Question about Vacuums
The oven just suddenly quite heating. - Vacuums
  • 43,501 Answers
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Posted on Sep 17, 2010
Why is my vacuum cleaner all of a sudden shutting off on it's own
Depends on the type of vacuum but the motor could be over heating check all filters and clean them to get better air flow to the motor
Jul 10, 2013 | Dirt Devil Vacuums
I have a kenmore elite microwave oven model 363 63692301 stoped heating food ;. fan & turntable work. HELP!
Hello, two things. The mega-tron tube is gone south, or the HV diode is open/shorted to ground which will cause to open. If the microwave meta-tron tube is bad then recyle your microwave oven and buy a new microwave oven. One can buy a new microwave oven cheaper than buying a microwave tube. GB...stewbison
Sep 12, 2011 | Vacuums
Microwave counts down but turntable does not turn and does not heat food. When it broke it stopped in mid-heating but still counted down the time remaining.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
May 04, 2011 | Vacuums
Marshmellow exploded in my ge jvm1190sy micr/convection oven and went thru the holes on the roof of the oven..i can not clean it any ideas? there is a layer of marshmellow and when i put convect oven on a...
You will need to steam the debris out. Place a microwave proof dish half full of water and two tablespoons of white vinegar into the microwave. Heat on high for two minutes. Let this sit for two or three minutes then heat again for thirty seconds. Take a warm damp towel and then try to remove the marshmellow. Don't use a paper towel or sponge. Keep boiling the water/vinegar and rubbing with the damp towel until everything is removed. Its going to take a while but you will eventually get it all.
Apr 07, 2011 | Vacuums
Our miele red star(s314i) vacuum was running great and quit suddenly. It had not been running for a very long time and just quit. Newish bag, no clogs in hose and doesn't seem overly hot. the over heated...
Ok, so if the cord test didn't fix the problem, then it sounds like either the plug has gone bad, or the switch. The plug is a very common problem to go bad, and can be caused by just simply yanking the plug out of the wall, or putting too much tension on the cord while you're vacuuming. Here's a link showing how to replace a plug on your Miele. You may purchase a plug at a Home Depot for very cheap. If this doesn't fix your problem, then it is either going to be the entire cord reel assembly that's gone bad, or the switch. The plug is the easiest, cheapest next best option, so hopefully this is your problem. Here's a link on how to change the plug out;
http://electrical.about.com/od/diyprojectsmadeeasy/ss/replacecordplug.htm
Please just use the comment field again if this doesn't fix it, and I'll walk you through step by step the more detailed process of replacing the cord reel.
Jan 17, 2011 | Miele Red Star Bagged Canister Vacuum
Using my unit (owned about 6 years - great service so far) it suddenly quit ... no wind down or 'prelude' like whine - growl - etc. -- it just quit running ... suggestions? clear filters?...
I agree with you having great service because mine only lasted two years. It sounds like the motor just worn out. If you don't smell any burnt electrical then replace the bushing for the motor. Good Luck
Jan 07, 2011 | Dirt Devil Reaction Twin Cyclone Upright...
My unit was working perfectly, then all of a sudden the heating unit quit. It's only two months old. What happened?
It's still covered by warranty, so I suggest taking it to where you got it. If they don't have a warranty station, you can find the nearest one on the below site.
http://www.eureka.com/Customer-Service/Store-Locator
Oct 05, 2010 | Eureka Deluxe Enviro Steamer Vacuum
Danby Microwave Model DMW 607w 700 watts Does not heat food
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
heatman101
Sep 13, 2010 | Vacuums
While vacuuming with my hoover mach 5 it all the sudden shut down
Hi, If it is warm to the touch, and it just shut down all of a sudden, I would say that the motor has an internal over load switch that is normally closed, and opened to stop from burning this vac out. It is a built-in safety. I would look at the roller for anything that may have hung up, but steady use for an hour just over heated the motor. Let it cool way down. Try and start it. Also, check the plug to see if you may have lost power there also. Let me know please so I can be of any help you may need.
Sincerely,
Shastalaker7
Nov 08, 2009 | Vacuums
Vacuums Logo
23 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
