Question about Frigidaire Freezers
I have an upright freezer there is no cold air coming out.You can hear the compresser kick in and fell some air but not cold air.What could my problem be.
  • Frigidaire Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then checkout the last two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 17, 2010
I have a Kelvinator upright freezer model k330uf the bottom section does not work
Sounds like its got blockage.
There is a channel that allows cold air to "fall" into the bottom chamber. There is also a return. Typically the "fall" chamber is choked with either something that fell in and was trapped, frozen solid with ice or algie has grown and closed the hole.
The best thing to do is empty it completely and inspect the drop channel.
Put all your frozen goods in ice chests to keep them from thawing out.
Good Luck.
Jan 08, 2015 | Kelvinator Freezers
It is running but is not freezing the food
Compressor is one reason why your freezer may not get cold. The compressor which is usually found at the back of the freezer helps to pump out gas/ cold air and the fan circulates this cold air in the freezer. If this compressor is knocked/defective, the freezer won't cool. Also, gas in the compressor sometimes get's finished and needs to be refilled. So, the compressor needs to be checked in a situation like this.
Fan problem is one of the most common reasons for the freezer to start failing, this is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them.
It's also possible that the fan is not running at all. If the fan is burned out or the motor isn't running, cold air can't circulate through the freezer and everything will melt. You can normally hear the fan motor switch on and off from time to time. Listen for it and if you can't hear it coming on for an extended period of time, the motor may need repair or replacement. The wires connecting to the fan may be the problem, preventing the fan from receiving electricity.
Several other problems could be keeping your freezer from freezing:
There could be leaks in one or several of the hoses in the refrigerator, which results in the cold air being lost instead of circulating properly throughout the fridge and freezer.
If you have the freezer so full that the cold air can't circulate, your food will thaw even though the freezer isn't malfunctioning. Always leave some space open in the freezer and try to not store food right up against the cooling vents.
The thermostat might have shorted out, which means the freezer can't accurately determine how cold it is. If this is the case, the refrigerator would probably not be working, either.
If your defrost drain becomes clogged, the water in the line will just refreeze over and over again, which could damage the lines as well as the fan. Always check the drain and make sure no sludge is building up in it if you have a self-defrosting refrigerator.
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster.
I hope the above helps.....
For further assistance, please let me know.
Regards.
Sep 15, 2011 | Maytag 15 cu. ft. / 425 liter Upright...
Freezer not freezing .. It's cold..
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster than the fridge can cool it, which will thaw your food.
I hope this helps........
Take care.
Apr 12, 2011 | Northland Panel Ready Upright Built In...
Our freezer sat in the garage unused and unplugged for about a year. Now we are ready to use it so we plugged it in. Its been on about a week now and its still not getting cold inside. Actually I...
something easy to try is to clean the evap. usually on the bottom. warm soap and water, or compressed air usually does the trick. it's the easiest thing to try.
Aug 21, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
How do i set my frigidaire upright freezer deluxe electronic temperature
My children left the freezer open overnight now the compresser want kick on... what can I do?
Aug 06, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
Freezer running bout only freezer top of freezer
Either the compressor is failing or it has lost some freon which means there is a leak. The sealed system needs serviced.
Eric
Sep 15, 2009 | Woods Chest Freezer C1501W3
White Westinghouse upright freezer not cold enough.
Coils are probably underneath. remove the grille at the front (usually you just rotate it down to pull off) and then vaccum inside with a wand. If there aren't any coils there either, pull the machine out from the wall, and remove the lower panel from the back side. Inside you should find a fan next to a coil. Make sure that fan is working, and if it isn't make sure it is getting power.
Vacuum out as good as you can, and if you can use compressed air to blow it clean, even better (vacuum first because it will kick out a lot of dust).
If vacuuming the coils doesn't work, then you probably have a freon leakage problem, in which case it is probably not worth the cost of repair.
Mar 06, 2009 | Freezers
Not sucking out air when door closes anymore
run your hand around the freezer gasket with the freezer closed slowly and see if you feel any cold air,also check corners they leak to,frost is caused by warm air getting into the freezer or the defrost system is failing,let me know what you find-mike
Oct 01, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezers Logo
81 people viewed this question
Top Frigidaire Freezers Experts
AJMAL KHAN
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
