Question about Goodman CLQ36AR49 Air Conditioner
AIR CONDITIONER MY GOODMAN AIR CONDITIONER IS NOT WORKING WELL. IT IS NOT GIVING OFF ANY COOL AIR. I ALREADY CHANGED THE FILTER HOPING THAT WOULD WORK BUT IT IS STILL DOING THE SAME THING. MY UNIT IS ONLY ABOUT A YEAR OLD. WHAT COULD BE THE PROBLEM?
  • 828 Answers
Do you have any frost on the lines going to the outside unit. If the large line is frosted your evaporator (Cooling coil in the furnace) could be frozen up. Operating it with the fan in automatic with the cooling on will sometimes be the cause of this condition.
If there is not frost on the large line going to the outside unit and you are getting air circulation inside the house the problem could be a loss of refrigerant charge. Look at the joints where the pipes were soldered to the inside and outside units for signs of oil. If you find oil at any point it is the indication of a refrigerant leak.
Posted on May 17, 2008
Filter dirty and blowing warm air
If your filter is dirty,the fan inside the house cannot push the cold air thru the evaporator, cool air cannot circulate, this will cause the compressor outside to over heat and even damage it and possible trip some fuses or circuit breakers, with these hotter days you want to change out your filters more often, changing out your filters more often will keep the evaporator cleaner and allow the cool air to flow, easier.good luck!
Aug 08, 2011 | Goodman CLJ36AR42 Air Conditioner
Freezing Goodman pipes
make sure the filter is clean. also the evap coil should be clean. if none of these then your system is probably low on charge. hope this helps
Jun 05, 2010 | Goodman CKL42AR42 Air Conditioner
Ice build up around intake?
Shut it down and make sure the cooling coil and filters are clean. Ice usually means one of two things
1. dirty filters or coil
2. low gas (freon) charge
Jun 02, 2010 | Goodman CKL24AR24 Air Conditioner
GSC130241AE Goodman Air conditioner does not restart
It could be a bad thermostat.When the unit isnt working does the tubing frostup? If you have heavy frost in the evaporator this could mean a leak or a dirty coil. Also make sure the filter is clean.
Jul 29, 2009 | Goodman CKL60AR60 Air Conditioner
My goodman seer 13 package heatpump stopped blowing cool air. Fan still works, there is power to the unit.
Is the outside unit starting and fan blade spinning? Have you inspected you air filter recently?
Sep 15, 2008 | Goodman Heating & Cooling
GOODMAN ARUF3642
These guys list the actual sizes of a good selection of goodman filters - just measure the old one or the space where it should be and match it to the right filter(should be a fairly tight fit). http://www.filters-now.com/products/dgb.html#skipmenu and this site describes what the different filter types available are http://www.oxyclean.com/goodman.html Hope this helps :)
Mar 07, 2007 | Goodman CLQ36AR49 Air Conditioner
Goodman CLQ36AR49 Air Conditioner Logo
141 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
