Question about Hunter (30067) Air Purifier
I have a Hunter 30377 - just replaced the filter and flashing light will not go off. Unit will only stay on for a few minutes. Display shows a "reset" light but no button to mash to do a reset -- where is reset button - or how do I do a reset? Unit otherwise works fine - strong air mover and quiet.
SOURCE: hunter 730 carbon pre-filter replacement orange light
Filter lights on your Air Purifier http://www.fastbrowser.net/netpicker/Filter-lights-on-your-Airifie.htm One of the best things about your IQAir Air Purifier is that it has warning lights to tell you when to change the prefilter, gas or hepa filters. Of course how long they last depends on your pattern of usage. For the initial 80% of the filter life the control panel will display a green light next to the corresponding filter on the outline of the unit. When the orange light goes on it does not mean that the filter needs to be replaced immediately but that there is 20% of useful life left. IQAir gives you plenty of time and the machine will tell you how many hours you have left. Once the number of hours gets to within a few hours remaining the orange light will then change to red. It is at this time you should change the filter. If you forget to change it and there are no hours left the hours will go into the negative displaying how many hours you have gone over and the red light will change to a flashing red light.
Just in case you have lost the manual like one of our customers, this is how you reset the filter lights:
1. Press the menu button ( 7 times) until you get to where the display says new filter.
2. Press the enter button and hold it down for 3 seconds and a number 1 will be flashing after the words new filter on the display. This flashing number is so you can enter which filter you have changed. Filter number 1 is the pre-filter, filter number 2 is the V-5 gas filter, and filter number 3 is the Hepa filter.
3. You change the number for the filter by pressing the up arrow button.
4. Once you reach the correct filter number you press the enter button and the control panel will display a question mark after the words new filter on the display. Below this it will say, E = Yes M = Cancel. If you wish to cancel the entry so it does not reset a new filter life, simply press the Menu button.
5. If you want it to reset the filter life for the changed filter, simply press the Enter button. Once this is done, the filter light will change back to the green light, which will show the filter has been changed. If you go to the remaining filter life on the control panel for the filter number you just changed, you will now see the remaining life of the filter in hours has been reset.
  • When most people think of Oreck, an air purifier is usually not the first thing
  • IQAir Dental Series Air Purifier
  • UV air purifiers are very effective at neutralizing airborne pathogens
  • HEPA Air Purifiers
  • REPORT ON THE AIR QUALITY CLEAN UP IN OUR OFFICES
  • Ozone Air Purification
  • Ionic air purifiers come in three different forms
  • WHOLE HOUSE HEPA
  • Dehumidifiers - Ebac Orion
  • Furnace Filters, Electronic, Electrostatic Air Filters - Comparisons, Ratings,
  • Posted on Dec 09, 2007
    SOURCE: lights still flashing after i replaced filter
    You have to press the reset button on some models. The unit does not have any way of knowing you reset the filter -- you have to tell it.
    Posted on Mar 23, 2009
    • 7 Answers
    SOURCE: I took apart my model 30377 air purifier, and I
    If you haven't found an answer, I can take pictures of mine.
    Posted on Jan 21, 2010
    SOURCE: Cannot find manuel, need to reset after replacing filters.
    How to reset Hunter quietflo air filter, won't start up.
    Posted on Feb 25, 2010
    shafykp750
    • 1070 Answers
    SOURCE: I purchased a Hunter Purifier,
    Hello Sir,
    It Seems To be Damaged...So try to Do following.....
    • Locate the air purifier's filter. Many times this is located underneath and toward the back of the air purifier. Note where it came from and what direction it was placed in the air purifier.
    • Carefully pull out the filter. Place disposable filters in a plastic bag and take them to a store for comparison and find the exact replacement filter. If it's a reusable filter, clean gently with warm water and mild soap. Rinse thoroughly until all suds are out of the filter. Shake out the filter to remove any excess water. Set the air purifier's filter aside when finished.
    • Disassemble the air purifier as much as possible. Make sure you keep track of what you are doing so that putting it back together is easier. You may want to take notes for easier assembly later.
    • Use a damp cloth wet with warm water to wipe down the entire purifier and all its parts. Wipe out all the grooves really well.
    • Leave all the air purifier's parts on a clean surface to dry completely. This may take several hours, depending on the consistency of the filter.
    • Reassemble your air purifier once it is dry. It is now clean and should be working properly.
    Hope this Make you Better...Thanks For Contacting FixYa...
    Posted on Apr 21, 2010
    Hunter hepatech 40882 uvc air purifier won't turn after cleaned filters
    Hello, this is Ava with Think Crucial.
    Filter life counters should be reset each time the filter has change. If your air purifier has a reset button, press and hold the reset button until the lights go out. You may also unplug your unit from the power for 30 seconds before plugging it back on if your unit doesn't have a reset button.
    You can purchase a wide variety of high quality Hunter replacement parts for your Hunter Air Purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
    http://www.thinkcrucial.com/search?type=product&q=hunter
    I hope this was helpful.
    Ava B.
