channel on the TV and then use the DVD remote control to find the digital input on the DVD recorder, this is usually AUX channel.
Post back if you need any more help
Good luck and thanks for using Fixya!!
Feb 22, 2009 | Televison & Video
Dvd recorder does not have tv tuner
sure you can record from your TV. You need to connect the AV1 of the tv to the AV1 of the DVD recorder. Then, when the TV is running, you can simultaneously record on your DVD recorder.
Use a SCART cable for the connection.
Jan 05, 2009 | Samsung DVD-V4600 DVD Player/VCR
Unable to connect dvd/vhs recorder to record via freeview box
Can you give me the model number of the dvd/vcr and set-top box?
Jan 03, 2009 | Daewoo DVRS04 DVD Recorder/VCR
Setting satellite box with dvd-r174
It's a shot in the dark, but it may be that your satellite provider incorporates a copy-protection signal in the broadcast.
Dec 15, 2008 | Televison & Video
I am trying to connect my Samsung DVD Recorder to my Samsung PS-42D7HD tv via the HDMI cable but it just comes up "no signal" on the tv - nothing at all. Also have an Olin HD Set top box with...
Hello
by befault your dvd recorder is transmiting signals via component video, so what you need to do is this connect both cable HDMI and Component or just a video cable then go into setup and then select video out via HDMI your video will go off on the screen and then with TV remote slect input source HDMI on TV and it should work fine.
Thankyou
May 09, 2008 | Televison & Video
Do I still need an ouside ariel to tune in the channels on my dvd recorder despite having virgin media. I am currently using a hdmi cable and three scart leads to play a DVD and still cannot record...
You can only tune the channels if the recorder is connected to an aerial, however you can still record from the V-box connected to the recorder via scart, but you can only record the channel you are watching.
May 01, 2008 | Televison & Video
Alba spkrkit559
Raymond,
I have the same Surround sound system and a virgin media box. Mine has been disconneted for some time and I am just trying to figure out how to hook it up again. To be honest the manual that comes with it (or maybe just mine) is useless. The diagrams don't actually show the correct DVD player or connections. I suppose though it's better than having no instructions at all. If you post your E-mail address I can scan it for you. I am not sure if you can connect everything you have but I managed to connect the Vigin Media box and DVD to the kit and it worked fine (it might be possible to put a scart switch somewhere).
Nov 03, 2007 | Audio Players & Recorders
Open Questions:
See all Samsung DVD-HR735 DVD Recorder/HDD Recorder Questions
Samsung DVD-HR735 DVD Recorder/HDD Recorder Logo
534 people viewed this question
Henry  Thomas
Henry Thomas
