Question about Samsung HCL4715W 47" Rear Projection Television
Power Problems This set has been flawless for the 7 years I have had itm, but recently the power tends to cycle. The set shuts off and turns itself back on. Could this be something I could purchase to fix?
  • 58 Answers
Hello
No
You will need a tech. to repair this one.
Thanks Guy9
Posted on Jun 16, 2008
Sony HCD-GT222 Hi-Fi CD and cassette deck with tuner, suddenly started to shut itself down at volumes higher than 50%, after three years of flawless operation.
It's thermal; protection is happening probably due to bad ventilation. Fuzz and dust can block air vents.These need to be vacuumed out now and then.
Jan 22, 2014 | Audio Players & Recorders
Swimming pool pump problems
motor overheating replace pump if new install check wiring
Sep 15, 2012 | Pentair Pool & Spa
Hotpoint 7 cycle agitator sopped spininng/10 years of flawless operation
Possible there is no power to the motor at the cycle of spinning or agitation. It is possible that the program controller unit is a suspect, you need to use a multimeter to confirm the case as the power to the motor could be measured
Aug 17, 2012 | Whirlpool Washing Machines
1 year ol 52 inch flat screen with new power supply cycling.
Still sounds like a power supply issue would it still be under repairers warranty
Jan 07, 2010 | Samsung Televison & Video
My DV9000 shuts off by itself, randomly.. I know the motherboard gets hot so I'm not sure if it's the heat or I need to replace something..I've had my laptop for a few years now..Has anyone experienced...
I have distanced myself from HP computer products; too many problems in recent years. You may have an extended warranty; check through these to see if you can expect to get help from HP:
HP DV9000 series recalls
Jan 02, 2010 | HP Pavilion dv9000z Notebook
Having problems turning on 2 year old Phillips
Philips TVs tend to have issues with bad capacitors in their power supplies. Failing capacitors tend to have slightly different ESR (equivalent series resistance) values when they have been left off, versus after they are warmed up and charged up. Either a new power supply board or replacement of the faulty capacitors will fix the problem.
Oct 20, 2009 | Philips 42PF9630A 42 in. Plasma Television
Printer cycles on/off and displays "improper shut down"
Got the same problem following a message "Printer ink failure" code 0xc19a0035. Instructions say to shut down using button on/off. But printer refused to shutdown. After 30 minutes, I disconnected power cable. Removed cartridges. Reloaded cartridges. Reconnected power cable and got "Improper shutdown" message with continuous cycle. Solution: 1. While the printer is still turned on, unplug all cables and cords at the back of the printer.
2. Unplug the power cord also from the wall outlet...
3. Wait for two minutes.
4. Reconnect power cord to the wall outlet first.
5. Press and hold the pound (#) and six (6) buttons.
6. While holding down the two buttons, reconnect the power cord to the back of the printer and after two seconds, release pound and six buttons.
7. Turn on the printer if it turns off... and it's fixed.
Aug 25, 2009 | HP Photosmart C6100 All-In-One Printer
Unit will not turn on
Sounds like it has a bad relay on the compressor. This is most common. If it is anything else I would suggest buying a new unit due to cost for repair.
Feb 25, 2008 | Whirlpool AD40DSL Dehumidifier
Power turns off automatically
happened with my 2002 42" model. they say the convergence circuit.
Mar 10, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Receiver turns on and off in endless cycle
Its one of Three problems. The main b+ filter is defective, one of the standby power sources have a bad capacitor on the line, or theres a short in the main amp. section. Its probabvly going to cost you more then you would care to invest in a reciver thats around 5 to 6 years old. Its most likly time for you to upgrade to a suround sound dydtem with new fancy lights bells and whistles. Good Luck
Jul 29, 2006 | Onkyo TX-SV636 Receiver
Samsung HCL4715W 47" Rear Projection Television Logo
29 people viewed this question
Henry  Thomas
Henry Thomas
