Question about Acer Aspire 5315 Notebook
The volume is no longer working on my acer laptop. Can you please help?
    President:
  • 2,291 Answers
Open the Control panel 2. Open the "Sounds and Audio Devices" icon. 3. Verify the "Place volume icon in the taskbar" checkbox is checked. If this option is not available or is grayed out, skip to the next section of this document. 4. If you were able to check this box, click ok and close out of this window and the Control Panel. 5. Double-click the sound icon in the Systray and verify that all the sound volumes are mid-way or higher.
Check Windows services. Right Click My Computer and Manage. Choose Services and Application > Services. Choose "Windows Audio" and set to Automatic and Start. Now next you can do is If you open control panel & click device manager the window that opens will show a list of all installed hardware. Look for anything with an exclamation mark beside it, or to do with sound. If you see anything, right click it, check it isn't Disabled then select "Properties." The next window should have some tabs along the top, the one you are looking for is "Driver," you should now see an "Update driver" button. Check ur sound card information by doing this Click on start menu Click on Run Type dxdiag, enter Click on the sound tab There is button of test direct sound click on this check if there is sound Check ur registry. Check if the sound registry key is enabled or disabled. There could be an error in registry, run registry cleaner reg in out to scan for errors.
repairing windows Once you enter the setup and it loads the entire program, then you need to press the R key, which is for repairing the windows installation. This action will take you to the dos mode where further processing will be done. In the dos mode, system will ask you about installation place. Most of the people install their operating system in the C drive, which comes at number 1 option, so you need to press option 1. However, if you have so many partitions or you have installed the operating system then you need to choose the option according to your drive name. Here you need to enter your password as well, but if you have not set any password then you can simply press enter.
*Then there will be a c:\WINDOWS> command in a dos mode where you need to write, "Copy d:\i386\ntldr c:\windows. However, if you have different place of your installed operating system then you will write the address of that drive. This is the whole process and now you can eject the cd and can press exit to restart the system. Now this process will copy the correct NTLDR file from installation disk to your hard drive by making your system in the working condition.
Remember to fix your Windows registry with RegInOut Registry Cleaner and PC Optimizer
Posted on Sep 20, 2010
Acer b3-20 screen will no longer rotate
It sounds like you have put the rotate lock on.
The button next to the volume is a lock toggle switch.
try that and see if it will rotate.
Nov 16, 2016 | Acer Computers & Internet
Nentlyturn up volume
Reinstall windows, or Factory reset...
May 05, 2013 | Acer Aspire Computers & Internet
Aspire 1640 series
please desccribe about your problem to solve it immediately ..Thank you for giving me opportunity to solve your problem .
please give your ratings must...!!
Jun 17, 2011 | Acer Aspire One D255-2670
Activating Ace Aspire 5100 Key Board Volume Control
Not absolutely positive about your model, but on some the volume icons are on the buttons on keyboard along with the keys having something else on them. if thats the case to activate the volume probably requires holding the Fn key + Key with the volume Up/Dwn icon on it.
hope this helps please rate if it does.
May 09, 2009 | Acer Aspire 5500 5570-2609 Laptop
Audio Not Working!
just check the volume control some programs mute it for some reason go to all programs on your start panel>accessories>entertainment>volume control hope this helps regards Jim
May 01, 2009 | Acer Aspire 4520-5582 Notebook
No Sound from Acer 5100 : Volume tab is disabled
I am worried that there is a problem with the sound card on your motherboard. If it has worked in the past and then suddenly disappeared, usually it is because the computer can no longer locate your sound card. It will not load a driver for a device that no longer exists. Since you have already done most of the troubleshooting steps, it is time to think about replacing your motherboard. Good luck
Apr 24, 2008 | Acer Aspire 5100 Notebook
Laptop Volume
Dear Lozzer89,
Please let me know the Brand and Model of your Notebook, so that i can provide you the right link for the same , to download the proper drivers for the same.
Cheerup and Be Happy always
Mar 04, 2008 | Acer Aspire 5630 Notebook
Volume control
If Acer does not let you download anything for XP, then you are out of luck.
Dec 19, 2007 | Acer Aspire 5630 Notebook
My acer aspire 5610z
Checking volume control for muted input/output devices
  1. Click Start, All Programs, Accessories
  2. Click Entertainment, Volume Control
  3. Ensure that all volume control levels are raised and any mute boxes unchecked, with the exception of the microphone.
Try this to see if it helps.
;0)
R-
Nov 06, 2007 | Acer Aspire 5610-4648 Notebook
Acer Aspire 5315 Notebook Logo
29 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
