Question about Kenneth Cole KC1104 Wrist Watch
Replace a watch band for a kenneth cole kc 1239 p93-05
SOURCE: leather watch band
I might have the solution. Is it a rectangular watch with a leather strap? It sounds weird, but I have a watch with no brand name on it (bought yesterday from K-Mart at $9.99) with the model #A126-06. The package insert said "Advance Watch Group." I googled them, and they manufacture watches for Kenneth Cole, Tommy Bahama and a bunch of other designers.
I was really surprised because K-Mart is the last place I'd buy a watch, except that it looked like my broken Raymond Weil tank watch.
I suggest you go to K-Mart and see if you find a watch that looks like yours.
The back of this watch is marked as follows:
V377
Stainless Steel Caseback
2035 Movement
Base Metal
Bezel
20279knx
A126-06
Posted on Aug 10, 2008
SOURCE: HOW DO I TAKE A LINK OUT OF THE WATCH BAND
Start by looking at the inside of the watchband, there should be a arrow pointing up/down. Take a pin and put it in on the side that shows the arrow going down. Take a hammer and GENTLY tapp the pin. The pin should push out a pin in the band. Do this as many times as you have to for the size you desire, and then put the pin in the same derection as you tapped the pin out. Usually you will also see a **** on the side youn DON'T want to tap out. If you still; have a problem don;'t hesitate to write me, and I will be glad to take you step by step with this. Good Luck!!
Posted on Aug 11, 2008
SOURCE: Leather Band
Do you need the same strap that was on it? The only way to try to get that is through Kennth Cole, and they probibly will tell you it is discontinued, but try. If you are not needing the exact band , take your watch to a watch repair shop, they will have bands that will fit your watch and probibly the style too. If you find you can't get what you want ,PLEASE let me know and I will do my best to find what you are looking for. Good Luck!
Posted on Aug 16, 2008
escapement
  • 2334 Answers
SOURCE: Kenneth Cole Wrist Watch unable to remove link
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Hope it'll help.
Regards
Arthur
Posted on Dec 17, 2008
SOURCE: want a replacement Kenneth Cole watch band for a
call Geneva watch repair on 18008740907 i just ordered mine now
Posted on Jan 11, 2011
Kenneth cole band replacement for kc 3903
please contact
aftersale@carmenco.com
thank you 9k=
May 31, 2014 | Kenneth Cole Kc9110 Touch Mens Watch
I have an older model watch that needs a new band. The band is black polyurethane. The model looks like KC 1158. Can I purchase this replacement part?
I would recomend searching EBay for this band but this band can be purchased from other vendors as well but may not be an exact match
Jan 29, 2011 | Kenneth Cole Watches
Where can I get a new band for my KS4003 Kenneth Cole watch? The clasp won't open and I didn't want to pay $65 just for a new clasp. How much is the band?
Thank you for contacting FixYa,
You can contact Kenneth Cole for a replacement band but I am afraid the band is probably going to be alot more then the $65 for the clasp. I would honestly just replace the clasp unless the band is worn in which case I would do the band.
Sorry.
KC can be reached at 1-800-KEN-COLE
Oct 02, 2010 | Kenneth Cole Watches
I am looking for a replacement band for a Kenneth Cole Reaction watch. The model number I believe is KC 1376 and there is another number P93-06. Any help would be great.
Thank you for contacting FixYa.<br /> According to previous customers on FixYa, Kenneth Cole are extremely hard to find and KC company has been of no help or assistance.<br /> I am afraid your best bet is going to be:<br /> <a href="http://www.watchbands.com/">http://www.watchbands.com/</a><br /> Good luck. <br /> Jewel<br /> Please be sure to rate me.
Aug 27, 2010 | Kenneth Cole 1213 Wrist Watch
I need to replace the wristband on my Kenneth Cole watch. Help
Thanks for contacting FixYa.
KC is a very tough one to find on line. Is it a specialty type band?? I dont know if yours is a leather or metal. If its a standard leather you can find at any store that carries bands. But otherwise, you may have to contact KC personally at 1-800-KEN-COLE.
Best regards.
Aug 24, 2010 | Watches
I have a Kenneth Cole watch (KC 1555 U54-09) and the leather/rubber strap is perished. Whwere to get a replacement?? Can I replace with a Stainless steel strap I am in Seattle,WA now
Call this certified Kenneth Cole watch repair company and speak to the representative. Not sure if they are on the West Coast.
Geneva Watch Group
1800-874-0907
Aug 09, 2010 | Kenneth Cole Watches
Where can I get replace band for this watch.. I have had it replace twice and the strap keeps ripping out of the screws. Where can I get another original KC band?
mcdevito75 here, Best Bet, see a small watch repair shop in your area, for the new band, You could get an orginal Kenneth Cole band on ebay.
Jun 28, 2010 | Kenneth Cole 1315 Dial Strap Watch for...
I HAVE KC 3500 WATCH.MY BAND IS IN TERRIBLE CONDITION.
You do not need exactly the Kenneth Cole watch band. Measure the distance between watch case lugs - this will be the width of your new band. Go to any jewellers shop you like, ask them to show all watch bands of this size and choose whichever you like. Ask them to fit it as well if you do not fancy to do it yourself.
In case if you have a buckle with KC logo and want to keep it, then take it with you and ask to refit the buckle as well.
Rate me, please.
Mar 12, 2009 | Kenneth Cole RK5034 REACTION
Watch bands f/ Kenneth Cole
Replacement watch band (f) can be purchased from amazon, take a look here: Amazon com kenneth cole band Watches Women Clothing Shoes Jewelry Wish you best of luck. Cheers
Jun 22, 2008 | Watches
Kenneth Cole KC1104 Wrist Watch Logo
414 people viewed this question
Top Kenneth Cole Watches Experts
Jimmy Accardi
Ansel Alberto
Ansel Alberto
Are you a Kenneth Cole Watch Expert? Answer questions, earn points and help others
