Question about Casio fx-300ES Calculator
Whenever i try to divide, the calculator gives me a fraction as an answer
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Casio Master
  • 102,366 Answers
To convert a single result to decimal, press SD. To have all results come out in decimal, press SHIFT MODE 2 to select LineIO mode.
Posted on Sep 17, 2010
How do I simplify the fraction 3/2
just divide 3 by 2 and it gives you 1.5 which is the answer
Feb 09, 2015 | Casio Fraction Mate Calculator
How to find remainder as a solution in CASIO fx991ES
Finding the remainder from a division calculation is often referred to as using the MOD function, though this isn't available directly on the fx-991ES.
To obtain the remainder, for example when dividing 10 by 7, you can only divide 7 into 10 once, leaving a remainder of 3.
For larger numbers, eg when dividing 389487 by 31 (equivalent to 389487MOD31) the division gives an answer of 12564.09677 (on the display), however you only want the fractional part so subtract 12564 to give 0.0967741935 . This includes the lower value digits that were previously hidden. Then multiply this result by 31 which gives 2.999999999 on the display. Since the result of a MOD or remainder calculation involving integers has to be a whole number, the answer needs to be rounded to 3. If the answer doesn't easily round to a whole number, it is likely that you have gone beyond the calculator's working capacity.
An alternative method which avoids the rounding of the fractional part is to take the integer part of the first result (12564) and multiply it by 31 to get 389484, then subtract this from 389487, giving the answer of 3.
Dec 16, 2012 | Casio FX991ES Scientific Calculator
When I divide the answer is in fraction form not decimal form how do i get it back
There are two options.
1) Whenever you want the answer in decimal form, place a decimal after at least one of the numbers.
For example: instead of using (1/2) use (1/2.)
2) Press the "Mode" button. Scroll down the list that appears until you find "Exact/Approx". If you set it to "Approximate", then it will always give the answer in decimal form. If you set it to "Exact", it will give the answer in fraction form.
Nov 12, 2009 | Texas Instruments TI-89 Calculator
Problems with fractions on the Casio fx-115es
To convert fractions to decimals or decimals to fractions, you use the [S<->D] key. Each time you press the key the result is displayed in the other format.
Alternatively, If you multiply or divide two integer numbers put a decimal mark at the end of one of the numbers (any one). The result will be displayed in decimal format.
Hope it helps.
Jun 01, 2009 | Casio FX-115ES Scientific Calculator
Mixed numbers
Proper fraction e.g. 3/5, input 3, divide, 5, =, answer 0.6
Improper fraction, either enter as improper fraction, or enter the whole number first, then +, then the proper fraction as before, then =.
E.g. 8/5 which is "1 and 3/5': enter 1, +, 3, "divide", 5 =, answer is 1.6
Or, just 8, "divide", 5, same 1.6 answer. Why go to mixed number first?
13/5 which is "2 and 3/5", enter 2, +, 3, "divide", 5, =, answer is 2.6. Or, just 13/5, same answer
Dec 17, 2008 | Texas Instruments TI-30XA Calculator
When I divide answers are always given in Fractions. Can I change it to come out in decimals?
To change from Fraction display to Decimal display on the Casio fx-300ES (and probably other calculators)
1) Press the "SHIFT" button
2) Press the "MODE/SETUP" button
3) Press the "2" button
This Changes it to LINEIO (Decimal)
Doing all of the above but pressing the "1" button instead of the "2" puts it back into MATHIO mode (Fraction)
Hope this Helps
(SHIFT)(MODE/SETUP)(2) to change to decimal
Nov 07, 2008 | Casio fx-300ES Calculator
What keys due i use to calculate a fraction, where is the fraction key
To do fractions, just use the normal divide button.
To see the exact answer, hit MODE and scroll down to Exact/Approx and change to EXACT. In this mode, it will give the fraction always unless you press the special (green button with diamond) before pressing ENTER and it will give the approximate decimal value.
Jan 22, 2008 | Texas Instruments TI-30 XIIS Calculator
Fraction problem
Go into MODE to the second page.  In Exact/Approximate, change it to Approx instead of Auto or Exact.  This will give you decimals instead of fractions.
Nov 17, 2007 | Texas Instruments TI-89 Calculator
Casio fx-300ES Calculator Logo
Top Casio Office Equipment & Supplies Experts
k24674
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
