Question about Doro 225ipc IP Phone
I have my 225ipc connected to my computer via the USB as instructed but the phone and computer are showing that it is not connected. I have installed the software and Skype is already installed but I cannot get the phone to respond to the computer. What do I do?
    President:
  • 3,278 Answers
Hello.
First, disconnect the power to the phone. Wait 10 minutes. Reconnect again.
If resetting the power does not work, reset the router.
Hope this helps.
Posted on Sep 17, 2010
How do i use my samsung c5212 as a modem to pc and to connect to internet.
Follow the below mentioned steps : 1. Connect the Samsung cell phone and computer. If you are connecting via USB, connect one end of the USB cable to your Samsung phone and the other end to your computer. It may take a few seconds for the proper drivers for the Samsung phone to install. If pairing via Bluetooth, make sure Bluetooth is enabled on your Samsung phone and start a search for devices on your Bluetooth-enabled computer by right-clicking the Bluetooth icon in your taskbar.
2 Launch Internet Sharing, found in the Start menu on your Samsung cell phone. Open the application.
3 Configure Internet Sharing. The status menu should read "Disconnected." Under the PC Connection setting, select the method you will use to connect your cell phone to the computer--USB and Bluetooth PAN are the choices. You shouldn't need to change anything under Network Connection, unless a network other than is showing on the display.
4 Start the Internet Sharing connection. On your Samsung device, press the Connect soft key. It may take up to 30 seconds for the connection to be negotiated, during which the status line may say "Check USB cable connection"; this is normal.
5 Connect the computer to the Internet sharing phone. If your computer and phone are paired via USB, no further pairing is needed. You will see the shared Internet connection as a wired connection in your Network and Sharing control panel on the computer. If you are connected to the Internet Sharing application via a Bluetooth personal area network, the computer must be synced to the phone. Right-click on the Bluetooth icon in the taskbar and select "Connect to a PAN" or similar, based on the version of Windows you are using. A list of all Bluetooth PAN connections within range is shown; select your Samsung phone. The PAN connection will be negotiated, and the Internet connection will be shared.
May 14, 2011 | Cell Phones
I wanted to install nokia pc suite on my toshiba laptop for my nokia n70 cell phone.PC suite did install ok but it did not complete the installation of the interface cable.What should i do?
Did you follow the instruction on how to install the PC Suite? Their instruction is to install the PC Suite without you connecting the mobile via USB. After finishing the installation you will have to restart your laptop then connect the mobile phone via USB then it will auto detect possible drivers the mobile may need.
Mar 24, 2011 | Computers & Internet
I need to use this phone as a modem for internet. How?
  • Connect the Samsung cell phone and computer. If you are connecting via USB, connect one end of the USB cable to your Samsung phone and the other end to your computer. It may take a few seconds for the proper drivers for the AT&T Samsung phone to install. If pairing via Bluetooth, make sure Bluetooth is enabled on your Samsung phone and start a search for devices on your Bluetooth-enabled computer by right-clicking the Bluetooth icon in your taskbar.
  • Launch Internet Sharing, found in the Start menu on your AT&T Samsung cell phone. Open the application.
  • Configure Internet Sharing. The status menu should read "Disconnected." Under the PC Connection setting, select the method you will use to connect your cell phone to the computer--USB and Bluetooth PAN are the choices. You shouldn't need to change anything under Network Connection, unless a network other than AT&T is showing on the display.
  • Start the Internet Sharing connection. On your AT&T Samsung device, press the Connect soft key. It may take up to 30 seconds for the connection to be negotiated, during which the status line may say "Check USB cable connection"; this is normal.
  • Connect the computer to the Internet sharing phone. If your computer and phone are paired via USB, no further pairing is needed. You will see the shared Internet connection as a wired connection in your Network and Sharing control panel on the computer. If you are connected to the Internet Sharing application via a Bluetooth personal area network, the computer must be synced to the phone. Right-click on the Bluetooth icon in the taskbar and select "Connect to a PAN" or similar, based on the version of Windows you are using. A list of all Bluetooth PAN connections within range is shown; select your AT&T Samsung phone. The PAN connection will be negotiated, and the Internet connection will be shared.
Feb 04, 2011 | Samsung SGHE250i Cell Phone
Pls i connected my L6 motorola phone via usb to my pc and installed the driver automatically. after the installation, it only charges my phone. tell me what i can do to acess my phone from my pc?
WHEN CONNECTED YOUR MIOBILE TO PC INSTALL MOTOROLA PHONE TOOLS... THEN FOLLOW THE INSTRUCTIONS... THEN LAUNCH MOTOROLLA PHONE TOOLS...SELECT THE MEDIUM OF YOUR CONNECTION (DATA CABLE)AND SELECT MOBILE MODEL...SELECT OK... PICTURE OF YOUR PHONE WILL APPEAR ON THE SCREEN ... NOW CAN ACCESS YOUR PHONE WHEN CONNECTED SHOWS ON THE SCREEN...
Oct 04, 2010 | Motorola Mobility L6 Cellular Phone
My screen shows blank.how can i retrieve contacts through PC
you need [mymobiler]programme .install on computer,attatch phone via usb and you can see your phone and data on computer..
Apr 18, 2010 | T-Mobile Wing™ Smartphone
Renoir wont connect via USB even though its physically connected
this is a uninstalled driver issue...although you install the usb driver it is still not sorted in device manager ,,you need to go into device manager and re install driver manually.....
Apr 02, 2009 | LG KC910 Renoir Cell Phone
My sony ericsson w700i are not connecting by usb cable with pc
Ensure the software from sony is properly installed on the computer. If you do not have the sony software you can use mobilesyc from microsoft to access the phone
Feb 12, 2009 | Sony Ericsson W700i Cellular Phone
Unable to connet mobile phone to PC
because you have no pc suite try to install software like pc suite or connect it via blutooth,,,
Feb 04, 2009 | Nokia 2626 Mobile Phone
I am trying to install a cable modem with usb and ethernet connections on a windows xp computer.
Well there are 2 ways
via Ethernet
1.) connect the ethernet from the modem to the ethernet of the computer via the cable provided and thats should basically setup and give you an ip automatically
Via Usb
2.) install the drivers that came on a cd with the model
2.) follow the onscreen instructions and connect the modem via the usb cable when it tells you to
3.) when setup is complete it will create a connect icon for you, just run it to connect
Jul 14, 2008 | Computers & Internet
Doro 225ipc IP Phone Logo
264 people viewed this question
Top Doro Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
Taelisin
Moazzem Hossain
Moazzem Hossain
Are you a Doro Computer and Internet Expert? Answer questions, earn points and help others
