I have a Kool Sound CDS-220 twin cd DJ mix unit but the output volume is very low when put through the amp, even with all the volume dials turned up. The headphone port gives plenty sound and both cd players play as they should. The master output knob crackles slightly and sometimes trips the amp so it doesn't blow. The LED volume display reacts when this mater volume dial is turned then disappears when you stop turning it. Just bought this second hand but it maybe simple to fix?
  • 130 Answers
SOURCE: intermitent audio
I had that happen before, one problem was my car had bad shocks or i hit a pothole in the road. The second time i had the volume up so loud the bass wass thumping the floor and it skips the CD. My question is, how lowd is the thign turned up? :P Some CD players load the data into a memory and then it plays from the memory till it needs more info. It maybe that the unit is not stable or the CD is not balanced right so it cant read the info at a consistant speed. The music maybe playing faster then it can read because of the vibrations. Is the disk clean? i know this may sound dumb but it is easy to over look. If the surface of the data side is so scratched up it may have problems reading the data quickly enough. Sometimes the coating can fall of the disk if you hold it in the light you can sometimes see spots threw the disk where the foil has been chipped off. The CD player could have a focus problem also, it could be damaged in shipping or have been dropped and it cant focus properly on the data. Do you have any other disks to try? a new one? one you never play?
Posted on Apr 04, 2006
  • 28 Answers
SOURCE: Sony DAV SA30 dvd player
Hi From the symptoms, you mentioned, ie playing CD's ok., Mpeg decoder chip is faulty. The new one supplied is a modified type. IC207, part no.6-707-406-01. Good luck. Capital98
Posted on Feb 14, 2007
SOURCE: will not record
the classic cdr201 will not record it will go to wait and return to cd status(blank cd etc) there is no led display of sound during this operation you can hear the audio for brief couple of seconds before it goes back to cd mode
Posted on Jan 13, 2008
SOURCE: M&S Systems MC602 Master Unit and M&S MCD6 6-disc CD Player
Go to www.allelectronicsrepair.com , he repaired mine and it works fine now
Posted on Mar 20, 2008
  • 92 Answers
SOURCE: setting up new CD laser
Any new laser will not require any adjustment, most modern CD players do a self calibration on power up. There is a small dot of solder that must be removed somewhere on the circuit board. You'll see it's shaped like two half circles with a small gap between them which is bridged by solder. Remove this and you should be good to go! You should just be able to touch a soldering iron to it and drag it off. Or you can use a "solder ******" or de-soldering braid.
Posted on Oct 09, 2008
Why has the sound / volume stopped working
It sounds like the output device may have failed. Check the manual it may explain it.
Nov 28, 2014 | Sony Audio Players & Recorders
I have 2 Mtx PA speakers with Brand new Stereo cables plugged into the back of them then the other end is going to my amp. But When i turn on my dj program and try to test them It is extremely quiet. Even...
This is a car stereo amp or DJ Amps and speaker set up? I think your question is in the wrong area. It sounds like you have something switched in the wrong position like monitor or record possibly using the wrong outputs or incorrectly figured signal routing. Possibly check the amp out signal selector on the mixing board? This question could be answered much better by a DJ in one of the many problem solving forums they have at other web sites. I have visited a number of them researching equipment I was selling. Just Google DJ Mixers forums.
Aug 16, 2013 | Car Audio & Video
Trying to record music from my dj equipment not sure how to connect
out put from the dj stuff to the input lines on the amp your using to record on, once the CD or tape, or whatever your recording onto, is set to record, it should pick it right up , now if your doing all of this off your DJ equipment everything that's used, from record players, to CD to tape, will be run through the main amp your using, if the selection switch is set to whatever, you should be able to just turn on the unit your recording to, and it will pick it up , everything leading to the main amp will be plugged into, a line in, and some, ( tape player ) will also have a line out, ( so should the cd player if its a recordable one, which in turn would be supplying the lines output to each unit .
Jul 25, 2011 | Audio Players & Recorders
I turn it on and at the volume set @ U or straight up(midway) nothing comes out. if you turn it all the way up of course you get alot of buzz and barely get any sound from a mic or mixer signal,etc. could...
