Question about Casio Forester FT610WV3BV Wrist Watch
I have a Casio Forester FT-120 -H watch. Just replaced battery but nothing happened. Is there something special relative to battery changes?
upajos
  • 24 Answers
SOURCE: please help me to replace battery on my casio F-91W
This reset trick works with other Casio Alarm Chrono digital watches, such as my old Model W-720, similar to your F91-W. After the new lithium coil cell is installed and secured with the spring clip, the watch may show random segments in the LCD display or may simply be blank. Insert a sewing needle, paper clip, or blade of a small jeweler's screwdriver into the hole on the back of the movement stamped "AC" (All Clear) to momentarily connect the gold plated contact at the bottom of the hole to the stainless steel battery clip. The battery clip in most such Casio watches is connected to the "+" terminal of the coin cell. This will reset the CMOS chip and it should start up with the watch displaying 12:00 and the date at 1-1. Then, use the control buttons to set the time and date in the normal fashion.
Posted on Oct 29, 2008
  • 8 Answers
SOURCE: I just repaced my casio watch batteries but i'm
This may sound dumb but make sure the battery is in the correct side up. There should be a + or - symbol on top of the metal piece that snaps over the battery. If that's correct get a pair of tweezers and spread them open, and touch one side to the top of the battery and the other side down inside a little hole with ac marked beside it. That will reset the watch, and your display should come on.
Posted on Feb 28, 2009
escapement
  • 2334 Answers
SOURCE: need directions on how to move analog hands on
Check out my tips here and find the instructions manual for your watch.
Posted on Feb 07, 2010
mcdevito75
  • 1970 Answers
SOURCE: My old brother has A old casio watch illuminator
mcdevito75 here, Most likely 2 batteries. 1 for the illuminator on top once you remove the cover and 1 for the time mechanism.
Posted on Jun 30, 2010
mcdevito75
  • 1970 Answers
SOURCE: What is the main internal
mcdevito75 here, The Internal workings of all watches and clocks, Quartz and mechanical is called the movement. You may have a weak or even dead battery, even if the battery is new. If you"ve dropped your watch, got it water logged, you could have hurt the Quartz movement. It'll take special equiptment to check the Quartz movement to see if it"s burned out. I would try another battery or at least double check this batteries instalation in your watch. For more info, here is Casio"s contact number, 800-435-7732 9AM--5PM EST.
Posted on Aug 03, 2010
What is the battery number for the casio ft 600w?
CTL1616 and there is a video on you tube showing you how to do it.
I assume this is the casio Forester.
Oct 02, 2017 | Casio Watches
Casio forrester date will not change
https://www.youtube.com/watch?v=I9VGeriSTOI CASIO FORESTER
Jul 12, 2017 | Casio Watches
Why is my watch not working?
The electronics in a watch sometimes stop working, because something is defect. Special when around the battery was "dust" is is oxide coming form a leaking battery. The batteries are not supposed to leak, but some cheaper brands do. The oxide can have damaged the circuitry in the watch. Not worth cleaning, because the oxidation already started en can go on on any place in the watch. If it is a good watch and you are attached, ask if they can replace the electronics, but also ask what it will cost you.
For a Casio certified repair store close to you, check here:
Authorized Service and Support Service Centers Support CASIO
Mar 31, 2015 | Casio MTP Watches
Battery
The Casio Forester FT500WVB watch has an EL (Electroluminescent) backlight and requires one silver oxide button battery. The SR621W battery (also known as type 363) is recommended by the instruction manual for the watch. Note the suffix "W" means this battery is a high drain type which is suitable for powering a watch mechanism and the EL light as well for 2 to 3 years, depending on use of the light. "SW" suffix batteries are low drain and are intended only to power a watch mechanism, and not a light. Note also the "SR" prefix indicates the battery is silver oxide and not lithium. The SR type batteries do not use mercury and are therefore safer to dispose of when they are discharged. I have found the type SR626W (also known as type 377) battery is also suitable for the FT500WVB watch and it has more stored power and should therefore last longer.
Last, the Casio Forrester FT500WC looks exactly like the FT500WVB, but it is a different watch internally. The FT500WC has an LED light and requires two batteries- the SR920SW low drain silver oxide battery which powers the watch mechanism and the CR1616 lithium battery which powers the LED. The LED is brighter than an EL light and stays on longer than the EL light when activated. But the LED has a bright dot light source that some might find annoying.
Apr 17, 2014 | Casio Forester FT500WV-3BV Wrist Watch
Casio prt 41
If you have that kind of problem with your Casio Watch, there are 2 possible problems here:
-Battery is leak
-They did not reset the watch properly if the battery was replaced.
Best you can do is take it to an official Casio dealer, they will handle your Casio watch properly.
You can find any spare you need for your Casio in our website. At TicTacArea.com we are official Casio dealers and we will be glad to help you with this and any other problem you may find related to your Casio Watch. Casio Watches Casio Multi Task Gear Watches
Apr 10, 2014 | Casio Watches
How to reset casio 3781 efa 115
if the light is not working it might be a dead battery and needs replaceing,this link is for the manual
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw3781.pdf
Jan 23, 2013 | Casio Edifice EFA109-7AV Wrist Watch
What is the main internal assembly of the Casio forester watch called? Replacing the battery does not work.
Aug 03, 2010 | Casio Forester PAS400B-5V Wrist Watch
Does not start after battery change. buttons are not functioning. display is fixed on 1- 1 SAT. light is off. I tried to reset shorting AC and [-] for more than 3 sec. but nothing happened. I concern it...
mcdevito75 here, Return your watch to whoever replaced the battery for adjustments. ------ If you replaced the battery yourself, you may have mis-aligned the buttons that press against the quartz movement to change the display, you"ll have to go inside the watch and make sure the buttons are touching where they are suppose to. It"s also ossible your new battery is weak from a long shelf life. Here also is Casio contact number, 800-706-2534 Optn. 2
Jul 13, 2010 | Casio WVA105HDA Wave Ceptor watch
Changed battery .A square piece of metal the size of match head fell out. No alarm or light, casio forester FT200
mcdevito75 here, Of couse without the watch and piece of metal that fell out it"s very hard to say. Most likely it was part of the lock-down tab to keep the battery in place, in any event don"t lose that piece of metal. If your casio is working ok don"t worry about it, just don"t lose that piece of metal that fell out.
Jul 05, 2010 | Casio Forester PAS400B-5V Wrist Watch
Casio Databank watch
The replacement battery may be defective.
Nov 08, 2017 | Casio E-DataBank DBC3101 Wrist Watch
Casio Forester FT610WV3BV Wrist Watch Logo
681 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
