My Noma floor airconditoner stopped working. I replugged it and it works for 5 seconds and then cuts off with a code FE something. I lost my manuel and not sure what this code is telling me.
  • 7 more comments
  • jrbattaglia Sep 17, 2010
    I got it working. I also noticed that when I restarted that the water light was on. So I drained it. That helped as well and could have been the original source of the problem. Seems to be working OK now.
    Thanks
    Thanks
    Thanks Jim
    Thanks Jim
    Thanks Jim
    Thanks Jim
    Thanks Jim
    Thanks Jim
    I also found the water light on. That could have contributed it to it as well. I drained it. Thanks
  • 2,272 Answers
The ac works on 2 modes.One is F and other is C.F is fan mode and other C is compressor mode.Try running on F mode then check.If its still turning off automatically.If its already on F mode then try switching it on C mode and check. Try holding down both up and down Temp arrows for 2-5 seconds.To turn from F to C or from C to F. keep updated thanks.'
Posted on Sep 17, 2010
  • raj somaiya
    raj somaiya Sep 17, 2010
    Thank you very-much for the update.And also thanks for the appreciation.
Bosch wft 2830
Its hard to say what your problem is without more information.
If you had a lot of vibration and water from a broken hose, you may have shorted one of the sensing units or main board.
Try to clear the program by disconnecting power and holding down the start key for a few seconds. Similar to Clearing the CMOS on a desktop computer.
Hope this helps
Mar 22, 2014 | Washing Machines
I have a 2005 Kia optima. It has no spark I changed the coils and cranks shaft sensor. And still no spark. The computer is not putting out any codes. Any suggestions?
fuses are first. always, with any electrical failure
most cars have 2 banks.
one in cab and one under the engine hood.
you said no spark but at all spark plugs or just one?
not checking them all , results in wrong diagnosis.
from 1920 to now.
not putting out , what does that mean.
dead OBD2 scan tool
or the tools works and scans but there are no DTCs stored.
when you crank the motor
all OBD2 tools show, the RPM cranking, does yours?
if the ECU can not see RPM it will cut spark and then cut fuel.
a scan tool just key on, not cranking. or runing can
see TPS throttle angle; move right foot see TPS move angle?
see water temp and air temp? see that?
that is a live working ecu.
then crank see RPM rise?
crank for 5 seconds, the ecu may log P0350 or355 for
for lost cam or worse lost crank sensors.
Sep 28, 2013 | 01-04 Hyundai Santa Fe, 99-05 Kia Sonata,...
Lost power last night - now Microwave won't work - control panel is not lit - unplugged for 10 seconds and replugged in - socket has power
Hi, W/D here.
Leave unplugged for a longer time, say 5 minutes. I have done this twice on my own, and it has worked, but it took about 5 minutes.
--W/D--
Feb 09, 2011 | Jenn-Air JMV8166BAS Microwave Oven
Oasis airconditioner broken
Unplug the unit for about 5 minutes and then plug it back in. If it still does not respond to the remote after that something has happened to the control panel. It should take 3 minutes after the unit is unplugged and then plugged in again before the compressor starts. (Self protection circuit) You can try turning off the circuit breaker and then turning it back on again also. I believe that your unit will work fine after trying these recomendations. Good luck.
Jan 12, 2010 | Heating & Cooling
CL code
I'm getting CL too, and don't know what that means, but I DO know how to get your remote phones to work. Before I lost the manual I had to do that. Simply set each one in the main charger for about 20 seconds and they will work.
Mar 15, 2009 | GE Lands Phones
Have a 95 grand cherokee larado limited the hatch light blinks
check fuses 5 and 8, if broken replace, then pull your overhead console off (its one screw in the front)
cut the purple wire and ground it to the ceiling, this worked for me, i had the EXCACT same problem, key for key, just make sure to use 15 amp mini fuses or youll blow something bigger causing a really big problem.
Jan 06, 2009 | 1995 Jeep Grand Cherokee
Counter top microwave GE lost all power
As an owner of a GE WES model might want to look at this blog post.
GE Customer Service is here.
Good luck.
Dec 16, 2008 | GE Microwave Ovens
LE Error??
your handbook should say what "fe" (a fault code) is. it may be not draining. have you checked the filter? on many machines the door can not be opened if water is still inside. try putting the drain hose at floor level into a bucket. otherwise undo the filter and let the water out that way - you may have water everywhere!!
Mar 19, 2007 | LG WD-3274RHD Front Load Washer / Dryer
Handset doesn't turn on; press a button, beeps and turns off
from a different brand portable phone - - it worked for me! "If you experience difficulty with placing/receiving calls, a lost security code may be the problem. The handset cannot communicate with the base. Unplug AC adapter. Disconnect handset battery for 10 seconds. Reseat the battery and then place in base. Replug AC adapter."
Oct 22, 2006 | Panasonic KX TC901W Cordless Phone...
Heating & Cooling Logo
18 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
