Question about Filter Queen Defender Air Purifier
How do you reset the red light on the defender when you put in a new filter? My light has never went out and I think it is supose to .
    Problem Solver:
  • 10 Answers
It won't go out by itself.
1. Plug unit into outlet. 2. Press power ON/OFF switch to the ON position. 3. Allow unit to start running at low speed. 4. PRESS and HOLD both the UP and DOWN arrow buttons until the FILTER REPLACEMENT INDICATOR starts to blink. 5. Release both the UP and DOWN arrow buttons. 6. While the FILTER REPLACEMENT INDICATOR is still flashing, again PRESS and HOLD both the UP and DOWN arrow buttons untile the FILTER REPLACEMENT INDICATOR turns off.
If the steps above have been performed properly, the Filter Replacement Indicator will turn offand not flash again for 11 months. If the Filter Replacement Indicator remains on, repeat the steps again.
*Note that in step 6 above, the Filter Replacement Indicator MUST still be flashing when the buttons are pressed the second time.The Filter Replacement Indicator will continue to flash for approximately 3 seconds after the buttons are released as required in step 5 above.
Posted on Jan 03, 2011
Need to reset my homedics hepa air cleaner
Press the lit reset button indicator and hold it for some time (I think it's like 5-6 seconds at least)
Oct 24, 2011 | Homedics AR10 Air Purifier
How do you reset the filter reminder warning light?
Filter Replacement
Filter Replacement Indicator:
Your Defender® is equipped with a Filter Replacement Indicator located on the front
panel. Anytime this red indicator flashes, it is recommended that you call your authorized
FILTERQUEEN® Distributor to order a replacement filter. Anytime this red indicator stops
flashing and remains solidly illuminated, it is recommended that you change your filter. To
receive full benefit from your Defender® and to extend your warranty, it is strongly
recommended that you follow the filter replacement schedule suggested above. Under higher
pollution levels, your filters will need to be replaced more frequently.
The Filter Replacement Indicator is operated by filter time in use and is controlled by an
onboard timer. After 11 months of time in use of your Medi-Filter® Cartridge, the Filter
Replacement Indicator will begin to flash. It will continue to flash until the you reach 12
months of time in use, at which time the Filter Replacement Indicator will stop flashing
and remain solidly illuminated.
After replacement of your Medi-Filter® Cartridge, you must reset the Filter
Replacement Indicator's timer. When the timer has been properly reset, the Filter
Replacement Indicator will turn off.
Resetting the Filter Replacement Indicator Timer:
After replacement of your Medi-Filter® Cartridge per the instructions found on page 7, the
Filter Replacement Indicator's timer can be reset by performing the following sequence of
steps:
1 Plug unit into outlet.
2 Press power On/Off switch to the On ("I") position.
3 Allow unit to start running at low speed.
4 PRESS and HOLD both the Up and Down arrow buttons until the Filter
Replacement Indicator starts to blink.
5 Release both the Up and Down arrow buttons.
6 While the Filter Replacement Indicator is still flashing*, again PRESS and
HOLD both the Up and Down arrow buttons until the Filter Replacement
Indicator turns off.
turn off and not flash again for 11 months. If the Filter Replacement Indicator remains
the buttons are pressed the second time. The Filter Replacement Indicator will continue
Note: Under higher pollution levels, your filters will need to be replaced more frequently.
Note: To order replacement filters, call your authorized FILTERQUEEN® Distributor, or call
1-440-846-7800 for the Distributor nearest you.
http://www.filterqueen.com/pdf/defender.pdf
Mar 02, 2011 | Filter Queen Defender Air Purifier
Mother gave me her filterqueen defender.. no manual. 360. There is a flashing red light even though its a new filter. Why?
The light is a reminder to change the filter, it does not sense if the filter has been changed or not.
When the red light is blinking, press and hold both up and down arrows until the red light blinks RAPIDLY, release both for a second or two, and press and hold both again until it stops blinking.
Dec 28, 2010 | Filter Queen Defender Air Purifier
How do you reset the machine, to get rid of the flashing red light after changing the filter?
Dec 09, 2010 | Filter Queen Defender Air Purifier
Defender air purifier
If you have replaced your main filter you need to reset the red light. If you have not replaced the main filter you will need to contact your local filterqueen distributor. If you go to www.filterqueen.com they will direct you to your closest distributor and they can walk you through over the phone on how to reset your red light.
Feb 15, 2008 | Filter Queen Defender Air Purifier
Filter Queen Defender red light will not blink
no with the red lite on it mean that you need to change your filter its a safety feature so you dont burn out your motor and also so you dont blow unpurified air through out your home
Oct 13, 2007 | Filter Queen Defender Air Purifier
Orange light help
Did you find an answer to your orange light question? I have an AM4000 defender that I bought off Craigslist and thought I got a good deal on it. One minute after turning it on the red light came on. I tried to reset it but  the red light won't flash so you can't reset it. I don't know if it's a filter problem or a circuit board problem and I don't want to spend $100 bucks on filters to find out it's a different problem. If you buy filters on e-bay, they're cheaper but if you spend $100 from a distributor then you reactivate the warranty. I'm sorry I bought it.
Sep 06, 2007 | Filter Queen Defender Air Purifier
Red light
Here is the link to the user manual; http://www.filterqueen.com/pdf/defender.pdf The red light indicates a filter needs replacing, see page 6 of the manual (page 9 of the pdf file) If filters have been replaced and the light still flashes, then the reset procedure (described on the same page) should work. If still flashing then there is a more serious, but probably fixable fault. Hope this helps - ask again if you need more info :)
Apr 13, 2007 | Filter Queen Defender Air Purifier
Red Light on front of Filter Queen Defender
When the red light is blinking, press and hold both up and down arrows until the red light blinks RAPIDLY, release both for a second or two, and press and hold both again until it stops blinking. It cured my problem.
Mar 06, 2007 | Filter Queen Defender Air Purifier
Replace Filter Indicator Will Not Turn Off
I owned the previous model of the same unit with the hole for the paperclip. But it wore out and I replaced it with the HAP422 and found the same issue; no hole to "reset" the light. I was just fooling with it and determined that "some" switch would reset it and finally held the power on button on for a few seconds, after which, the red light flashed and then went out. Problem solved. BUT THERE IS NOT ONE WORD IN THE MANUAL TO TELL YOU THIS! WHY NOT?
Dec 18, 2006 | Holmes Products HAP422G-U Air Purifier
Filter Queen Defender Air Purifier Logo
247 people viewed this question
Top Filter Queen Air Purifiers Experts
Colin Stickland
Colin Stickland
dj_wininger
Level 1 Expert
steve h woody
Are you a Filter Queen Air Purifier Expert? Answer questions, earn points and help others
