Kenmore 16129 Built-in Dishwasher Logo
Posted on Sep 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My dishes and glasses are coming out of my kenmore dishwasher with a rough film on them..i put in rinse aid and that doesn't help
Anonymous
Level 3:
  • Kenmore Master 43,501 Answers
  • Posted on Sep 17, 2010
Anonymous
Kenmore Master
Level 3:
Answers
43501
Questions
0
Helped
10842544
Points
101584
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried in vainto clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if the heating element goesbad then that also can mess things up bad... So I would buy new spray arms, and also check out theheating element to make sure it is working... Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Machine working fine last week then began to not clean efficiently then water did not all drain away so plunged, soaked up excess, cleaned filter, replenished dishwasher salt and rinse aid and put new...
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101
There is white residue on the dishes/glasses (note: the rinse aid is full and we have cleaned the components one month ago) also, water drips slightly out of the left corner of the dishwasher
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Dishwasher Residue and Film on Dishes
heatman101
2answers
Model 665.13732k600 seriel FT4610713 dishes are not getting clean, they look like they have a film on them. Kenmore Ultrawash Quiet Guard Deluxe
The film is the stuff and the old soap backing up in the dishwasher. There is no cure for this. You can have them come out and it won't get fixed because it will happen again. They did not put a large enough drain/disposal on the models. Essentially you are eating old soap - goodness only knows what is in it.
1helpful
2answers
White film on dishes, glasses and silverware.
white film is actually from the calcium and magnesium found in hard water. your dishwasher is fine. its the water leaving the residue and spots. go to www.dishwasherfilter.com . they have a new product out exactly for this reason. very affordable and works amazing. you will love it.
Oct 06, 2009 • Dishwashers
2answers
How does the Rinse Aid part of the FDB2000RFS1 dishwasher work? We got one donated to our non-profit organization and found all our dishes are coming out with a dry film all over them. I believe we have...
Rinse aid is only effective if you have good quality water to start with. With hard water being the issue, you still won't resolve the film problem.
You can either put in a water softener, which I suspect isn't an economical answer just to get cleaner (film less dishes) or you can allow the dishes to air dry instead of using the heated dry setting in an attempt to avoid getting a film on the dishes.
You can try to use the rinse aid, but I'm pretty sure it won't affect the water quality issues you got, since you have hard water to start with - nothing ventured, nothing gained.
Just remove the cap for the rinse aid dispenser and with the door all the way open, pour in about 1/4 to 1/2 of the bottle and replace the cap.
Here's link to your manual that you can download for free, just scroll down and select the correct manual for your model number and click on the link.
http://www.devicemanuals.com/guide/Dishwasher/Frigidaire-manuals-page55.html
Hope you found this very helpful and best regards!
Aug 06, 2009 • Dishwashers
2answers
Dirty dishes
Try putting a cup of white vinegar in the empty dishwasher & running it on fast wash. Should eliminate film; do you have hard water where you live? If so lime build up could be the problem.
Hope this helps.Cheers.
May 16, 2008 • Dishwashers
2answers
Film on dishes
the problem is hard water. this is a new product out called the dishwasher filtration system and it actually filters the water going into the dishwasher. i tried everything to get my dishes clean but nothing worked until i tried this system. my glasses all had a white, cloudy look to them and it was terrible. you can get it at www.dishwasherfilter.com. it is very affordable and works amazing. the filter fits right under the sink and solves the problem immediately. if you use the discount code DFMTEN you will get 10% off
Top Kenmore Dishwashers Experts
vince
Paul Carew
NOEL
NOEL
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
