Question about Frigidaire GLTF530DS Front Load Washer
Units leaks under load - Frigidaire GLTF530DS Front Load Washer
  • 83 Answers
If all of the hoses are in good condition and not leaking, you probably need to replace the water pump
Posted on Sep 17, 2010
Water leaks from under washing machine after each wash
If it is a top load washer, you can tilt the machine back to where you can look under it to see if you can see the leak. If it is a front load washer, you will need to take the top of the unit off and start checking all parts that have water running through it. I would start by looking around the door seal for any rips, tears or holes. If you don't see anything there, look under the tubs at the drain pump and hoses. Sometimes underwires out of bras put a hole in the tub-to-pump hose.
Feb 27, 2015 | Washing Machines
My washer runs fine and drains fine but leaks water from the drainage hose. Is the connection just not secure enough or is there a problem with the pump?
if its leaking from the center bottom front of unit its your pump..if its leaking farther back it could be the hose...take a peice of news paper and stick it under front of unit,,it will give you a good idea,,if you need a closer look and help openning cabnit,repost.. good luck
Sep 09, 2011 | Kenmore 24032\24036 Top Load Washer
I have an LG front loader washing maching, model# WM2277H* I have changed both the hot/cold water value and the washer is still leaking.
if leaking on front unit : check rubber seal front glass door. if it ripped you should change it.
If leaking behind unit : check water hose , is it placed properly ?
If leaking under unit : call technician to repair it.
good luck.
Mar 25, 2011 | LG WM-2277HW Front Load Washer
Model CTS90AWN Speed Queen from Alliance Laundry Systems. The unit shakes / vibrates quite a bit - I have read that this is a common problem. Also leaks a small amount of water from beneath unit (have not...
These machine like to be loaded to capacity. Under loading them is the major cause of shaking. Try loading the drum all the way lightly filled but not packed. Another thing to look for is that it was installed properly. It is very important with theses machine that they be leveled properly at install. If this was not done shaking can occur.
Dec 27, 2010 | Speed Queen CTS90AWN Front Load Washer
Water leaking under floor when dishwasher runs
check the water to the unit it is locate under the door open the panel 2 -4 screw take flash light turn the unit on and see where the water come from ... it might be also from under your sink.
Jan 01, 2010 | Dishwashers
Maytag MAH2400A Front Load Washer
likely a rubber gasket slipped off the groove.... try taking it apart and slipping the gasket back on.
heavy loads have more force during the spin cycle.
Apr 20, 2009 | Maytag MAH2400A Front Load Washer
Kenmore top load washer 110-24642300 is leaking when it fills
tip the unit back and lean against the wall so you can look under it you will see the pump it is plastic. more than likley this is your problem. let me know if you need more assistance
Feb 24, 2009 | Kenmore 22642 Top Load Washer
I have an lg1814cw front load washer...it is leaking from the tub when trying to drain..I have cleaned the filer on the front, but it leaks under the tub.
im not going to tackle this yet,,because i need a little help...unplug unit get a flash lite,,and take back cover off,,..and you should see where is leaking from ,,than we will take it from there...
Dec 21, 2008 | LG WM1814CW Front Load Washer
Oil leak from bottom of maytag neptune tl - about 4 years old
sounds like seal leak in tub water is leaking onto drive unit and washing over it bring and oil it can with it couls be big bucks some parts may be under warranty call service but be sure to get estimate first
Nov 27, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Frigidaire GLTF530DS Front Load Washer Logo
27 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
