Question about Rohl A3608/11LMAPC Single Lever Country Kitchen Faucet with Extended Spout...
Single lever with pull out accessory sprayer. Too little flow from the main spout. The pull out sprayer has more pressure than the main spout. I suspect the diverter valve is the trouble. What is the part number? Thank you
  • Philip Meese Mar 05, 2013
    once you take the cartridge out, how to you extract the diverter? It's all the way down in the faucet housing and there's nothingt to grab it with.
    Filmmaker:
    Uploaded 5 video answers.
  • 119 Answers
The Diverters Parts is C7005. Here's the parts breakdown for your Rohl faucet. Contact Rohl and have them send you new diveter for free, the A3608 seriers came with a limited liftime warranty.
Posted on Sep 17, 2010
Kohler style k12172 fairfax when i use the side spray there is very little pressure & the hose and sprayer are new and the hose has no bends in it.
you have an other part that went bad. Inside the faucet there ins a part called a devertot that is in the body of the faucet. This little part move the water from the main spout to the hand held sprayer.
You have to remove the handle and the spout. pop it out pop a new one in and you are good to go.
Glad you came to us for help. your rating us help us know how well we have done
Tom
Sep 09, 2011 | Kohler Fort© Single Lever Handle Kitchen...
Kohler Fairfax kitchen faucet has low flow pressure. Any suggestions? It's the faucet, not the water getting to the faucet that has the low pressure.
First thing to check is if it has a strainer on the spout that has debris. The second thing is if you have a sprayer attachment the diverter valve is a chronic problem with kitchen faucets.
Dec 29, 2010 | Kohler Fairfax Single Control Lavatory...
Trying to change cartridge on Moen single lever kitchen faucet with sprayer. Now that it's been reassembled, gets no water from spout when turned on. When lever is turned on, sprayer goes off and...
Moen has a diverter built in that will need to be replaced.
use the same steps as when you replaced the cartridge, but this time you will need to remove the spout, there is a small diverter, you will see it when spout is removed.
take this part with you to the hardware store, along with the O Rings from the spout, as they will need to be replaced also
use a non silicone faucet lubricant when putting back together
Aug 08, 2010 | Moen 7437 Chateau Single Hole Kitchen...
I used different length supply lines because th hot water line was a little short. Would this cause the side sprayer to move when the main faucet is turned on or the faucet head to drip?
No the length doesn't matter. When you turn the faucet on, you also fill the hose to the sprayer, and it may expand slightly, causing the sprayer to move a little. Is the drip from the end of the spout at the aearator? or is it around the faucet lever. If it is the lever, you should be able to tighten it slightly. If it's the end, make sure your aearator is clean.
Jul 18, 2010 | Kohler Fort© Single Lever Handle Kitchen...
Sprayer leaks on my Rohl single lever faucet
The spray head will need replacing, it unscrews and the new one will fit right on
Jun 27, 2010 | Rohl A3608/11LMAPC Single Lever Country...
Low water pressure from faucet, but plenty of pressure in water lines.
1-Remove aerator from end of faucet spout to check to make sure it is not obstructed by anything. Grit builds up there and causes flow to decrease , but it can be taken appart and cleaned out.
2-If you have a sprayer attachment to it sometimes the diverter goes bad. This sends water to spray head.
Cut water off remove handle with allen wrench and loosen collar on top to gain access to remove spout. after removing handle and collar you can pull up on spout or work it side to side easily to remove it.
In the middle at the bottom it has a removeable diverter that can be removed and replaced.
If it comes appart it will restrict water flow.
3- If you have to remove faucet to make sure no obstructions any where esle.
I hope this may be some help for you to have a starting point.
May 20, 2010 | Kohler Fort© Single Lever Handle Kitchen...
Water volume has been getting very slow
Could be a blockage in the valves and check any filters any where in line.some sinks in kitchen have a filter under sink and check valve to make sure they are opened all the way.
Apr 29, 2010 | Kohler Fort© Single Lever Handle Kitchen...
Faucet/sprayer coordination
If you have a Delta faucet your diverter may need to be replaced. The diveter is located under the spout (see diagram)(this is not your faucet but works the same)
Here are the instructions:
  1. Turn off water to faucet.
  2. Remove handle.
  3. Remove top cap.
  4. Turning spout back and forth gently lift and remove.
  5. Remove and replace diverter.
Hope this helps and please remember to rate this!
Nov 15, 2008 | Delta 2402 Classic Single Handle Kitchen...
Rohl A3608/11LMAPC Single Lever Country Kitchen Faucet with Extended Spout... Logo
505 people viewed this question
Top Rohl Plumbing Experts
Donni Steen
obsteiner
john h
Are you a Rohl Plumbing Expert? Answer questions, earn points and help others