    Think Crucial Customer Care
    Oct 24, 2016 | Hunter Air Purifiers
    Tip
    How to Reset Your Air Purifier Filter Light
    <span style="font-weight: bold;">Airgle Air Purifier:</span><br /> <ol> <li>Turn off and unplug the unit </li> <li>Press the light button to the "on" position </li> <li>Plug in the unit, and then release the button after the Filter-check starts</li> <li>The system will automatically reset the Filter-Check Gauge in about 25 seconds</li> <li>Once the procedure has completed resetting, please turn on the unit and press "Filter Check" button again.</li> <li>This time, the system should report an accurate result. </li></ol><span style="font-weight: bold;">Alive Air Purifier:</span><br /> <ol> <li>Insert a straightened out paper clip into the reset hole, with the unit off, and push the Timer button.</li> <li>You should hear a 2 beeps, signaling that the Reset was successful.</li></ol><span style="font-weight: bold;">Holmes Air Purifier:</span><br /> <ol> <li>Units which have an indicator light must be reset once the HEPA filter has been replaced. Reset indicator by inserting a small object (such as a pin or paperclip) into the hole marked reset.</li></ol><span style="font-weight: bold;">Honeywell Air Purifier:</span><br /> <ol> <li>Reset the filter indicator by pressing and holding the "Filter Monitor" button until the indicator light shuts off.</li></ol>or<br /> <ol> <li>With the unit powered on, press and hold the appropriate filter<br />indicator button down for approximately 10 seconds until the<br />light turns off.</li></ol><span style="font-weight: bold;">Hunter Air Purifier:</span><br /> <ol> <li>Change the filter and/or pre-filter.</li> <li>Now, you must choose which counter you want to reset. Press and hold the filter reset key (approximately three seconds) until the prefilter indicator flashes. Press and release the reset key again to alternate between the two indicators. The counter that will be reset is designated by the flashing indicator. For Models 36394 and 36395: Use the tip of a pen or pencil to press the key.</li> <li>Once you have the correct indicator flashing, press and hold the reset key for three seconds to reset that counter to zero hours. The indicator will stop flashing when it has been reset. If needed, repeat these steps to reset the other counter.</li></ol><span style="font-weight: bold;">IQAir Air Purifier:</span><br /> <ol> <li>To reach the Filter Life Reset function from the main display window, press the Menu key seven times.</li> <li>Press and hold the Enter key until the flashing cursor appears. Release the Enter key. The first filter selection to appear is the Pre-Filter.</li> <li>Press the Up Arrow key to select the filter that has been replaced. The Filter Life LED for the appropriate filter is now flashing red.</li> <li>Press the Enter key to confirm that the selected filter has been replaced. The filter life LED for the appropriate filter is now flashing red.</li> <li>Press the Enter key one more time to confirm the filter change or to exit without resetting the filter life, press the Menu key (M=Menu).</li> <li>Upon successful reset of the filter life, the new remaining filter life (taking the currently selected fan speed into account) will be displayed, and the filter LED light on the control panel will change from red to green.</li></ol><span style="font-weight: bold;">Kenmore Air Purifier:</span><br /> <ol> <li>Press the FUNCTION and OFF TIMER buttons at the same time for five seconds. The CHANGE FILTER INDICATOR will flash five times and turn off </li></ol>
    on Jun 17, 2011 | Air Purifiers
    Hunter air filter when you turn it on it keeps cycling- on/off,on/off and wont stay on. also hepa filter button not working any more, does not light up blue when pressed. TY for any help : )
    If your unit has a reset button, try resetting your unit. Also, replacing the filters and resetting it after putting on the replacement filters usually works. If this fix doesn't work, I suggest you contact Hunter support for assistance and their number is 888-830-1326.
    Ava B.
    Oct 01, 2016 | Hunter Air Purifiers
    Who would service hunter air purifier . I have a model 30377. I live in Nanticoke, Penna 18634, it will not turn on.
    MFG customer service email But Owner's manual troubleshooting might help figure it out.
    no manual? try manualslib.com
    Apr 05, 2015 | Hunter Air Purifiers
    Lights still flashing after i replaced filter
    Mar 22, 2009 | Hunter (30067) Air Purifier
    AC2044-1
    Unit likely had large partical like dog or cat hair cross over cell, Unlplug and remove pre-filter & cell.
    The unit has a timer that knows when power has been removed & front grille has been taken off by 2 micro switches in back of front grille that is connected to the units control board.
    While you are there remove pre-filter & Cell, if ok and no debris is found & theres no need to wash, wait 10 to 15 minutes replace all & plug back in.
    You should see the LED display flashing Clean Cell & Cell button flashing, hold Cell button in at least 3 seconds this may take longer to reset. Unit should turn back on.
    This condition has happened to my 2 units on occasion even though I had washed the cell only a week or two previously.
    The unit will turn off if a cell overload is detected by way of large static discharge. If I know the cell is clean, I just unplug the unit & take the front grille off for 15 minutes then & replace it plug back in & reset & all goes back to normal operation.
    Apr 22, 2008 | Kenmore AC2044-1 Air Purifier
    Hunter 730 carbon pre-filter replacement orange light
  • WHOLE HOUSE HEPA
  • Nov 26, 2007 | Hunter 30216 3-SPEED FLOOR MODEL Air...
    Red light on air filter
    After spending hours searching for this supposed little hole easy to miss, I called customer service. I found out that it's easy to miss because it doesn't exist!
    Here's the correct answer: Once you've replaced the filters, turn the unit back on. Then, with the machine running, press and hold down the on/off power button for about two seconds. The red light will flash and then turn off.
    Oct 12, 2007 | Holmes Products HAP422-UC Air Purifier
    Red light
    Here is the link to the user manual; http://www.filterqueen.com/pdf/defender.pdf The red light indicates a filter needs replacing, see page 6 of the manual (page 9 of the pdf file) If filters have been replaced and the light still flashes, then the reset procedure (described on the same page) should work. If still flashing then there is a more serious, but probably fixable fault. Hope this helps - ask again if you need more info :)
    Apr 13, 2007 | Filter Queen Defender Air Purifier
    Hunter (30067) Air Purifier Logo
    90 people viewed this question
    Top Hunter Air Purifiers Experts
    Steve
    Gerry Harvey
    Gerry Harvey
    Are you a Hunter Air Purifier Expert? Answer questions, earn points and help others
