Question about Foxconn 865A01-PE-6EKRS Motherboard
WHERE IS THE SECOND SATA CONNECTION ON BOARD - Foxconn 865A01-PE-6EKRS Motherboard
1796 sata cabling error
Make sure your Sata connection start from Sata 0 and on up. You'll get the 1796 error when you have sata drives or devices plugged in other sata connections, Like: Your first Hard drive in sata 0 your second drive in sata 1 your optic drive in sata 2....You system (BIOS) will automatically start at sata 0 then sata 1 and so fourth.
hope this helps ya and thank you for using FixYa.
Nov 04, 2013 | HP Compaq dc7600 Convertible Minitower PC...
Where is the sata connection on this board FW82801
Hi.
You won't find any SATA connectors on that motherboard because it doesn't support SATA.
Regards.
Jan 01, 2013 | Intel Desktop Board D845HV Motherboard
Sata power supply with ide only mother board?
Unlike IDE drive cables, which allow you to connect at least 2 drives to the same cable, SATA cables only allow one connection from motherboard to drive per cable. You can connect as many SATA drives to your motherboard as you have SATA connections.
Mar 25, 2010 | Computers & Internet
System not recognizing dvd writer. new build. 2nd one I took the first one back thinking it was defective. HP dvd1270i dvd writer
Could be the motherboard's SATA connection is bad or not activated in the BIOS. I assume you have tested the SATA cable and verified that the SATA power connector is working. You may need to verify in the computer's BIOS that the SATA settings are on and correct. Do you have another SATA drive that is known to work that you can test in the computer to verify the SATA connection is working? Also some motherboards have a jumper on the board to disable and enable the SATA connection on the board. Verify that if there is a jumper it is in the correct position.
Nov 10, 2009 | Cars & Trucks
No Boot , new P5QL-EM mother board
Check the heat sink ontop of your cpu sounds like bad connection and it will cause it to do as you describe
Aug 04, 2009 | ASUS P5QL-EM - Motherboard - micro ATX -...
Does this have a SATA connection for a SATA HDD
I cant find specs or a good big pic so I can see it, the sata jacks are similar in appearance to usb potrs, on the Motherboard they are usually clumped together (If there's more than one), If it doesn't have them you can get a PCI card with SATA potrs and put that in.
May 11, 2009 | Matsonic MS8147C+ (N82E16813184008)...
Formating hardisk with sata connection
1) Be sure that your motherboard support SATA - See Bios
2) Using the Win XP installation CD you can format the drive. If you cannot load windows during the installation hit F6 to charge the SATA drivers.
If your sata drive is working like a second disk, you can format it directly from windows.
Start>> Control Panel >> Admistrative tools >> Computer Management
Or using any partition tools...
Sep 23, 2008 | Seagate Computers & Internet
Add sata HDD
Make sure the power cable of SATA hard drive is properly plugged in or not.. It is possible.. Try with SATA 0..
Thank you........
Aug 30, 2008 | EliteGroup (ECS 915PL-A2) Motherboard
Does Asrock P4VM8 support 500GB SATA hard disks?
near the interface port of the hard drive you have to put a jumper that limit the connection speed from 3.0giga per second to 1.5giga per second, I think that would solve the problem because the hard drive speed goes to 3 giga per second and the motherboard p4vm8 serial ata port can support up to 1.5giga per second.
Jun 23, 2008 | Asrock P4VM8 Motherboard
Foxconn 865A01-PE-6EKRS Motherboard Logo
Top Foxconn Computers & Internet Experts
David
David
Gareth Cockram
Gareth Cockram
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