Make sure you are using BALANCED line to this... XLR connections boyh ends. Make sure ALL interconnected devices are powered from the same receptacle or power conditioner. Test your cables... they do go bad. This unit REQUIRES line level input. Do NOT expect a mic to drive it directely. Make sure your mixer uses the XLR outputs and is powered from the same receptacle, even if you have to run an extension cord to it. This is a bi-amped speaker so there are independent amps for high and lows. With nothing out and known good in there is very little electronics before the signal is split to the separate amps. At line level, your volume control should probably be about 2 o'clock with the EQ's straight up flat.
Apr 25, 2011 | Mackie TH-15A Active DJ Powered THUMP...
Sub woofer volume adjustment
The gain dial is not a volume control. The gain dial is used to compensate the output level of your car radio head unit. all car stereo units output are not alike. If you set this gain level too high, it will cause major distortion (clipping) to the audio output of you speakers when cranked up. This excessive distortion WILL eventually, or even quickly damage or blow your speakers.
I personally blown speakers this way no not properly setting this. (lesson learned, I guess :| )
Jan 27, 2009 | Clarion DXZ545MP CD Player
Low volume on finalized songs.
There's not really any magic fix to this as far as I'm aware. I usually don't burn CD's from my Tascam directly, but export the mix to the PC and do final touches and burn from there. I don't typically normalize though and the levels are what has come out of the Tascam. I do however use compression on many of the tracks (and sometimes on the whole mix) before exporting which will squash the peaks and lows together and thus give you an overall higher volume with your level meters peaking in the normal place you're used to.
There are other factors like EQ without which a mix can sound too loud and perhaps cause you to lower the levels when really things in the mix just need to be allowed to sit in different EQ bands.
Compression is the key though. Unfortunately even well recorded instruments and vocals naturally contain wide fluxuation in terms of lows and highs and these need to be smoothed out in order to obtain anywhere near the volume of a commercial CD. With compression alone the result may still fall short as the use of pro quality mastering effects can really make a world of difference to overall percieved volume as well.
Hope this helped
bd.
Jan 26, 2009 | Tascam DP01 All-In-One Recording Package...
Low Volume on CDs - Roland 2400 CD
Hey Rick, There are a couple of places to look; I'll assume you have a decent input level near -12db average without peaking. First, ensure during playback upper right meter labled MST is near peak without going over, if you have room push the master level above 0db to +1 thru +6db and recheck for peaks above 0db. (You never want digital recordings to hit above peaks, you lose quality or resolution of the sound) As you find the sweet spot, master rec to 23/24-16 using the elevated level on the master fader. The manual suggest editing and mastering with the master fader at 0db however if you don't compress your tracks individually or reprint them at higher levels, you may have a great mix at an overall lower volume, pushing the master fader should help for a quick fix, but if this cures the level issue, try compressing and leveling each track to peaks prior to the first mix only lowering tracks which are too loud, when you get to mastering, all your signals are at their top potential for the CD. Spend a few minutes burning samples at low, just below peak, and just above peak levels on separate tracks and playback in your boombox for reference to a commercial CD. You'll find little to no difference when you are in the sweet spot. Another trick is to mixdown to a separate pair of tracks (not 23/24-16) and compress again during master mixdown rec. (ultimately 23/24-16) Good Luck Jeremy Yates, Radio World LLC.
Jan 08, 2009 | Roland Vs2400CD Digital Workstation W/CD...
Numark cd mix 2
Well, it's not that hard to set up. What do you need help with? If you want to know how to connect:
1) The CD units go into the back of the mixer - in the CD / LINE INPUT - Left side on CD / LINE INPUT 1 and Right side to CD / LINE INPUT 2
The output of the mixer - MASTER OUT - goes to the INPUT of your stereo, amplifier, or receiver's LINE INPUT connection.
That's it. Press PLAY on your CD players, and raise the faders/volumes, and your all ready to go.
- TWEAK AV LAB
Nov 30, 2007 | Numark Fusion 494 Complete DJ Package
Volume is uncontrolable
Hi sounds like you have the audio out from the cd changer connected to the RCA/Phono out of the radio. double check that the output from the CD changer is going into the correct phono/rca connector regards Mark www.carradiospares.co.uk
Apr 04, 2007 | Panasonic CX-DP88 8-Disc CD Changer
141 people viewed this question
 Grubhead
Grubhead
