Question about Kenmore 24032\24036 Top Load Washer
The machine will not fill on cold water cycle( only trickles in)
  • Kenmore Master
  • 43,501 Answers
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Posted on Sep 17, 2010
Machine won't fill up with rinse water, it washes & spins but the water only trickles in the rinse cycle, i ahve been filling it up manually
Turn the water supply off.
Remove the COLD water hose from the rear of the washer.
Clean the silt out of the COLD water valve on the washer.
Re-attach the hose on turn on the water supply.
Jan 21, 2011 | GE WBSR3140DW Top Load Washer
My washer will fill with water during the wash cycle just fine, but during the rinse cycle the water just trickles in. The water lines seem to be fine. What else could be causing my problem?
usually the wash is a mix of hot and cold and the rinse is just cold, that said, it is most likely a problem with the cold water supply. check to make sure the cold water valve is all the way open and the hose isn't kinked. If those are ok turn the water supply off and remove the supply lines on the machine side, you will see a screen inside the washer that may be clogged with sediment. If so, just clean it out and put it back together. You may also want to run a wash cycle on cold only to see if it fills slowly for the wash cycle. If it does fill slowly on cold you have low pressure on the cold side.
Jan 07, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
The water fills very slowly on rinse
You probably have a cold inlet valve with restricted flow, either because the filter on the inlet valve is clogged or because the cold valve is failing......If you wash on "warm" you have both hot and cold water mixed. On rinse there is probably only cold water used....Check water flow for HOT and COLD settings and you'll probably see the difference...Good luck...Nomess
May 23, 2010 | Whirlpool LSR5132PQ Top Load Washer
GWL15 starts to fill, water shuts off & water coming in slows to a trickle. Hot & Cold lights flash, machine beeps. If filled with buckets of water cycle will finish.
A common fault with F&P machines is in the water inlet valves.It is not afvisable to exchange the hot and cold valves because they are different. The faulty valve should be replaced. . Goodluck.....Nomess
Apr 23, 2010 | Fisher Paykel EcoSmart GWL15
Water pressure for Washer (rinse only)
you nead to turn off both cold and hot water.next you nead to remove cold water hose from washer.remove screen and clean it and replace it.hookup cold water hose to washer and turn water back on.you should have better pressure.your rince cycle is cold water.
Nov 18, 2009 | Kitchen Ranges
Rinse cycle water flows out to a trickle- regular wash cycle flows normal- water valve?
Flows out where , drain or into machine ? If into machine , Most washers have a cold rinse into machine . If your using hot fill and you get a trickle , then problem is a clogged screen at the valve or a bad water valve .
Jul 06, 2009 | Washing Machines
Cold water in the rinse cycle of the washer just trickles
Sounds like cold water solenoid is not opening all the way, its easy to replace, and is found inside the wash machine where the hose connects
Apr 25, 2009 | Whirlpool LSQ9600L Top Load Washer
Water barely trickles out for rinse cycle
It sounds like you have some buildup in the cold water valve screen. Where the hose connects to the washer there should be a screen inside the valve. Remove the cold water hose from the washer and clear any debri on the valve screen.
If this doesn't fix the slow cold water flow then you will have to replace the whole water valve assembly. The water valve is the piece that the hoses connect too and supply water to the washer.
If you have anymore questions about this please ask. I will be more than happy to help you out.
Thanks
Jan 10, 2009 | Kenmore 24032\24036 Top Load Washer
Water filling oo last cycle
if only leaking on rinse cycles would suggest checking door seal for small tear as water level is higher on rinse.
Oct 23, 2008 | Fisher and Paykel Washing Machines
Washer fills slow only in the rinse cycle
ck and clean screens first both sides be sure hoses are not reversed timer has no affect on fill rate if screens are clean replace valve
Sep 19, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
91 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
