Question about Garden
How to set carburator for Mcculloch 3.4ci PM605 electronic ignition chain saw?
5 Suggested Answers
SOURCE: how to adjust carb. settings on a McCulloch Pro Mac 610 chain saw
turn both jets in untill snug (don't force) turn out ccw one full turn. increase by 1/8 turns untill set proper. should be between 1 1/4 and 1 1/2 normally. good luck. be safe.
Posted on Sep 21, 2008
  • 11 Answers
SOURCE: need owners maual for mcculloch power mac 6 chain saw
try my answer to the post on McCulloch pro/mac 10-10 chainsaw owners manual... posted by denniswick on Oct 03, 2008
Posted on Feb 13, 2009
  • 42 Answers
SOURCE: I have a McCulloch 10 10 Automatic Chain Saw. What is the oil to
40:1 of two stroke oil roughly 2..5% 40 parts fuel to 1 part oil mixed Good Luck the Yeti
Posted on May 17, 2009
dontbother10
  • 2220 Answers
SOURCE: flywheel/ignition coil air gap for mcculloch mac 130 chain saw
Specifications for a Mac 130 can be found here:
Chain Saw Collectors Corner
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/c1f32b7598cccadd88256c2f0019c792?OpenDocument
Ignition coil gap:
An index or business card is a good gap tool. Remove the plug, rotate until magnetic attraction pulls coil and card tight to flywheel, tighten the coil screws. Rotate flywheel until magnetic attraction eases, remove card, rotate a couple of revolutions and ensure nothing drags or contacts flywheel. HTH
Lou
Posted on Jan 07, 2010
McCulloch PM605 Owners Manuel
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
User manuals McCulloch Service
I trust this information proves beneficial.
Jun 16, 2016 | McCulloch Garden
Need a ignition coil for a promac 1000
get make & model number of saw and google.com or yahoo.com or ask.com and type in: want to buy ignition coil for mcculloch promac 1000
or type in mcculloch chain saw parts sales
Oct 04, 2013 | McCulloch Garden
Mcculloch chain saw,pro-mac 610, with electronic ignition, no spark at plug
If there is no spark with a new plug, and the earth cut out wire not connected, then it will require a new ignition unit, the old unit is not servicable.
Oct 28, 2011 | McCulloch Garden
I have a 14" Mcculloch
All modern chainsaws have electronic ignition, you should first try diss connecting the wire to the ignition switch, to rule out a fault with the switch, if still no spark check the gap between the the unit and the flywheel, this shouls be 0.3mm, if still no spark it will be a replacment ignition unit.
Jul 30, 2011 | McCulloch MCC1514 14Inch 15 HP Electric...
Need carburator adjustments high and low mac 3516
Basic settings one and a half turns out on both screws, you will need to fine tune from there.
Feb 15, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Mcculloch 3516 chain saw, does not always start.
It must have spark, fuel and compression to run. Your task is to figure out which is missing.
Sometimes electrical components quit operating once beyond a certain temperature. Does it always start cold and become tempermental when warm?
IMO most hard start problems on a chainsaw with a good fuel delivery system are flooded.
Start Procedure
Cold:
  1. Ignition on/off to on
  2. Set compression release – optional step even if saw is equipped with a compression release
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls; no more than 4)
  4. Set compression release – optional step even if saw is equipped with a compression release
  5. Push (open) choke pull starter until it starts. (usually first pull)
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) - Don’t pull with choke closed.
  4. Push (open) choke, pull starter until it starts. (usually first pull)
The 3516 is a MTD McCulloch (Chinese). These saws are in a class by themselves. Good Luck
Lou
Nov 15, 2009 | McCulloch Garden
On mcculloch 3200 need float setting for carburator (chain saw).
There are no carburetor floats in chainsaws made since 1960±.
Oct 15, 2009 | McCulloch Garden
I have Mcculloch Mac 10 10 chain saw year unknown
Put a small amount of fuel mix in the carburator. If it sputters investagate fuel system.
Lou
Oct 08, 2009 | McCulloch Garden
Garden Logo
61 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
