Question about LG 47LG70 42 in. LCD TV
I have an 47LG70. It was working fine until two weeks ago. When I turn it on I can hear my TV through my surround sound stereo but no picture appears the screen, not even any kind of display such as a menu, channel numbers or even static. In an attempt to reset the TV I left it unplugged for a week. Still no luck.
  • mattblackerb Sep 17, 2010
    The are no outputs from the unit. I have the satilite box connected to the surround sound and the surrond sound connected to the TV with an HDMI cable. I went as far as disconnecting the HDMI cable from the TV and connected it to a second TV I have. It worked fine so I know it isnt the box or the surround sound. Im not tech savvy at the least so I dont really feel comfortable taking the thing apart. The TV is less than two years old so if there is no easier fix I'll try to get a replacement from the store. Please let me know if there is anything else I can do so i dont look like an *** when i try to return it. Thanks
  • 10,515 Answers
I am sorry to hear regarding the problem. To begin with, this is an internal failure and unplugging would not resolve the problem. It has to be repaired. As the unit is less than 2 years old, repair makes sense - if the cost of repair is less than half the cost of the TV.It would be really tough to speculate whether this is a problem with the inverter or with any of the electronic circuitry. I agree that these products are not made in the same way as it used to be and i have seen many products being failed within 18 months. This is why i usually prefer extended warranties on these sets.
The ball is in your court.As you cannot open the TV and repair or test the components, it would be hard to determine the exact fault.However, this is an internal failure.
Looking at the cost of the TV and other stuff, i would prefer you to get this unit repaired. However, if you wish you could also go in for a replacement.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 17, 2010
  • 456 Answers
At first the problem sounds like it could be the main printed circuit board, but is odd, because the audio outputs come from the main printed circuit board. Does the TV have the audio output running from the unit? Is the main question.
What I would suggest is, depending on how old the unit is, for instance, if it is only a few months out of warranty, contact LG and they may offer a once off 'Parts Only' or 'Labour Only' warranty for this problem as a gesture of good will.
The unit is getting power, we can tell because the audio still works through the surround sound, so the power supply printed circuit board is ok.
The main printed circuit board, the one with all the outputs and and inputs, seems to be working as it still delivers sound to the surround sound system.
It may be the LCD panel, the logic printed circuit board, a small printed circuit board attatched to the LCD panel or in a less likely case (or not) a component on the main printed circuit board.
I suggest if you are tech savvy and have access to a multimeter or a voltameter, you can remove the back of the unit and test the voltages running from the power supply printed circuit board to the main printed circuit board and from the main printed circuit board to the logic board and also to the voltages leading from and to the LCD panel.
Also keep and eye out for any blown capacitors, the look like a battery with the top bulging out when faulty as they are a common cause of certain issues becoming faulty and other issues still functioning properly.
I hope this helps, good luck.
  • Adam Jerome_lagudi
    Adam Jerome_lagudi Sep 17, 2010
    Test the TV using different inputs from the satellite box, AV1, AV2, etc to determine if possibly it may be a set up issue in regards to the HDMI, like the dpi settings.
    A lot of LG units have a habit of becoming temperamental with the HDMI cable, when using my LG unit as a monitor for my laptop I may sometimes need to insert and remove twice before it functions with picture and sound, annoying yet just the way it is as I have pulled it apart several times after frustration getting the better of me.
    Also try using another HDMI cable and also if possible even a games console with using a HDMI cable to determine where the fault may lay, TV settings or otherwise.
Why would tv sound work fine but while using roku 2 the sound suddenly stopped working?
If the picture is OK then check your sound cables, red and white if analog, or swap out the HDMI cable with one that you know works.
Also, on the SETTINGS screen make sure your audio is set to stereo not surround sound.
Dec 27, 2014 | Roku 2 XS
TV will shut off after 2-5 minutes
It is probable that there is power supply trouble. Visual examination of capacitors does not reveal internal electrical failure.
Jan 26, 2014 | LG 47LG70 42 in. LCD TV
No hdmi sound but perfect hdmi picture, we have tried 2 different cables, 2 different HDMI devices and both HDMI ports. Sound works fine with svideo cables.
have you checked the sound control in menu when HDMI cable is selected. I have had this on my own tv a wile ago. turned out tv was on 3D sound but sauce was just stereo no sound came out until changed it to stereo.
Oct 01, 2013 | Philips Televison & Video
Picture is black. sound went out a few weeks ago and now all that seems to work is the red power lamp turns on and I hear a click but that's all. I am not concerned about the picture since it is c
The click is a power relay on the main board and if the red light is on I would suggest looking inside to see if it has more than one relay--follow the power cord into the set----some of these sets have one relay but others have up to 3.
They are know for sticking open or shut. A tap on them can free them..A look inside even by a novice may also reveal something burnt or unplugged etc.
12_5_2012_3_12_13_pm.jpgview of relay bottom side is up.
Dec 05, 2012 | Hitachi 53SDX01B 53" Rear Projection...
Viewsonic N3252W picture ok but no sound
Download the repair book to this TV by net. It will have all details.
May 23, 2012 | ViewSonic N3252w 32 in. LCD Television
DELL SPEAKER SYSTEM STOPPED WORKING
Suggest you abandon the mini-phone jack connection - sounds like a wire is broken in that connector. Use the RCA stereo outputs from your TV into the Dell surround system. You may need a couple of adapter cables to make that work. Take photos of the connectors on the back of your TV and on the back of the Dell Surround system. Take those to an electronics store like Best Buy and ask for help there to get the cables you need (telling them that the mini-phone (headphone) plug is giving you trouble.
Apr 22, 2017 | Dell 5650 Computer Speakers
WD-52725 TV loses picture while playing DVD but not sound
replace DM or try to fix it.
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
Jan 04, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Audio fade
if there is no problem with the surround sound, you have a problem with the volume regulation circuit or with the main amp of this TV set, But to say the least is you have a backup to fix your problem, with the sound system, you said it works fine. this could run ya about 250 to 400 to repair. Good luck.
Mar 29, 2007 | Mitsubishi WS-55315 55" Rear Projection...
Panasonic SC-HT900-problems with surround sound mode and digital input
i have the same probelm when playing a dvd does it work then when u press the surround sound button it goes slient ???
Oct 16, 2006 | Panasonic SC-HT900 System
LG 47LG70 42 in. LCD TV Logo
333 people viewed this question
Computer Repairing
Computer Repairing
