Question about Indesit W 83
Door hande broken replacement parts indesit w83
  • 83 Answers
Go to this website to contact Indesit - http://www.indesitcompany.com/inst/en/
click on the 'contact us' tab-there are contact choices, phone, skype, e-mail and fax
Posted on Sep 17, 2010
Indesit w83 dial just clicks round, is there a reset button some where
Washed any coins lately? I had a front loading washer and when mine did that it was still under warranty so the service came out and pulled a quarter out of the drain trap. If you not sure where that is contact me
Dec 20, 2013 | Indesit W 83
Indesit W123 drum not moving. Will turn freely and quietly both directions if spun by hand. Sounds like going through cycle and dial turns as is going through programme. Made a whirring noise when ini
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Jan 20, 2013 | Indesit Door Handle Kit for W123, W133,...
Indesit washing machine wie167 the word door came flashing up, the cycle has stuck and the door wont open
Ok the machine needs to be drained. Then switch the machine on again. The door should open.
Oct 06, 2012 | Indesit Door Handle Kit for W123, W133,...
Indesit w123. motor burnt out?
If your seeing flashes from behind the dial I'm thinking that the timer needs to be changed. Even with the motor shorted out, it still wouldn't cause that effect to happen.
Jun 17, 2012 | Indesit Door Handle Kit for W123, W133,...
The door handle on my Indesit W83 just broke off and I can't open the door... Any tips for getting my clothes out?? :/
same thing happened to me with my indesit w10.....so now i have touse a screwdriver to lever the door open (could always buy another handle, but hey...).
there should be a hole where the handle would lever the metal catch open...stick a screwdriver / spoon in there and lever it open...there's a technique to it but have a play around, you'll work it out... its easy enough!
Jun 27, 2010 | Indesit W 83
Indesit w103 does not close at all, the door is broken, where can I find a spare part to change it?
Hi.
Go to ----WWW.4INDESIT.CO.UK/SPARES
You should be able to obtain the parts you require through this site.
Please leave feedback.
Thankyou.
Jan 06, 2010 | Indesit Washing Machines
Indesit IDL530
it will require the door outer casing to be removed and the control panel to be removed as the lock assembly is fitted to the control panel,please make sure appliance is disconected from the mains supply as there are electrical connections there.
Sep 21, 2008 | Indesit 24 in. IDL500 Built-In Dishwasher
Fixing broken door lock of Indesit W123X washing Machine
no easy way to open
disconnect from mains
take top off. feel down the front to where the door lock is and see if you can feel the door peg sticking thro the door interlock. force this with your fingers and with luck the door will open
if can't do this way, break handle off and lever peg with a small screwdriver
you can buy a handle kit complete. fitting this is not difficult - split the door and all will be revealed advise you make a carefull note of where springs go etc before you start stripping it down or take a few fotos if you have a digicam
Jul 10, 2008 | Indesit W 123 Front Load Washer
Indesit d41 dishwasher
try testing the door interlock, actually this is only a micro switch inside the door behind the plastic front panel, there could also be the possibility there is a broken wire behind the door skin just above the hinge part, take care when working on appliances do not force parts to remove them and always unplug at the mains hope i have helped, if so please rate me well
Sep 26, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Broken door handle Indesit dishwasher DG 6100
I agree read "broken door catch" solution and be particularly careful in respect of the edges of the stailess steel panels - some of the edges are hidden and they are very sharp.
Jan 29, 2007 | Indesit 24 in. D61 Free-standing...
Washing Machines Logo
118 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
