Question about Lowrance Transom Mount Speed And Temp Sensor
I have a X15 Lowrance with GPS. I have lost the feed back from the 200khz but I can use the 50khz and get the bottom. The water that I am fishing is the Columbia River and the depth max is about 120 feet.
4 Suggested Answers
  • 4 Answers
SOURCE: Lowrance x96 does not function after 20 feet depth
Your transducer needs to be adjusted so the return signal can be picked up. Some of these have to be super tuned to receive the signal. Also the transducer may be moving ever so slightly when the boat is traveling at speed. You may have some water turbulence interference all contibute to signal return.
Posted on May 27, 2009
SOURCE: I purchase a lowrance LMS-520C about 18 months
If your problem happens mostly in weedy area's, you should try downloading the latest version of software from the lowrance site. It's Ver 2.5.0. You also need to change your fishing mode to "shallow water". I experienced the problem as described on the site, and the download fixed it.
Hope this helps you.
Posted on Mar 14, 2010
SOURCE: Bottom Line Fishin'Buddy II Fish/Depth Finder user guide/manual?
i have an older fishin buddy 2 bottom line sidefinder i need a manual, a bracket that holds it to the boat and the battery holder / handle i hope you can help me with this my email dave2_3@yahoo.com
Posted on Jun 21, 2010
My fish finder shutsdown or restarts when I start my main motor
are they drawing power from the same bat? it maybe that starting the motor drop the voltage the finder receives
Apr 25, 2016 | Lowrance HDS 5 Fishfinder GPS Chart...
Why don't I see fish on my lowrance elite5 hdi fish locator
Sounds like you do not have your transducer connected.
You will know it is working if you have a bottom sounding. If you have a bottom sounding (depth reading) and it is correct then you may have to fine tune the finder to see the fish.
I have the same finder on my boat. http://njsaltfish.com/index.php/captainsfocus?sid=61
Sep 17, 2015 | Lowrance HDS 5 Fishfinder GPS Chart...
How do i find water depth
Water depth should show automatically on your sonar page.
if it does not then either you have selected "stop sonar" under your sonar options or you have opted to turn off the depth displayou so the numbers don't show up.
if you areally viewing your GPS or split screen sonar/GPS page, sometimes the depth display is not visible on these pages unless you specifically instruct the unit to display it.
Lowrance HDS 5 Gen2 Fishfinder GPS Chartplotter
Here is a link to Lowrance where you can download a pic version of the operators manual.
Go to page 11 "overlay data" this will give you a step by step of how to add data or readouts to different screens.
Aug 27, 2014 | Lowrance HDS 5 Fishfinder GPS Chart...
Problem with st1000 trying to go wrong direction using hds5
One of the settings is 180 degrees off. Go back through the manual and check all of your setup settings. I had that happen once to me.
Dec 03, 2013 | Lowrance HDS 5 Fishfinder GPS Chart...
Lowrance hds-5 will not power up. lowrance will not work on if out of warranty. does anyone?
most the time its a bad key pad when unit wont power on and what it cost to repair you can buy another one check the pins in the power cord see if there not broke or bent yes they break take a 12 volt test light see if you have power going to power in the plug that connects to back of unit if you have power . . .bad key pad
Feb 25, 2013 | Lowrance HDS 5 Fishfinder GPS Chart...
Lowrance eagle fish strike 2000c fishfinder/gps/plotter owners manual
The owners manual for the Eagle/Lowrance Fish Strike 2000c http://www.retrevo.com/support/Eagle-2000C-GPS-manual/id/517ci960/t/2/
May 05, 2011 | Lowrance GPS
How can I learn more about using my debth finder. Its new to me . Any video tutorials or materials I can read or watch?
look under support
http://www.lowrance.com/Products/Marine/HDS-High-Definition-System/HDS-5-FishfinderGPS-Chartplotter/
Feb 08, 2011 | Lowrance HDS 5 Fishfinder GPS Chart...
GP700F Airmar P66 to TM260
you must run 50KHz for deep water, so you will have to solve the interference problem to benefit from the power
Oct 12, 2009 | Furuno GP7000F/NT GPS Receiver
How do you get the fish to show up on the screen on a lowrance X96 depth finder? We just got it and there is no manual with it.
Are you looking for the little fish symbols?
Press MENU, down arrow to SONAR FEATURES and press ENT. Arrow to FISH SYMBOLS and press ENT. Press EXIT twice. Any significant return in the water will now show up as a fish symbol.
Are you looking for the fish arches?
You won't get any arches unless the boat is moving and of course there are fish passing within the transducers signal. The shallower the water, the less area you are covering and less likely to get a fish return.
There is an OK guide to understanding what you see on the sonar screen at the link below. It if pretty technical but parts of it may help you out.
http://primus.lowrance.com/support/resultDisplay.do?gotoLink=5&docType=1000&contextId=351%3A5.47%2C11918.11930%2C22.47&clusterName=ClusterPublic&lang=english&docset=%2FDocuments%2FSonar&contentId=9de88fa2-0b60-4b44-a470-29ee14767b3e&responseId=135ccbe2cfd4f608%3A1fe88d%3A122773df7e0%3A7c2&groupId=4&answerGroup=1&score=981&page=http%3A%2F%2Fprimus.lowrance.com%2Ficr%2FSonar%2FChart+Tutorial.htm&result=0&excerpt=Chart+Tutorial+Deciphering+Sonar+Charts.&question=chart+tutorial&resultType=5000#Goto5
An X96 owners manual can be downloaded from http://www.lowrance.com/en/Downloads/Manuals/
Jul 11, 2009 | Lowrance X96 200khz Fishfinder
Raymarine a65 transducer 200kh fine 50kh not reading bottom
First do a factory reset and determine that all the setting are correct. You can get this info from the manual. Remember you will loose any saved way points when you do the reset. If that does not sort you out;Remove transducer from transom mount and duck tape it to a broom stick so that the transducer face is facing down. With the boat standing still in calm water and the ducer hooked to the DSM25 push it below the water and see if it see bottom on 50khz.The idea here is to get the ducer in another location to see that it is not getting reflections of the boat. 50Khz is very prone to reflecting of stuff around it. If you still have a problem I would send the ducer and DSM25 unit back under warrant .No need to send A65 back it should not have a problem.
Mar 30, 2009 | Raymarine A65 Combo GPS...
Lowrance Transom Mount Speed And Temp Sensor Logo
29 people viewed this question
Top Lowrance Boating Experts
dduncan54
dduncan54
Level 1 Expert
Phil Walker
Phil Walker
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
