Question about ViewSonic VP2030b 20.1" LCD Monitor
I have two Viewsonic VP2030B monitors that both died together. Possibly a resolution or scan rate problem but I need a bit of help disassembling the things. The main chassis seems to be held in place right where the stand connects to the rear plastic panel and there are no obvious screws there.
  • 732 Answers
Wa7tuv, If the plastic front "bezel" is very thin and the monitor control and setting buttons are located on the verticle sides of unit, it just may be that the "bezel" will need to be parted from the rear cover, with the glass lcd panel left in the rear panel. Then you will need to remove screws so you can get lcd panel out of the rear cover. You might just get lucky and find a video of some owner/technician doing a tear-down if you search YOUTUBE using "lcd monitor disassembly" or "lcd monitor repair" as search terms. Be very careful and protect the glass lcd screen at all times. It is the most expensive part of the unit. You CRACK the glass, It's you bought it, you own it, Toyota!!!! You could also check with Viewsonic to see if they have a cash+old unit exchange program for out of warranty,but prematurely failed units that will be swapped for same model "refurbished units????? 12fixlouie
Posted on Sep 17, 2010
Problem: no image, black everything, it doesnt turn on, there is no red light and no green light either, previously sometimes turn off and than went on again... it did it several times... I can buy a...
Unplug the cabels and plug it back in,Have you tried this already?
Post back if it is not working we will be happy to help you.
Hope this helps.
Cheers!!!!
Jan 10, 2011 | ViewSonic VP2030b 20.1" LCD Monitor
Adjust zoom of monitor
mcdevito75 here, You can try going into Menu on the monitor or you can press the auto on your monitor to retrn to factory settings.
May 07, 2010 | ViewSonic VP2030b 20.1" LCD Monitor
Out of range
Your windows video settings are for a monitor that has more capability (eg more pixels/finer resolution, higher refresh rate, more colour bits than the current screen can handle so it's spit the dummy.
Run your computer in safe mode (I believe that uses basic video driver) and set the video display options to a very low level, then re-start your computer again in normal mode, and set the options to the native resolution, refresh rate etc of the monitor. These should be listed in the specs that would come in the box with it (may be resolution: 1,680x1,050)
Sep 13, 2009 | ViewSonic VX2235wm LCD Monitor
Viewsonic VP2030b LCD monitor - No power
There should be one fuse in the power supply inside. You can check and replace that if its dead. now if its not dead and you got power to that point you do need to rule out any capcitors at that time but if the fuse is gone it will not hurt to check the rest of the supply for the fault.
Please rate and accept the answer if it did help.
Aug 18, 2009 | ViewSonic VP2000s 20.1" Flat Panel LCD...
External monitor issues with Toshiba Advanced Port Replicator III
DebitGuy
I have the exact same problem with a Tecra Laptop and a ViewSonic monitor - Did you manage to resolve this at all?
Thanks in advance
Stu
Jan 08, 2009 | Toshiba Advanced Port Replicator III...
ViewSonic VP2030b 20.1" LCD Monitor Logo
486 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
